Unexpected error from cudaGetDeviceCount(). Did you run some cuda functions before calling NumCudaDevices() that might have already set an error? Erro
We encountered a problem when running the following script:
import torch
print (‘torch version:’, torch.version)
is_avail = torch.cuda.is_available()
print (‘is_avail:’, is_avail)
cnt = torch.cuda.device_count()
print ('device cnt: ', cnt)
curr_device = torch.cuda.current_device()
print (‘curr_device:’, curr_device)
device = torch.device(‘cuda:0’)
print (device)
aa = torch.randn(5)
aa = tensor([-2.2084, -0.2700, 0.0921, -1.7678, 0.7642])
aa.to(device)
print (‘Done’)
Result:
torch version: 2.1.0+cu121
/usr/local/lib/python3.8/dist-packages/torch/cuda/init.py:138: UserWarning: CUDA initialization: Unexpected error from cudaGetDeviceCount(). Did you run some cuda functions before calling NumCudaDevices() that might have already set an error? Error 802: system not yet initialized (Triggered internally at ../c10/cuda/CUDAFunctions.cpp:108.)
return torch._C._cuda_getDeviceCount() > 0
is_avail: False
device cnt: 1
File “test_cuda1.py”, line 11, in
File “/usr/local/lib/python3.8/dist-packages/torch/cuda/init.py”, line 769, in current_device
_lazy_init()
File “/usr/local/lib/python3.8/dist-packages/torch/cuda/init.py”, line 298, in _lazy_init
torch._C._cuda_init()
RuntimeError: Unexpected error from cudaGetDeviceCount(). Did you run some cuda functions before calling NumCudaDevices() that might have already set an error? Error 802: system not yet initialized
Below is from nvidia-smi:
| NVIDIA-SMI 535.129.03 Driver Version: 535.129.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA H800 Off | 00000000:17:00.0 Off | 0 |
| N/A 29C P0 73W / 700W | 18MiB / 81559MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1052 G /usr/lib/xorg/Xorg 4MiB |
We have tried uninstall/re-installing cuda/driver/pytorch with no use. Please advice.
The attached is the nvidia-bug-report.log.gz
The usual reasons for this are either an improper fabric manager install in a NVLink setup, or MIG mode improperly enabled.
Rather than using torch to figure this out, validate your CUDA install using the methods in the CUDA linux install guide.
Also, if it were me/my system, I wouldn’t use X enabled on an H800.
Thanks, Robert. The nvidia-smi shows that MIG is disabled. Also, what is X enabled on H800? How to disable it?
So my guess would be fabric manager, then. You haven’t indicated much about the system this is running in, so its just a guess.
See here.
Our server is Ubuntu 20.04.6 LTS. We are running pytorch inside a docker container in our server. The os in the docker container is Ubuntu 20.04.5 LTS. What other system info you need? I also have nvidia-bug-report.log.gz, but don’t know how to upload to the forum.
root@3fed4b1a61a3:/tao-pt/test# nvidia-smi topo -m
GPU0 CPU Affinity NUMA Affinity GPU NUMA ID
GPU0 X 0-19 0 N/A
root@3fed4b1a61a3:/tao-pt/test# nvidia-smi -q -i 0 | grep -i -A 2 Fabric
Fabric
State : In Progress
Status : N/A
Who is the manufacturer and what is the model number of the server? How many H800 GPUs are in the machine? Is it an HGX platform? What is the result of running nvidia-smi -a on the base machine (i.e. not in/from any container)?
I meet the same problem, with one GPU, i works fine, with two, it failed
test code:
import torch
def get_device():
  return 'cuda' if torch.cuda.is_available() else 'cpu'
device = get_device()
print(f'DEVICE: {device}')
print(torch.__version__)
both run in docker env
dc42e1d5d9bc(@:):/# nvcc -V
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Mon_May__3_19:15:13_PDT_2021
Cuda compilation tools, release 11.3, V11.3.109
Build cuda_11.3.r11.3/compiler.29920130_0
dc42e1d5d9bc(@:):/# apt search cudnn
Sorting... Done
Full Text Search... Done
libcudnn8/now 8.9.5.29-1+cuda11.8 amd64 [installed,local]
  cuDNN runtime libraries
libcudnn8-dev/now 8.9.5.29-1+cuda11.8 amd64 [installed,local]
  cuDNN development libraries and headers
the only differences is one use single GPU, the other use double
for my case, it works with blow commands
ca406134a828(@:):/# CUDA_DEVICE_ORDER="PCI_BUS_ID" PYTORCH_NVML_BASED_CUDA_CHECK=1 CUDA_VISIBLE_DEVICES=0,1 python3 ./test.py
DEVICE: cuda
2.2.1+cu121
ref: Unexpected error from cudaGetDeviceCount 错误解决_runtimeerror: unexpected error from cudagetdevicec-CSDN博客
