Hi All,
My kernel look like this :
[codebox]device float contrib_e[100][400][24][4];
device float flux[100][400][24][4];
global void Integral_opal(float d_global_data[70][13][24][10000], int coord[100][8], float d_y[100][24], int d_cutoff[100][4], float d_el[4][100][24], float d_kappa_r[100][4], float d_flux[24][100][4]){
fill contrib_e and flux and return the result in d_kappa_r and d_flux
}[/codebox]
this kernel is called by
[codebox]Integral_opal<<<dim3(100,1),dim3(400,1)>>>((float()[70][13][24][10000])d_global_data, (int()[100][8])d_coord, (float()[100][24])d_y, (int()[100][4])cutoff, (float()[4][100][24])d_el, (float()[100][4])d_kappa_r, (float(*)[24][100]4])d_flux);[/codebox]
and this return “unspecified launch failure”…
if i change <<<dim3(100,1),dim3(400,1)>>> to <<<dim3(100,1),dim3(1,1)>>>, then the code runs, but once we increase it to <<<dim3(100,1),dim3(2,1)>>> or above, the error come back.
Does anyone know what this error mean? where should I look?
thanks
