I’ve installed 28.2, and had to re-compile the kernel to get Firewire support. I’m seeing the following errors (crashes in libnvidia-glcore.so.28.2.0):
[13596.761443] Library at 0x7f8b580950: 0x7f8a60d000 /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.28.2.0
[13596.771367] Library at 0x7f8b581090: 0x7f8a60d000 /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.28.2.0
[13596.781286] vdso base = 0x7f9caab000
[13597.234149] unity_support_t[20512]: unhandled level 2 translation fault (11) at 0x00000afc, esr 0x92000046
[13597.243814] pgd = ffffffc068ca9000
[13597.247237] [00000afc] *pgd=00000000e8c90003, *pud=00000000e8c90003, *pmd=0000000000000000
[13597.257046] CPU: 3 PID: 20512 Comm: unity_support_t Tainted: G W 4.4.38-huskybot-v0.1 #1
[13597.266271] Hardware name: quill (DT)
[13597.269946] task: ffffffc074dd5780 ti: ffffffc005abc000 task.ti: ffffffc005abc000
[13597.277439] PC is at 0x7f9089d950
[13597.280767] LR is at 0x7f9089e090
[13597.284095] pc : [<0000007f9089d950>] lr : [<0000007f9089e090>] pstate: 60000000
[13597.291495] sp : 0000007fe7dad4a0
[13597.294823] x29: 0000007fe7dad8f0 x28: 0000000000000001
[13597.300162] x27: 0000007fe7dad5f0 x26: 0000007fe7dad5b0
[13597.305506] x25: 0000007f91312000 x24: 0000007f91312b08
[13597.310865] x23: 00000000caf10000 x22: 0000007f91312b0c
[13597.316205] x21: 0000000000000000 x20: 00000000004d9870
[13597.321556] x19: 000000000048f870 x18: 0000007fe7dad880
[13597.326897] x17: 0000007f917e74c0 x16: 0000007f8f861b80
[13597.332232] x15: 0000007f91b4b000 x14: 0000000000000000
[13597.337584] x13: ffffffffffffffff x12: 0000000000000005
[13597.342923] x11: 0000000000000028 x10: df7854cf5f77ef56
[13597.348258] x9 : f561b7854eed6aae x8 : 11af0b836ee1aede
[13597.353606] x7 : 00000000ffffffff x6 : 0000000000000001
[13597.358948] x5 : 0000007fe7dad5f0 x4 : 00000000000030f1
[13597.364282] x3 : 00000000beef30f3 x2 : 00000000004d8870
[13597.369633] x1 : 0000000000001804 x0 : 0000000000000768
I’m happy to re-compile the kernel, but unfortunately I need FireWire modules available.
