I would like to use Tensorflow ssd model in Deepstream.
However, I found only caffe model can be used in Deepstream from documentation. The model file defined in the config is:
model-file | The path to the caffemodel file. Not required if the model cache file is identified. | A string identifying the model file path. | model-file=/home/ubuntu/gie.caffemodel
Can you provide an idea how to inference TF SSD model with Deepstream? In the future, will Deepstream have more models?
Hi Wayne, thank you for the reply. After looking over more documentation, I got more questions
Since Jeston Deepstream is version 1.5, so I looked over the Deepstream2.0 for Tesla, I still cannot find an example of implementing TRT and iPlugin. I guess there’s no example for TRT right now. For now, I used Gstreamer and opencv to infer my TF ssd model, but it’s really slow.
(1)
Will the encoding/decoding preform faster to use Deepstream instead of Gstreamer pipeline? (I guess they are same because Deepstream wrapped Gstreamer?)
(2)
Will Ds2.0 for Jetson have example for TRT engine implement?
(3)
For now , can you provide any information/link that can give me an idea of making the iPlugin for unsupported layer for TF model? (I want to change to use TRT to infer my model)
(4)
My basic idea is:
a) Gstreamer —> get frame or Deepstream -> get frame
b) My frozen TF model -> uff model
c) Create iplugin for unsupported layers
d) b+c -> TRT engine
e) infer TR engine (maybe in Deepstream)
Is this correct?
(1)
If your gstreamer pipeline use HW decode/encode, performance will be same.
(2)
Yes, but currently you can use appsink + TRT engine directly.
(3)
(4)
My basic idea is:
Is this correct?
