I try to understand what i can do multiGPUs. I make a small program that perform 3D gradient computation on 2 Quadro 5600 GPU. I give them the same input, and hope that they will produce same output.
However when i run the code, the test failed most of the time. Can any one try and explain why that happen.
Thank you. I really need to understand why it failed, without it i can not continue my research. I’m stuck. multiGPU.tar.gz (2 KB)
are all global and therefore shared between threads. You need to have separate variables for each thread, otherwise one thread will overwrite the address placed there by another thread.
The programming guide isn’t going to tell you that you need separate CPU variables to avoid race conditions between threads. This is a basic multi-threading concept. (This sounds somewhat confusing, but remember the pointers to device memory actually exist in the CPU’s memory space.)
If it helps, I’ve learned you need separate variables for each thread/GPU/CUDA context for everything except texture references and constant symbols.
