My Jetson Orin Nano gave me a notification to reboot for an update.
Previously, I have written a dtb overlay which I applied using the jetson-io tools and has been working consistently.
Since updating, in the boot menu, the config is still seen to be selected, however, the effects that should be cause by the dtbo are not applied. extlinux.conf has not changed and the dtbo is still present in /boot.
Based on the provided context, it appears that you are experiencing an issue with your Jetson Orin Nano after a recent update. Specifically, you had previously applied a custom dtb overlay using the jetsonio tools, which was working correctly. However, after the update, the effects of the dtbo are no longer being applied, despite the config still being selected in the boot menu.
To troubleshoot this issue, let’s consider a few possible explanations:
Boot partition changes: The update might have altered the boot partition, which could be causing the dtbo to not be applied. According to the context, there is a discussion about the differences in boot partitions between manual flash and OTA updates (What are the differences in boot partitions between manual flash and OTA update?). It’s possible that the update changed the boot partition, which is preventing the dtbo from being applied.
UEFI secure boot: The context mentions enabling UEFI secure boot by OTA from 35.5.0 to 35.6.0 ([Orin Nano NVME] SKU 003 Enable UEFI secure boot by OTA from 35.5.0 to 35.6.0). It’s possible that the update enabled UEFI secure boot, which is preventing the custom dtbo from being applied.
extlinux.conf changes: Although you mentioned that extlinux.conf has not changed, it’s possible that there are other changes in the boot configuration that are preventing the dtbo from being applied.
To resolve this issue, you could try the following steps:
Reapply the dtbo: Try reapplying the custom dtbo using the jetsonio tools to see if it resolves the issue.
Check the boot partition: Verify that the boot partition has not changed and that the dtbo is still present in the correct location.
Disable UEFI secure boot: If UEFI secure boot was enabled by the update, try disabling it to see if it resolves the issue.
Verify extlinux.conf: Double-check that extlinux.conf has not changed and that the dtbo is still referenced correctly.
Check for other boot configuration changes: Verify that there are no other changes in the boot configuration that could be preventing the dtbo from being applied.
If none of these steps resolve the issue, it may be helpful to provide more information about the custom dtbo and the changes you made to the boot configuration. Additionally, you can try searching the context for other discussions related to dtbo and boot configuration issues on the Jetson Orin Nano.
The overlay in /boot is definitely mine. It is custom and named clearly.
The correct boot config is detected and being used but the effects of the overlay were not applying.
I have fixed this by simply reapplying using the Jetson-IO tools. The overlay now applies as it should. However, I am confused as to why it was not working before?
Thanks ~0120
Sorry for the late response.
