Unexpected error in updating: tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
Hi! On Orin NX 16GB, BSP 36.4, I’m running a flash command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-only --flash-only --external-device nvme0n1p1 -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
  1. I was running this flash command many times before and it worked.
  2. However I have reflashed my Jetson’s internal QSPI (with command: sudo ./flash.sh --no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit nvme0n1p1). QSPI flash succeeded. Log:
    qspi-flashing-36.4.log (105.5 KB)
  3. Now when running kernel/rootfs flash, script tries to change a file which doesn’t exist:
[   0.0219 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
Error: Unexpected error in updating: tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb 'Unexpected error in updating: tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
Such file doesn’t exist in BSP.
Full output:
unexpected-error-in-updating-with-odm-dtb.log (4.8 KB)
Hi filip.kubicz,
Are you using the devkit or custom board for Orin NX?
Please try to remove --flash-only in your command to flash the board.
Hi, this suggestion worked, thank you!
