use python onnxsim simplify lib to modify onnx, and put modified onnx to tensorrt, get error.
if i modify the yolonet,such as add attention(SE,CA), what i should do to match the tensorrt.
Can you please help us with your modified onnx?
Related topics
| Use python onnxsim simplify lib to modify onnx, and put modified onnx to deepstream, get error | 3 | 874 | April 28, 2024 | |
| Unexpected output with onnx-TensorRT | 1 | 842 | August 30, 2021 | |
| Convert onnx to tensorrt error on Jetson Xavier. | 5 | 1857 | June 26, 2019 | |
| Onnx to torchrt convertion error | 3 | 1252 | February 8, 2022 | |
| Yolor to onnx to trt | 1 | 1663 | September 14, 2022 | |
| Issues while converting ONNX to TRT | 8 | 1525 | September 10, 2020 | |
| Fail to build inference engine of mobilevit model using tensorrt 8.2 | 6 | 1806 | May 24, 2022 | |
| Help converting a pytorch model to TensorRT | 5 | 3197 | July 22, 2020 | |
| Onnx -> tensorrt fp32 conversion performance degradation different outputs | 4 | 2386 | November 29, 2022 | |
| Error when converting from ONNX model to Tensorrt | 2 | 897 | August 16, 2023 |
