Upgrade Embedded Controller from 0x00000001 to 0x02004203? problem /Failed to download due to server limit
sudo apt update
sudo apt dist-upgrade
sudo fwupdmgr refresh
sudo fwupdmgr upgrade
dont work
Devices with no available firmware updates:
• MZALC4T0HBL1-00B07
• UEFI dbx
║ Upgrade Embedded Controller from 0x00000001 to 0x02004b03? ║
║ This update improves the performance and stability of the Embedded ║
║ Controller in DGX Spark ║
║ NVIDIA_DGX_Spark must remain plugged into a power source for the duration ║
║ of the update to avoid damage. ║
Perform operation? [Y|n]: Y
Downloading… [ - ]
Downloading… [ - ]
This could be a transient network error. We just released a major software update today so please try to update your system again.
Same problem
• UEFI dbx
Downloading… [ / ]
Have you tried upgrading through the DGX Dashboard instead? That is our recommended way to perform updates.
Of course, I first tried the update via “DGX Dashboard”, but it didn’t work there either, and then I was directed to manual update.
Now I’ve tried again via the dashboard.
Result:
As the error message says, please try rebooting, especially if you haven’t after trying to update via command line
There was already a thread about this,
and command-line update commands were suggested as a solution.
The thread starter’s problem was solved.
It wasn’t resolved for me either,
so I opened this thread.
First, you told me to try again, but that didn’t work.
Then, you told me to update via DGX Dashboard.
I tried, but it didn’t work.And now you’re saying,
“As the error message says, please try rebooting, especially if you haven’t tried to update via command line.”
Of course, I’ve rebooted many times.
There are a total of three DGX Spark on the same network, and only one of them has this problem.
Your suggestions are a vicious cycle.
Try DGX Dashboard + reboot
Try commandline + reboot
If the updates over network are not working, then I would recommend reimaging the Spark to the latest version
