The dmesg xhci and usb related lines are: (the 5000M is the SS0, and the 480M is the SS1)
ubuntu@tegra-ubuntu:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/5p, 480M
ubuntu@tegra-ubuntu:~$ cat A.txt | grep xhci
[ 4.914341] tegra-xhci tegra-xhci: num_hsic_port 0
[ 4.933449] tegra-xhci tegra-xhci: Firmware timestamp: 2016-06-16 13:21:43 UTC, Version: 50.16 release, Falcon state 0x20
[ 4.959083] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 4.966001] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[ 4.994390] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 5.048759] usb usb1: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[ 5.066805] usb usb1: SerialNumber: tegra-xhci
[ 5.073029] xHCI xhci_add_endpoint called for root hub
[ 5.073037] xHCI xhci_check_bandwidth called for root hub
[ 5.160717] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 5.167870] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 5.178011] usb usb2: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[ 5.178015] usb usb2: SerialNumber: tegra-xhci
[ 5.221257] xHCI xhci_add_endpoint called for root hub
[ 5.221259] xHCI xhci_check_bandwidth called for root hub
[ 5.654576] usb 2-1: new SuperSpeed USB device number 2 using tegra-xhci
[ 5.942825] usb 2-1: reset SuperSpeed USB device number 2 using tegra-xhci
ubuntu@tegra-ubuntu:~$ cat A.txt | grep usb
[ 4.669586] usbcore: registered new interface driver xpad
[ 4.669609] usbcore: registered new interface driver usb_acecad
[ 4.669632] usbcore: registered new interface driver aiptek
[ 4.669653] usbcore: registered new interface driver gtco
[ 4.669678] usbcore: registered new interface driver hanwang
[ 4.669705] usbcore: registered new interface driver kbtab
[ 4.669727] usbcore: registered new interface driver wacom
[ 5.001172] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.021980] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.041907] usb usb1: Product: Nvidia xHCI Host Controller
[ 5.177996] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.178002] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.178007] usb usb2: Product: Nvidia xHCI Host Controller
[ 5.252276] usbcore: registered new interface driver uvcvideo
[ 5.758444] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 5.758450] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 5.758454] usb 2-1: Product: USB 10/100/1000 LAN
[ 5.758458] usb 2-1: Manufacturer: Nvidia
[ 5.758461] usb 2-1: SerialNumber: 000001000000
[ 6.015601] usbcore: registered new interface driver usbhid
[ 6.022910] usbhid: USB HID core driver
[ 6.334059] usbcore: registered new interface driver snd-usb-audio
[ 7.886123] usb-vbus3: disabling
[ 7.890491] usb-vbus1: disabling
