Open Linux Kernel Modules Installed by Default
Starting in the release 560 series, it will be recommended to use the open flavor of NVIDIA Linux Kernel Modules wherever possible (Turing or later GPUs, or Ada or later when using GPU virtualization).
If installing from the .run file, installation will detect what GPUs are present and default to installing the open kernel modules if all NVIDIA GPUs in the system can be driven by the open kernel modules. Distribution-specific repackaging of the NVIDIA driver may require additional steps, specific to that packaging, to choose the open flavor.
In the release 560 series, it will still be possible to configure the .run file to install the proprietary flavor of kernel modules, with the
--kernel-module-type=proprietarycommand line option. However, in the future, some GPUs may only be supported with the open flavor. -
Support for 32-bit x86 kernels
The Linux-x86 and FreeBSD-x86 release packages, as well as support for 32-bit kernels in the Solaris package, are no longer provided starting with release 396.Support for 32-bit applications running on x86_64 kernels will continue.
See Support Plan for 32-bit and 64-bit Operating Systems | NVIDIA for more details.
Support for Fermi-based GPUs
Fermi-based GPUs are no longer supported starting with release 396. These GPUs were supported through the release 390 legacy branch, which received critical bug fixes and updates for compatibility with new Linux kernels and X server versions through the end of 2022.See What's a legacy driver? | NVIDIA for a list of Fermi-based GPUs.
Support for Maxwell-, Pascal-, and Volta-based GPUs
The release 580 series will be the last to support GPUs based on the Maxwell, Pascal, and Volta architectures. -
Minimum kernel version
The release 410 series was the last to support Linux 2.6.9 kernels. After that, the minimum required Linux kernel version moved to 2.6.32.
The release 470 series was the last to support Linux 2.6.32 kernels. After that, the minimum required Linux kernel version moved to 3.10.
The release 550 series was the the last to support Linux 3.10 kernels. After that, the minimum required Linux kernel version moved to Linux 4.15. -
Minimum X server version
The release 410 series was the last to support X.Org X servers older than version 1.5.
The release 418 series was the last to support X.Org X servers older than version 1.7.
The release 580 series will be the last to support X.Org X servers older than version 1.17. -
Minimum glibc version
The release 415 series was the last to support glibc 2.2.5 on Linux x86_64. After that, the minimum required glibc version for Linux x86_64 moved to 2.11. -
Support for non-GLVND OpenGL and EGL libraries on Linux
The release 430 series was the last to support installing Linux OpenGL and EGL client libraries that do not use the GL Vendor Neutral Dispatch (GLVND) loader library. -
Support for Serial Digital Interface (SDI) video output and capture
The release 430 series was the last to support the NVIDIA Quadro SDI Output and NVIDIA Quadro SDI Capture cards. -
Support for SLI AA/AFR/SFR modes
The release 450 series was the last to support the following SLI modes:
- AA
- AFR
- SFRSLI Mosaic, Base Mosaic, GL_NV_gpu_multicast, and GLX_NV_multigpu_context will continue to be supported in future driver series.
Support for older presets and rate control modes in NVENC API
The release 580 series will be the last one to support older presets and rate control modes in NVENC API.Refer to the preset migration guide at NVENC PRESET MIGRATION Guide
Minimum Wayland version
The release 580 series will be the last to support Wayland older than version 1.20.0.
Support for Xinerama
The release 595 series will be the last to support Xinerama. SLI Mosaic or RandR display offload (also known as “Reverse PRIME”) can be used to extend an X11 screen across displays on multiple GPUs.
Minimum FreeBSD version
A future release will raise the minimum supported version of FreeBSD to 14.3-RELEASE from 12.2-STABLE.
