Hello.
I have a TX2 with a custom carrierboard which provides one USB 3.0 and two USB 2.0 ports. However, SuperSpeed (USB 3.0 speed mode) negotiation doesn’t work in the former; it provides HighSpeed (USB 2.0 speed) at most.
I test this with lsusb -t
and SuperSpeed-capable devices (hard drives and cameras). In a PC, they effectively use SuperSpeed. What’s more, even if I put the exact same TX2 module in a Jetson board, without making any changes to the filesystem, SuperSpeed works.
The connector in the board is Type-C and I’m using an adapter to Type-A, but I’ve verified that it does work well in a PC.
I’m using Jetpack 3.2.1 and L4T 28.2.1. The kernel is the same that comes with L4T. The DTB is a modified one, I’m attaching the relevant parts.
tegra186-quill-p3310-c03-00-base.dts
xhci@3530000 {
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>;
phy-names = "utmi-0", "utmi-1", "usb3-0";
pinctrl@3520000 {
pinmux {
usb3-std-A-port2 {
nvidia,lanes = "usb3-0";
tegra186-quill-p3310-1000-a00-00-base.dts
usb_cd {
status = "okay";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>;
phy-names = "otg-phy";
xotg {
status = "okay";
phy-names = "otg-usb2";
xudc@3550000 {
status = "okay";
phy-names = "usb2";
emc-frequency = <150000000>;
xhci@3530000 {
status = "okay";
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>;
phy-names = "utmi-0", "utmi-1", "usb3-1";
nvidia,boost_cpu_freq = <800>;
pinctrl@3520000 {
status = "okay";
pinctrl-0 = <&tegra_xusb_padctl_pinmux_default>;
pinctrl-1 = <&vbus_en0_sfio_tristate_state>;
pinctrl-2 = <&vbus_en1_sfio_tristate_state>;
pinctrl-3 = <&vbus_en0_sfio_passthrough_state>;
pinctrl-4 = <&vbus_en1_sfio_passthrough_state>;
pinctrl-5 = <&vbus_en0_default_state>;
pinctrl-6 = <&vbus_en1_default_state>;
pinctrl-names = "default",
"vbus_en0_sfio_tristate", "vbus_en1_sfio_tristate",
"vbus_en0_sfio_passthrough", "vbus_en1_sfio_passthrough",
"vbus_en0_default", "vbus_en1_default";
tegra_xusb_padctl_pinmux_default: pinmux {
/* Quill does not support usb3-micro AB */
usb2-micro-AB {
nvidia,lanes = "otg-0";
nvidia,function = "xusb";
nvidia,port-cap = <TEGRA_PADCTL_PORT_OTG_CAP>;
nvidia,oc-pin = <0>;
usb2-std-A-port2 {
nvidia,lanes = "otg-1";
nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
nvidia,oc-pin = <1>;
usb3-std-A-port2 {
nvidia,lanes = "usb3-1";
e3325-usb3-std-A-HS {
nvidia,lanes = "otg-2";
status = "disabled";
e3325-usb3-std-A-SS {
quill-platforms/tegra186-quill-kernel-4.9.dtsi
xhci@3530000 {
compatible = "nvidia,tegra186-xhci";
reg = <0x0 0x03530000 0x0 0x8000>,
<0x0 0x03538000 0x0 0x1000>;
interrupts = <0 163 0x4>, <0 164 0x4>, <0 167 0x4>;
clocks = <&tegra_car TEGRA186_CLK_XUSB_HOST>,
<&tegra_car TEGRA186_CLK_XUSB_FALCON>,
<&tegra_car TEGRA186_CLK_XUSB_SS>,
<&tegra_car TEGRA186_CLK_XUSB_CORE_SS>,
<&tegra_car TEGRA186_CLK_CLK_M>, /* FIXME: HS souce */
<&tegra_car TEGRA186_CLK_XUSB_FS>,
<&tegra_car TEGRA186_CLK_PLLU>,
<&tegra_car TEGRA186_CLK_PLLE>;
clock-names = "xusb_host", "xusb_falcon_src", "xusb_ss", "xusb_ss_src", "xusb_hs_src",
"xusb_fs_src", "pll_u_480m", "clk_m", "pll_e";
/delete-property/ mboxes;
/delete-property/ mbox-names;
xusb_padctl: xusb_padctl@3520000 {
compatible = "nvidia,tegra18x-xusb-padctl";
reg = <0x0 0x3520000 0x0 0x1000>, <0x0 0x03540000 0x0 0x1000>;
reg-names = "padctl", "ao";
resets = <&tegra_car TEGRA186_RESET_XUSB_PADCTL>;
reset-names = "padctl";
status = "okay";
prod-settings {
#prod-cells = <4>;
mask-one-style;
prod_c_bias {
prod = <0 0x284 0x00000038 0x38>;
prod_c_hsic0 {
prod = <0 0x344 0x0000007f 0x2d>;
prod_c_utmi0 {
prod = <0 0x88 0x01fe0000 0xcc0000>;
prod_c_utmi1 {
prod = <0 0xc8 0x01fe0000 0xcc0000>;
prod_c_utmi2 {
prod = <0 0x108 0x01fe0000 0xcc0000>;
pads {
usb2 {
clocks = <&tegra_car TEGRA186_CLK_USB2_TRK>;
clock-names = "trk";
lanes {
usb2-0 {
status = "okay";
#phy-cells = <0>;
usb2-1 {
status = "okay";
#phy-cells = <0>;
usb2-2 {
status = "okay";
#phy-cells = <0>;
usb3 {
lanes {
usb3-0 {
status = "okay";
#phy-cells = <0>;
usb3-1 {
status = "okay";
#phy-cells = <0>;
usb3-2 {
status = "okay";
#phy-cells = <0>;
ports {
usb2-0 {
status = "okay";
mode = "otg";
usb2-1 {
status = "okay";
mode = "host";
vbus-supply = <&vdd_usb1_5v>;
usb2-2 {
mode = "host";
vbus-supply = <&vdd_usb2_5v>;
usb3-0 {
nvidia,usb2-companion = <2>;
usb3-1 {
nvidia,usb2-companion = <1>;
status = "okay";
usb3-2 {
xudc@3550000 {
nvidia,xusb-padctl = <&xusb_padctl>;
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>;
phy-names = "usb2";
xhci@3530000 {
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>;
phy-names = "usb2-1", "usb3-1";
plugin-manager {
fragment-e3325-xusb {
enable-override-on-all-matches;
ids = "<3310-1000-500";
odm-data = "enable-xusb-on-uphy-lane0";
override@0 {
target = <&xusb_padctl>;
_overlay_ {
ports {
usb2-2 {
status = "okay";
usb3-0 {
status = "okay";
override@1 {
target = <&{/xhci@3530000}>;
_overlay_ {
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>,
phy-names = "usb2-1", "usb2-2", "usb3-0", "usb3-1";
fragment-500-xusb-config {
ids = ">=3310-1000-500";
override@0 {
_overlay_ {
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>;
phy-names = "usb2-1", "usb3-0";
override@1 {
_overlay_ {
ports {
usb3-1 {
usb3-0 {
status = "okay";
fragment-500-e3325-pcie {
odm-data = "enable-pcie-on-uphy-lane0";
override@0 {
_overlay_ {
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>;
phy-names = "usb2-1";
Any clues about what could be going wrong?
