Unrecognized Token in kernel
The following kernel is given in the document Scan using CUDA on page number 10 to 12.
When I compile the code I get the following errors:
[root@kiran Download]# nvcc Scan13.cu -deviceemu -o Scan
Scan13.cu(59): error: unrecognized token
Scan13.cu(59): error: expected a “]”
4 errors detected in the compilation of “/tmp/tmpxft_00001307_00000000-4_Scan13.cpp1.ii”.
I have folllwoing questions here:
1- In the line : #define CONFLICT_FREE_OFFSET(n) \ ((n) >> NUM_BANKS + (n) >> (2 * LOG_NUM_BANKS))
what is the meaning ""? should it not be “/” ?
2- I am getting all the four errors in the following line of the code:
if (thid==0) { temp[n - 1 + CONFLICT_FREE_OFFSET(n - 1)] = 0; } //// clear the last element
3 of these 4 errors say : “unrecognized token”. What is the meaning of token here with respect to line 59
where I am clearing last element. And why the same error is coming up
three times when I think the instruction is executed only once during compilation.
3- I am unable to understand “/tmp/tmpxft_00001307_00000000-4_Scan13.cpp1.ii”. What is tmp, tmpxft_00001307_00000000-4_Scan13.cpp1.ii
What is .ii file etc?
4-why "expected a “]” error is coming in the line 59 i.e:
Thanks in advance!!
The kernel along with the Macro is given below (please notice the bold lines):
#define NUM_BANKS 16
#define LOG_NUM_BANKS 4
#ifdef ZERO_BANK_CONFLICTS
#define CONFLICT_FREE_OFFSET(n) \ ((n) >> NUM_BANKS + (n) >> (2 * LOG_NUM_BANKS))#else
#define CONFLICT_FREE_OFFSET(n) ((n) >> LOG_NUM_BANKS)
#endif
global void prescan(float *g_odata, float *g_idata, int n)
extern shared float temp;// allocated on invocation
int thid = threadIdx.x;
int offset = 1;
int ai = thid;
int bi = thid + (n/2);
int bankOffsetA = CONFLICT_FREE_OFFSET(ai);
int bankOffsetB = CONFLICT_FREE_OFFSET(ai);
temp[ai + bankOffsetA] = g_idata[ai];
temp[bi + bankOffsetB] = g_idata[bi];
for (int d = n>>1; d > 0; d >>= 1) // build sum in place up the tree
__syncthreads();
if (thid < d)
int ai = offset*(2thid+1)-1;
int bi = offset
(2*thid+2)-1;
ai += CONFLICT_FREE_OFFSET(ai);
bi += CONFLICT_FREE_OFFSET(bi);
temp[bi] += temp[ai];
offset *= 2;
for (int d = 1; d < n; d *= 2) // traverse down tree & build scan
offset >>= 1;
__syncthreads();
if (thid < d)
int bi = offset
(2*thid+2)-1;
float t = temp[ai];
temp[ai] = temp[bi];
temp[bi] += t;
__syncthreads();
g_odata[ai] = temp[ai + bankOffsetA];
g_odata[bi] = temp[bi + bankOffsetB];
You should fix this
<b>#define CONFLICT_FREE_OFFSET(n) \ ((n) >> NUM_BANKS + (n) >> (2 * LOG_NUM_BANKS))</b>#else
#endif
to this:
#else
#endif
plain macro typo… you’re missing a line-feed there
eyal
Thanks a lot eyal!!
Can you tell me why I am getting “Unrecognised Token” error three times and why it is expecting “]” in line 59 wher I am clearing the last element?
Its a compiler complain - nothing to do with CUDA :)
you’ll get an error for every line that has the faulty macro.
eyal
Ok. Got it!!!
By the way do you think the way temp has been declared has nothing to do with the error and there is no error in the decerlarion:
What’s the problem with this line? its not a macro if thats what you mean…
eyal
