I’m trying to use shared memory in a device function but I get the message:
SHARED attribute ignored on dummy argument totals_shared
and then:
Error 3 Internal compiler error. Unexpected runtime function call 0
The shared memory is declared properly in the kernel (size known at compile time) and passed as reference to the function, I have tried all different ways to declare the shared memory, but I don’t seem to be able to get around this problem.
Dummy arguments can’t have the shared attribute, so you’ll need to remove it from the declarations in the Multigrid function. You’ll still be using shared memory since you pass in the addresses of the shared arrays so the code should function as expected.
In this case, the message is coming from the NVIDIA back end compiler. Most likely we’re presenting it with some intermediate code it doesn’t like. Though, I’d need a reproducing example to understand what “function call 0” means.
Well this si the function giving all the trouble… I guess is still the same issue. I’m programming Sean Baxter’s scan and radix sort subroutines in CUDA Fortran, I guess is still the problem with shared memory declaration?
type integer2
integer :: x
integer :: y
end type
attributes(device) type(integer2) function Multiscan(tid, x, reduction_shared, totals_shared)
integer :: tid
integer :: x
integer :: warp, lane, i, sum, offset
integer :: total, totalsSum
type(integer2) :: result
integer,volatile, dimension(:) :: reduction_shared!(SCANSIZE)!(*)!(:)!(3256)!(ScanSize)
integer,volatile, dimension(:) :: totals_shared!((*)! (48)!(NUM_WARPS + NUM_WARPS/2)
integer, volatile :: s, s2 !we have a problem here in the translation of
warp = tid / WARP_SIZE ! check this one for fortran charac.
lane = IAND((WARP_SIZE - 1), tid) + 1 !in fortran so we are starting in 1; in c: (WARP_SIZE - 1) & tid
s = SCANSTRIDE * warp + lane + WARP_SIZE / 2 !index/pointer
reduction_shared(s - 16) = 0 !The first 32 position will be filled with zeros
reduction_shared(s) = x !And now only the first 16 will...
!! Run inclusive scan on each warp's data.
sum = x
!CUDA Fortran compiler is suppoused to unroll the loop for us...
do i = 1, LOG_WARP_SIZE
offset = ISHFT(1, i-1)!1 << (i - 1)
sum = sum + reduction_shared(s-offset)
reduction_shared(s) = 0
end do
!! Synchronize to make all totals available to the reduction code
call syncthreads()
if(tid < NUM_WARPS)then
!! Grab the block total for the tid'th block. This is the last element
!! in the block's scanned sequence. This operation avoids bank
!! conflicts.
total = reduction_shared(ScanStride* tid + WARP_SIZE/2 + WARP_SIZE ) !- 1) !this -1 may be eliminated
totals_shared(tid) = 0
s2 = NUM_WARPS / 2 + tid
totalsSum = total
totals_shared(s2) = total
!! Compiler shoud unroll this one
do i = 1, LOG_NUM_WARPS
totalsSum = totalsSum + totals_shared(s2-offset)
totals_shared(s2) = totalsSum
end do
!! Subtract total from totalsSum for an exclusive scan.
totals_shared(tid) = totalsSum - total
end if
!! Synchronize to make the block scan available to all warps
call syncthreads()
sum = sum + totals_shared(warp)
total = totals_shared(NUM_WARPS + NUM_WARPS / 2) !)- 1) !el - 1
result%x = sum
result%y = total
!!!!!!!!!!!!!!!!!!!!! and return...
Multiscan = result
end function Multiscan
Ok the problem seem to be using the ISHFT bit intrinsic, any reason for that?
According to the CUDA Fortran reference is a perfectly valid call…
integer ishft(integer, integer)…
It is relatevely easy to sustitue as I use to calculate multiples of 2 … but bit intrinsics are fast…I would like to use them…
Yep, it’s the ISHFT. CUDA Fortran does support ISHFT, but currently only if the “shift” argument is a constant. In this case, ISHFT is inlined but when it’s a variable, a call is emitted.
I asked engineering and they do have these on their TODO list but it was pushed to a lower priority (you’re the first to ask for these). I added a report (TPR#18883) to help track this and the other missing elemental functions.
Any other bit intrinsics not supported?.. I kind of need to know because I’m programming a Radix Sort on CUDA Fortran and I will make heavy use of all of them.
It will be the same for all of them (btest, iand, ibclr, ibits, ibset, ieor, ior, ishft, ishftc, not) since we don’t have the GPU run time device routine. If the intrinsic gets inlined, then it’s not a problem.
Word from engineering is that they’ll have “btest”, “iand”, “ibclr”, “ibset”, “ieor”, and “iand” into 12.9. Granted, I haven’t verified it myself, but that’s the word.
I will like to know if its possible to copy data from one shared array to another? In my code I passed two fixed size shared arrays to a device subroutine in which I copy some of potions of the array from one to another, something like:
sXconf(j1,:,:) = spXconf(j1,:,:)
where j1 is the threadid, the code compiles well but at runtime I get a memcpy error which using cuda-memcheck I get the following:
========= Invalid __global__ write of size 8
========= at 0x00001098 in /home/godfred/bio/Godfred/papers/2014/qmc/Codes/CUDA4-5/host_subs_m.CUF:798:host_subs_m_d_pmetropolis_
========= by thread (0,0,0) in block (0,0,0)
========= Address 0x3f4d77f200000001 is misaligned
========= Device Frame:/home/godfred/bio/Godfred/papers/2014/qmc/Codes/CUDA4-5/host_subs_m.CUF:1080:host_subs_m_kernel1_ (host_subs_m_kernel1_ : 0x2ce0)
========= Saved host backtrace up to driver entry point at kernel launch time
========= Host Frame:/usr/lib64/libcuda.so.1 (cuLaunchKernel + 0x2c5) [0x14ad95]
========= Host Frame:/state/partition1/pgitest/linux86-64/2015/cuda/6.5/lib64/libcudart.so.6.5 [0xf5d8]
========= Host Frame:/state/partition1/pgitest/linux86-64/2015/cuda/6.5/lib64/libcudart.so.6.5 (cudaLaunch + 0x143) [0x36833]
========= Host Frame:./gpuqmc [0xb5bc]
========= Host Frame:./gpuqmc [0xf239]
========= Host Frame:./gpuqmc [0x4a14]
========= Host Frame:/lib64/libc.so.6 (__libc_start_main + 0xf4) [0x1d994]
========= Host Frame:./gpuqmc (malloc + 0x1ed) [0x4925]
========= Program hit cudaErrorLaunchFailure (error 4) due to "unspecified launch failure" on CUDA API call to cudaMemcpy.
========= Saved host backtrace up to driver entry point at error
========= Host Frame:/usr/lib64/libcuda.so.1 [0x2ef613]
========= Host Frame:/state/partition1/pgitest/linux86-64/2015/cuda/6.5/lib64/libcudart.so.6.5 (cudaMemcpy + 0x1df) [0x3370f]
========= Host Frame:/state/partition1/pgitest/linux86-64/15.7/lib/libcudafor.so [0x1a0d8]
========= Host Frame:/state/partition1/pgitest/linux86-64/15.7/lib/libcudafor.so (pgf90_dev_copyout + 0x58) [0x1a194]
========= Host Frame:./gpuqmc [0xf26b]
0: copyout Memcpy (host=0x200d00200, dev=0x1302080400, size=8) FAILED: 4(unspecified launch failure)
========= ERROR SUMMARY: 2 errors
where host_subs_m.CUF:798 refers to the line with the code above.
