Problem loading data to shared memory
I’d like to make use of shared memory in CUDA Fortran, but I get an error that I don’t understand.
I want to pass data from a 2-d array in global memory (X_global) to
a 1-d array in shared memory (X_shared).
Each element of the arrays is of type “float4” (that I defined in a separate
module).
attributes(global) subroutine steepest_kernell(X_global,Nmin,Npart)
integer, value :: Nmin, Npart
type(float4), device, dimension(Npart,Nmin) :: X_global
type(float4), shared, dimension(4) :: X_shared
X_shared(threadidx%x) = X_global(threadidx%x,blockidx%x)
end subroutine steepest_kernell
[\code]
But I get the following error when compiling:
[quote]
PGF90-S-0000-Internal compiler error. unsupported operation     264 (module_minization_gpu.f90: 48)
  0 inform,   0 warnings,   2 severes, 0 fatal for steepest_kernell
/tmp/pgcudaforpcefTExtKbwL.gpu(23): error: expected an expression
2 errors detected in the compilation of "/tmp/pgnvdRdefbY8bwnCL.nv0".
PGF90-F-0000-Internal compiler error. pgnvd job exited with nonzero status code       0 (module_minization_gpu.f90: 48)
[\quote]
When I comping in emulation mode (-Mcuda=emu), everything works nicely.
Thanks,
Alberto.
Hi Alberto,
This means that the compiler is generating CPU code that has no GPU equivalent. We’re either generating the wrong code or not flagging a semantic error. Either way, it is a compiler error.
Can you please post the definition for ‘float4’? Also, which version of the compilers are you using?
Thanks,
Mat
Hi Matt,
I’m using the compiler pgi/64/10.8 and CUDA driver 3.1
The definition of float4:
type float4
	real :: x  !!! X-position
	real :: y  !!! Y-position
	real :: z  !!! Z-position
	real :: d  !!! diameter
end type float4
Alberto
Hi Alberto,
It looks like the compiler is trying to add memory copy optimization which isn’t supported on the GPU. I have sent our engineers TPR#17223 detailing the problem. The work around is to copy each member separately.
Thanks for the report!
Mat
  X_shared(threadidx%x)%x = X_global(threadidx%x,blockidx%x)%x
  X_shared(threadidx%x)%y = X_global(threadidx%x,blockidx%x)%y
  X_shared(threadidx%x)%z = X_global(threadidx%x,blockidx%x)%z
  X_shared(threadidx%x)%d = X_global(threadidx%x,blockidx%x)%d
Hi Mat,
When copying each component separately, the program does compile, but it doesn’t work properly.
In emulation mode it compiles “ok” and the results are also “ok”. But in the gpu (w/o emulation), it compiles “ok” (using the trick you mentioned), but the results are completely wrong.
Can you confirm me that the PGI Cuda-Fortran compiler does work with derived data types?
For example, this trivial program:
  real :: temp
  temp = X_shared(threadidx%x)%x + 1
  X_global(threadidx%x,blockidx%x)%x = temp
Works nicely in emulation mode, but in the gpu doesn’t add the “1” to the vector as it should.
Best regards,
Alberto.
Hi Alberto,
Can you please post a reproducing example? I tried with the code below but it works for me.
Thanks,
Mat
% cat test.cuf
module foo
use cudafor
type float4
end type float4
contains
  real :: temp
subroutine testme(Npart,Nmin)
  integer :: Npart
  integer :: Nmin
  type(float4), dimension(Npart,Nmin) :: X
  X%x = 1.0
  X_global=X
  call steepest_kernell<<<32,4>>>(X_global,Nmin,Npart)
  X = X_global
  print *, X(1:4,1)%x
end subroutine testme
end module foo
program test
   use foo
   call testme(4,32)
end program test
% pgf90 -fast test.cuf -V10.8; a.out
    2.000000        2.000000        2.000000        2.000000
Hi Mat,
Your example works “ok” for me as well.
After several hours I have detected where the error in my program comes from, but it seems very strange.
If I run the code below with -Mcuda=emu, I get the good results.
If I run the code without “emu”, the program gives wrong results.
But the really strange thing is that if I erase the first subroutine in the file (the one called “force_over_my_particule”), everything works without “emu”!
And this is even more strange, because as you can see this subroutine
is not called from the kernell! (it’s commented!)
Thanks a lot for your help!
Alberto.
module foo
use cudafor
type float4
end type float4
type float3
end type float3
contains
attributes(device) subroutine force_over_my_particule(X_shared,grad_shared,Npart)
type(float4), shared, dimension(8), intent(in) :: X_shared
type(float3), shared, dimension(8), intent(out) :: grad_shared
integer, value, intent(in) :: Npart
real :: force
real :: dx, dy, dz, r, invr
real :: diam, invdiam, ptemp, fr
integer :: i
type(float3) :: temp_grad
temp_grad%x = 0. !! No olvidar el "punto" al final.
temp_grad%y = 0.
temp_grad%z = 0.
	do i=1,Npart
           dx = X_Shared(threadidx%x)%x - X_Shared(i)%x
           dx = dx-nint(dx)
	   dy = X_Shared(threadidx%x)%y - X_Shared(i)%y
	   dy = dy - nint(dy)
	   dz = X_Shared(threadidx%x)%z - X_Shared(i)%z
	   dz = dz - nint(dz)
	   r = sqrt(dx*dx+dy*dy+dz*dz)
	   invr = 1.0D0/r
	   diam = (X_Shared(threadidx%x)%d + X_Shared(i)%d)/2.0D0
           invdiam = 1.0D0/diam
           if ((r > 0) .AND. (r<diam)) then
              ptemp = (1.0D0- r * invdiam)
              fr= invdiam*invr*ptemp
              temp_grad%x = temp_grad%x - fr*dx
              temp_grad%y = temp_grad%y - fr*dy
	      temp_grad%z = temp_grad%z - fr*dz
           end if
	enddo
grad_shared(threadidx%x)%x=temp_grad%x
grad_shared(threadidx%x)%y=temp_grad%y
grad_shared(threadidx%x)%z=temp_grad%z
end subroutine force_over_my_particule
attributes(global) subroutine steepest_kernell(X_global,Nmin,Npart,step_size)
  real, value :: step_size
  type(float4), shared, dimension(8) :: X_shared
  type(float3), shared, dimension(8) :: grad_shared
  !!! Copy to shared memory
  call syncthreads()
  !!! Compute the gradient
  grad_shared(threadidx%x)%x = step_size
  grad_shared(threadidx%x)%y = step_size
  grad_shared(threadidx%x)%z = step_size
!  call force_over_my_particule(X_shared,grad_shared,Npart)
  !!! end compute gradient
  call syncthreads()
  temp%x =  X_shared(threadidx%x)%x - step_size*grad_shared(threadidx%x)%x
  temp%y =  X_shared(threadidx%x)%y - step_size*grad_shared(threadidx%x)%y
  temp%z =  X_shared(threadidx%x)%z - step_size*grad_shared(threadidx%x)%z
  call syncthreads()
  X_global(threadidx%x,blockidx%x)%x = temp%x
  X_global(threadidx%x,blockidx%x)%y = temp%y
  X_global(threadidx%x,blockidx%x)%z = temp%z
subroutine minimize_steepest_gpu(Npart,Nmin,X0,Xf,step_size)
  integer :: Npart
  integer :: Nmin
  real :: step_size
  type(float4), dimension(Npart,Nmin) :: X0, Xf
  X_global=X0
  call steepest_kernell<<<Nmin,Npart>>>(X_global,Nmin,Npart,step_size)
  Xf = X_global
end subroutine minimize_steepest_gpu
subroutine initialize_positions(X0)
   type(float4), dimension(:,:), intent(inout) :: X0
   integer :: i,j
   real :: ran
   do i=1, size(X0(1,:))
      do j=1,size(X0(:,1))
	   call random_number(ran)
	   X0(j,i)%x = ran-0.5
	   X0(j,i)%y = ran-0.5
	   X0(j,i)%z = 0
      enddo
   enddo
end subroutine initialize_positions
subroutine initialize_diameters(X0,r,PHI)
  real, intent(in) :: r,PHI
  real, parameter :: PI=3.14159265358979D0
  real :: d1,d2
  integer :: npart, nmin, i, j
  nmin = size(X0(1,:))
  npart = size(X0(:,1))
  d1 = sqrt(8*PHI/(PI*npart*(1+r*r)))
  d2 = d1*r
  do i=1,npart
     if (i<=npart/2) then
        X0(i,:)%d = d1
     else
        X0(i,:)%d = d2
     end if
  end do
end subroutine initialize_diameters
end module foo
program test
use foo
integer, parameter :: Nmin = 1
integer, parameter :: Npart = 8
real,parameter :: step_size = 1.0
type(float4), dimension(Npart,Nmin) :: X0, Xf  !!! Posiciones iniciales
real, parameter :: phi = 0.9  !!! Volume ration
real, parameter :: r = 1.4 !!! Diameter ratio
 call initialize_positions(X0)
 call initialize_diameters(X0,r,phi)
write(*,*) 'x0'
write(*,*) X0(:,1)
   call minimize_steepest_gpu(Npart,Nmin,X0,Xf,step_size)
write(*,*) 'xf'
write(*,*), Xf(:,1)
end program test
Hi Alberto,
I suspect something else is wrong since when I run your program with and without -Mcuda=emu, I get the same results. This is true if I leave force_over_my_particule commented out, remove the function altogether or include the call.
Could you please add the following error checking code just after your kernel call? I’m wondering if it’s failing for some reason.
! Check for errors
    errCode = cudaGetLastError()
    if (errCode .gt. 0) then
       print *, cudaGetErrorString(errCode)
       stop
    endif
Another possibility is that I’m getting the same wrong answers for both. Below are the results I’m getting. Can you please verify that they are correct?
% pgf90 alberto1.cuf -Mcuda=emu -V10.9 -o emu109.out
% pgf90 alberto1.cuf -Mcuda -V10.9 -o cuf109.out
% cuf109.out
 x0
   0.4079230      -0.3093079        0.000000       0.3111003
  -0.4328347       0.3000845        0.000000       0.3111003
   0.2973146       0.1368300        0.000000       0.3111003
   8.8782728E-02  -0.3409344        0.000000       0.3111003
  -0.1793523      -5.1823914E-02    0.000000       0.4355405
   0.1579502       0.1075459        0.000000       0.4355405
   0.2622637      -6.2520266E-02    0.000000       0.4355405
  -3.6130935E-02   0.2004157        0.000000       0.4355405
 xf
  -0.5920770       -1.309308       -1.000000       0.3111003
   -1.432835      -0.6999155       -1.000000       0.3111003
  -0.7026854      -0.8631700       -1.000000       0.3111003
  -0.9112173       -1.340934       -1.000000       0.3111003
   -1.179352       -1.051824       -1.000000       0.4355405
  -0.8420498      -0.8924541       -1.000000       0.4355405
  -0.7377363       -1.062520       -1.000000       0.4355405
   -1.036131      -0.7995843       -1.000000       0.4355405
% emu109.out
 x0
 xf
  • Mat
Hi Mat,
Thanks a lot for your response.
Your results are the correct ones.
I inserted the error checking lines, and indeed there’s an error:
errCode = 8
cudaGetErrorString(errCode) = “invalid device function”
The call “force_over_my_particule” is still commented.
Do you know what can be wrong?
Alberto.
Hi Mat,
I think I’ve found where things go wrong:
apparently it doesn’t like the representations of the numbers, i.e,
with “1.0D0” doesn’t work, but with “1.” does work.
Does this make any sense? I mean: why did it work before in the emulation
mode? and why it was saying “errCode=8”?
A.
Does your card support double precision? What NVIDIA CUDA driver do you have? If you don’t know, post the output from the PGI utility ‘pgaccelinfo’.
Note that “Error 8: invalid device function” means that your trying to run Compute capability (CC) 1.3 code on a device that only supports CC1.2 or earlier. Double precision was first added in CC13 devices.
Hi Mat,
Indeed, the card of my local machine is CC1.1
I’m sorry for this stupid error from me!
Alberto.
Alberto,
TPR 17223 - CUF: User code gives ICE unsupported
operation when copying a derived type
Has been corrected in th e11.0 release, which is available now.
thanks again for your submission.
regards,
dave
