Jetson Linux 36.3 + Orin Nano
flash with command:sudo ./flash.sh jetson-orin-nano-devkit-nvme internal
It turns out to be Orin NX:
flash log:
log.txt (98.8 KB)
Bus 004 Device 031: ID 0955:7020 NVIDIA Corp. L4T (Linux for Tegra) running on Tegra
You need to make device in recovery mode.
Likes below:
Bus <bbb> Device <ddd>: ID 0955: <nnnn> Nvidia Corp.
Bus 001 Device 111: ID 0955:7623 NVIDIA Corp. APX
Please refer to this doc to execute official recommended command instead.
#Jetson Orin Nano Developer Kit (NVMe):
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-orin-nano-devkit internal
Using official command :
-c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 jetson-orin-nano-devkit internal
flash log:
log.txt (324.5 KB)
Still shows Orin NX in dmesg or power GUI
One more question to confirm. Is your Orin Nano a dev kit or the custom carrier board?
Custom carrier board
the only file I modified is bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
cvb_eeprom_read_size = <0x100>; → cvb_eeprom_read_size = <0x0>;
Hi.
With our internal review, your device has been successfully flashed. Please ignore the name mismatch for now.
We will conduct further checks and get back to you once the name mismatch is resolved.
Any update?
Sorry for the late update.
With latest BSP (r36.4.3), we verify the name mismatch not find in Orin Nano dev kit.
Please install latest bsp version to check whether issue exists.
