It was said fixed in somewhat version of software:
"[200166169] Using NvGstCapture-1.0, video snapshot captured by CSI camera is upside
May I know which attribute to add to there to get it reverse upside down ?
nvgstcapture -m 2 -k 2 -w 10
Hi Andrey1984, on r28.1/TX2, please try ‘nvgstcapture-1.0 --orientation=0’
orientation as well can be set up with
so:1
so:2
so:3
so:4
under nvgstcapture terminal.
Could you let me know how to switch resolution from 640:480 to any other, please? An all attempts to change pcr vcr icr it says “not supported” and only does pictures/videos in 640:480 by now
** Message: <main:5374> Capture completed
** Message: <main:5424> Camera application will now exit
root@tegra-ubuntu:/home/nvidia# nvgstcapture
Encoder null, cannot set bitrate!
Encoder Profile = Baseline
Supported resolutions in case of CSI Camera
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Runtime CSI Camera Commands:
Help : 'h'
Quit : 'q'
Set Capture Mode:
mo:<val>
(1): image
(2): video
Get Capture Mode:
gmo
Set Sensor Id (0 to 10):
sid:<val> e.g., sid:2
Get Sensor Id:
gsid
Set sensor orientation:
so:<val>
(0): none
(1): Rotate counter-clockwise 90 degrees
(2): Rotate 180 degrees
(3): Rotate clockwise 90 degrees
Get sensor orientation:
gso
Set Whitebalance Mode:
wb:<val>
(0): off
(1): auto
(2): incandescent
(3): fluorescent
(4): warm-fluorescent
(5): daylight
(6): cloudy-daylight
(7): twilight
(8): shade
(9): manual
Get Whitebalance Mode:
gwb
Set Scene-Mode:
scm:<val>
(0): face-priority
(1): action
(2): portrait
(3): landscape
(4): night
(5): night-portrait
(6): theatre
(7): beach
(8): snow
(9): sunset
(10): steady-photo
(11): fireworks
(12): sports
(13): party
(14): candle-light
(15): barcode
Get Scene-Mode:
gscm
Set Color Effect Mode:
ce:<val>
(1): off
(2): mono
(3): negative
(4): solarize
(5): sepia
(6): posterize
(7): aqua
Get Color Effect Mode:
gce
Set Auto-Exposure Mode:
ae:<val>
(1): off
(2): on
(3): OnAutoFlash
(4): OnAlwaysFlash
(5): OnFlashRedEye
Get Auto-Exposure Mode:
gae
Set Flash Mode:
f:<val>
(0): off
(1): on
(2): torch
(3): auto
Get Flash Mode:
gf
Set Flicker Detection and Avoidance Mode:
fl:<val>
(0): off
(1): 50Hz
(2): 60Hz
(3): auto
Get Flicker Detection and Avoidance Mode:
gfl
Set Contrast (0 to 1):
ct:<val> e.g., ct:0.75
Get Contrast:
gct
Set Saturation (0 to 2):
st:<val> e.g., st:1.25
Get Saturation:
gst
Set Exposure Time in seconds:
ext:<val> e.g., ext:0.033
Get Exposure Time:
gext
Set Auto Exposure Lock(0/1):
ael:<val> e.g., ael:1
Get Auto Exposure Lock:
gael
Set Edge Enhancement (0 to 1):
ee:<val> e.g., ee:0.75
Get Edge Enhancement:
gee
Set ROI for AE:
It needs five values, ROI coordinates(top,left,bottom,right)
and weight in that order
aer:<val> e.g., aer:20 20 400 400 1.2
Get ROI for AE:
gaer
Set ROI for AWB:
wbr:<val> e.g., wbr:20 20 400 400 1.2
Get ROI for AWB:
gwbr
Set FPS range:
It needs two values, FPS Range (low, high) in that order
fpsr:<val> e.g., fpsr:15 30
Get FPS range:
gfpsr
Set WB Gains:
It needs four values (R, GR, GB, B) in that order
wbg:<val> e.g., wbg:1.2 2.2 0.8 1.6
Get WB Gains:
gwbg
Set TNR Strength (0 to 1):
ts:<val> e.g., ts:0.75
Get TNR Strength:
gts
Set TNR Mode:
tnr:<val>
(0): NoiseReduction_Off
(1): NoiseReduction_Fast
(2): NoiseReduction_HighQuality
Get TNR Mode:
gtnr
Capture: enter 'j' OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter '1'
Stop Recording : enter '0'
Video snapshot : enter '2' (While recording video)
Set Preview Resolution:
pcr:<val> e.g., pcr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Note - For preview resolutions 4208x3120 and more use option --svs=nveglglessink
Get Preview Resolution:
gpcr
Set Image Resolution:
icr:<val> e.g., icr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Get Image Capture Resolution:
gicr
Set Video Resolution:
vcr:<val> e.g., vcr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
Get Video Capture Resolution:
gvcr
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br:<val> e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep:<val> e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter 'f'
bitrate = 4000000
Available Sensor modes :
2592 x 1944 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
2592 x 1458 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
1280 x 720 FR=120.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
** Message: <main:5364> iterating capture loop ....
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 1 WxH = 2592x1458 FrameRate = 30.000000 ...
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
pcr:1
-------> Not supported <------
pcr:2
-------> No
basically I am looking for a way to take a picture with high res with the camera, with somewhat res;
evidently found an option to do that via the loopback;
but nvgstcapture resolution change wont work;
Hi Andrey1984,
For running in 1920x1080, the command is
$ nvgstcapture --prev-res=4 --image-res=4
