I just upgraded to c2050.
When trying to run my application, i get a cuda error of type “unspecified launch failure”.
The same code works just fine on machines with c1060.
Driver version: 258.96
Any ideas anyone?
Any ideas anyone?
Check your shared memory access. Fermi doesn’t forgive out-of-bounds when accessing shared memory arrays, G80/G92/G200 is more forgiving, unless you overwrite your kernel launch parameters or block and grid size.
Indeed a shared memory access violation!
Thanks a bunch!
eldad.
