CUDA thread
#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#define BLOCK_DIM 512
const int size_x=512;
const int size_y=1;
__global__ static void ThreadDemo1(unsigned int* ret)
  unsigned int xindex=blockDim.x*blockIdx.x+threadIdx.x;
  unsigned int yindex=blockDim.y*blockIdx.y+threadIdx.y;
if(xindex<size_x && yindex<size_y)
	 unsigned int index=xindex+size_x*yindex;
	 ret[index]=xindex;
	 ret[index+size_x*size_y]=yindex;
void ThreadDemo1()
  unsigned int* ret=0;
  unsigned int  host_ret={0};
  int i=0;
cudaMalloc((void**) &ret, sizeof(unsigned int)*(size_x*size_y*2));
dim3 grid(size_x / BLOCK_DIM, 1);
  dim3 block(BLOCK_DIM,1,1);
ThreadDemo1<<<grid,block>>>(ret);
cudaMemcpy(&host_ret, ret, sizeof(unsigned int)*(size_x*size_y*2), cudaMemcpyDeviceToHost);
for(i=0; i<size_x*size_y; i++)
	printf(¨(%d,%d)¨,host_ret[i],host_ret);
  cudaFree(ret);
This is a CUDA programme about testing the threads. When I compile it, it says
threadDemo.cu(41): error: unrecognized token
threadDemo.cu(41): error: expected an expression
the line 41 is the line in red.
who can tell me why it is unrecognized? Thanks :blink:
Maybe you’re using the wrong quotation marks, try replacing ¨ with "
N.
Thanks a lot!! External Media
