I am currently tuning the performance of Tensorflow with memory oversubscription feature by Unified Memory on IBM AC922.
Tensorflow firstly pre-allocates a huge memory space using cuMemAllocManaged as a memory pool.
Then during runtime, it allocates space for tensors from the memory pool, and deallocates when a tensor will be no longer used.
After conducting some profiling, I found a large number of page faults are caused by writing data to a newly allocated space (new tensor).
These page faults are followed by host-to-device (HtoD) page migration that copies the page from system memory to GPU memory.
Since logically we know the allocation is new, it is unnecessary to do the copy; but instead, it is better to invalidate the page on system memory and allocate a new one on GPU, with the same virtual memory address.
Is there any way to avoid such unnecessary copies? I guess it would, to a great extent, speed up DNN training.
Thanks in advance,
Chi-Chung
In an oversubscription scenario, if the GPU writes to the complete range of an oversubcribed single allocation, it should be evident that some D->H traffic will be inevitable.
I can’t explain the H->D traffic immediately, but there is the possibility of thrashing.
In an oversubscribed scenario, if the GPU writes to a range of memory that will fit within GPU memory (only) then there is no migration of data in the no-host-write case, according to my testing.
$ cat t398.cu
#include <stdio.h>
#include <cuda_profiler_api.h>
__global__ void k(int *d){
size_t idx=threadIdx.x+blockDim.x*blockIdx.x;
d[idx] = 0;
int main(){
size_t ds = 5ULL*1024ULL*1048576ULL; // 20 GB allocation on 16GB GPU
int *d;
cudaMallocManaged(&d, ds*sizeof(int));
#ifdef HOST_WRITE
for (size_t i = 0; i < ds; i++) d[i] = 1;
#endif
#ifndef USE_8
size_t ks = ds;
#else
size_t ds_8GB = 2ULL*1024ULL*1048576ULL; // 8 GB
size_t ks = ds_8GB;
#endif
k<<<ks/256, 256>>>(d);
cudaDeviceSynchronize();
cudaProfilerStop();
$ nvcc -arch=sm_60 -o t398 t398.cu -DUSE_8
$ nvprof --device-buffer-size 1024 ./t398
==31926== NVPROF is profiling process 31926, command: ./t398
==31926== Profiling application: ./t398
==31926== Profiling result:
Type Time(%) Time Calls Avg Min Max Name
GPU activities: 100.00% 1.45063s 1 1.45063s 1.45063s 1.45063s k(int*)
API calls: 61.86% 1.45069s 1 1.45069s 1.45069s 1.45069s cudaDeviceSynchronize
37.85% 887.77ms 1 887.77ms 887.77ms 887.77ms cudaMallocManaged
0.20% 4.7682ms 384 12.417us 365ns 509.98us cuDeviceGetAttribute
0.06% 1.4154ms 4 353.86us 229.38us 536.43us cuDeviceTotalMem
0.02% 450.02us 4 112.50us 97.579us 136.42us cuDeviceGetName
0.01% 132.51us 1 132.51us 132.51us 132.51us cudaLaunchKernel
0.00% 23.042us 4 5.7600us 4.3950us 8.2050us cuDeviceGetPCIBusId
0.00% 8.4410us 8 1.0550us 443ns 1.8120us cuDeviceGet
0.00% 5.0430us 3 1.6810us 423ns 2.3320us cuDeviceGetCount
0.00% 2.2140us 4 553ns 454ns 786ns cuDeviceGetUuid
==31926== Unified Memory profiling result:
Device "Tesla P100-PCIE-16GB (0)"
Count Avg Size Min Size Max Size Total Size Total Time Name
23424 - - - - 1.429526s Gpu page fault groups
==31969== NVPROF is profiling process 31969, command: ./t398
==31969== Profiling application: ./t398
==31969== Profiling result:
GPU activities: 100.00% 4.92223s 1 4.92223s 4.92223s 4.92223s k(int*)
API calls: 84.15% 4.92231s 1 4.92231s 4.92231s 4.92231s cudaDeviceSynchronize
15.73% 920.32ms 1 920.32ms 920.32ms 920.32ms cudaMallocManaged
0.08% 4.9341ms 384 12.849us 303ns 523.25us cuDeviceGetAttribute
0.03% 1.4693ms 4 367.32us 227.18us 570.92us cuDeviceTotalMem
0.01% 441.40us 4 110.35us 96.085us 131.23us cuDeviceGetName
0.00% 124.54us 1 124.54us 124.54us 124.54us cudaLaunchKernel
0.00% 22.922us 4 5.7300us 4.4880us 8.1420us cuDeviceGetPCIBusId
0.00% 9.5170us 8 1.1890us 512ns 2.7860us cuDeviceGet
0.00% 6.5430us 3 2.1810us 366ns 3.7320us cuDeviceGetCount
0.00% 2.2490us 4 562ns 443ns 742ns cuDeviceGetUuid
==31969== Unified Memory profiling result:
88761 47.254KB 4.0000KB 988.00KB 4.000000GB 472.8389ms Host To Device
2761 2.0000MB 2.0000MB 2.0000MB 5.392578GB 452.4796ms Device To Host
58213 - - - - 4.858694s Gpu page fault groups
$ nvcc -arch=sm_60 -o t398 t398.cu -DHOST_WRITE
==32021== NVPROF is profiling process 32021, command: ./t398
==32021== Profiling application: ./t398
==32021== Warning: Found 82 invalid records in the result.
==32021== Warning: This can happen if device ran out of memory or if a device kernel was stopped due to an assertion.
==32021== Profiling result:
GPU activities: 100.00% 6.45874s 1 6.45874s 6.45874s 6.45874s k(int*)
API calls: 85.08% 6.45879s 1 6.45879s 6.45879s 6.45879s cudaDeviceSynchronize
14.82% 1.12464s 1 1.12464s 1.12464s 1.12464s cudaMallocManaged
0.07% 5.3009ms 384 13.804us 355ns 582.09us cuDeviceGetAttribute
0.02% 1.6069ms 4 401.72us 266.27us 616.44us cuDeviceTotalMem
0.01% 556.18us 4 139.05us 106.50us 190.73us cuDeviceGetName
0.00% 195.35us 1 195.35us 195.35us 195.35us cudaLaunchKernel
0.00% 23.848us 4 5.9620us 4.2110us 8.1680us cuDeviceGetPCIBusId
0.00% 7.9820us 8 997ns 477ns 1.6850us cuDeviceGet
0.00% 6.3990us 3 2.1330us 332ns 3.9300us cuDeviceGetCount
0.00% 2.6670us 4 666ns 534ns 886ns cuDeviceGetUuid
==32021== Unified Memory profiling result:
436462 47.975KB 4.0000KB 988.00KB 19.96922GB 2.306184s Host To Device
2757 2.0000MB 2.0000MB 2.0000MB 5.384766GB 451.1309ms Device To Host
57850 - - - - 6.386874s Gpu page fault groups
Total CPU Page faults: 61440
Tesla P100, CUDA 10.0, CentOS 7
