I have a usb camera source device connected to jetson nano. The device is not detected on startup, but is detected after a reboot. What can be the issue for this?
Thanks in advanced
Thanks in advanced
It is very likely the signals(D+/D- pins) are not stable in the condition, so it fails in enumeration. A possible solution is to trigger enumeration after bootup. Please refer to this post:
Power down USB ports - #4 by vsaw
I tried the below commands
sudo uhubctl -l 1-2 -a off
sudo uhubctl -l 1-2 -a on
But after powering on I get the below message
Failed to open /dev/video0: Device or resource busy
Do you use Jetson Nano developer kit? The command shall work on developer kit.
I tested these commands in the jetson nano developer kit. Power down command seems to work (the usb devices are turned off) but power on command is not working properly the video devices are not detected but the connected keyboard is detected
Hi @DaneLLL
The issue for not enumerating properly maybe due to the external USB hub connected to the jetson. But the below command solved the issue for me
sudo uhubctl -l 1-2 -a cycle -d 5 -R
