Unknown error trying to cudaFree array of pointers
I looked carefully at Sarnath’s recent discussion of using arrays of pointers which made perfect sense to me before I made this post but for some reason cudaFree in the following code is returning “unknown error”. This is simple code that just zeros out an array of float arrays. I feel like I must be missing something simple but I don’t see why cudaFree is complaining. The code throws no other errors and of course it runs fine with emulation.
Thanks for any help.
  • Richard
[  Host code ]
extern "C" void ciZeroFloat( float *arrays[], int numArrays, int size ) {
	const int xBlockDim = 128;
	const int yBlockDim = 1;
	int yGridBlocks = numArrays;
	int xGridBlocks;
	cudaStream_t thisStream;
	cudaStreamCreate( &thisStream );
	dim3 dimBlock(xBlockDim,yBlockDim);
	if (size % xBlockDim == 0) xGridBlocks = (size)/xBlockDim;
	else xGridBlocks = (size)/xBlockDim + 1;
	dim3 dimGrid(xGridBlocks,yGridBlocks);
	float** d_fPtrArray;
	cutilSafeCall( cudaMalloc( (void**) &d_fPtrArray, numArrays*sizeof( float* ) ) );
	for (int i=0; i<numArrays; i++) d_fPtrArray[i] = arrays[i];
	kZeroFloat<<< dimGrid, dimBlock, 0, thisStream >>> ( d_fPtrArray, numArrays, size );
	cutilSafeCall( cudaStreamDestroy(thisStream) );
	cutilSafeCall( cudaFree( d_fPtrArray ) );  // returns -- unknown error
[Device code]
__global__ void
kZeroFloat( float *arrays[], int numArrays, int size ) {
	int ndx = threadIdx.x + __mul24(blockIdx.x,blockDim.x);
	int arrNum = blockIdx.y;
			   __syncthreads();  // no change with our without __syncthreads()
	if (blockIdx.y < numArrays && ndx < size) {
		arrays[blockIdx.y][ndx] = 0.0f;
The problem is probably here:
cudaMalloc() allocates memory on the GPU.
The for loop right below it executes on the Host.
Mixing like this is not good :-)
-Mark Roulo
Thank you Mark, you’re absolutely right, can’t believe I missed that. Clearly I am indexing into my device array from the host and the following code seems to have fixed the problem.
cutilSafeCall( cudaMemcpy( d_fPtrArray, arrays, numArrays*sizeof( float* ), cudaMemcpyHostToDevice) );
Sorry to post for such a simple problem but sometimes a second set of eyes can be so incredibly helpful, especially if you’re a CUDA newbie and the only CUDA guy on the project. Thanks so much.
  • R
