Hi, I’m here again. I’m working with FFT, and I need to make a simple code, but it’s not working. I need to transform with cufft a sin(x) and turn back, but between the transforms, I need to multiply by 2 the result so that, when I turn back the result with the inverse transfomr, I’ll recive 2sin(x) for example. With the fftw.h, I just multiply by 2 my d_signal[i] and when I turn back, I have 2sin(x), but I used to work with the complex.h. Any idea? Thanks.
# define SIGNAL_SIZE 64
# define PI acos(-1.0)
# define x 2*PI/SIGNAL_SIZE
void runTest(int argc, char **argv)
printf("[simpleCUFFT] is starting...\n");
findCudaDevice(argc, (const char **)argv);
// Allocate host memory for the signal
cufftComplex *h_signal = (Complex *)malloc(sizeof(Complex) * SIGNAL_SIZE);
cufftComplex *h_reversed_signal = (Complex *)malloc(sizeof(Complex) * SIGNAL_SIZE);
// Initalize the memory for the signal
for (unsigned int i = 0; i < SIGNAL_SIZE; ++i)
h_signal[i].x = sin(i*x);
h_signal[i].y = 0;
cufftComplex *d_signal;
checkCudaErrors(cudaMalloc((void **)&d_signal, SIGNAL_SIZE*sizeof(cufftComplex)));
// Copy host memory to device
checkCudaErrors(cudaMemcpy(d_signal, h_signal, SIGNAL_SIZE*sizeof(cufftComplex),
cudaMemcpyHostToDevice));
cufftHandle plan;
checkCudaErrors(cufftPlan1d(&plan, SIGNAL_SIZE, CUFFT_C2C, 1));
// Transform signal and kernel
printf("Transforming signal cufftExecC2C\n");
checkCudaErrors(cufftExecC2C(plan, (cufftComplex *)d_signal, (cufftComplex *)d_signal, CUFFT_FORWARD));
getLastCudaError("Kernel execution failed [ ComplexPointwiseMulAndScale ]");
d_signal[i].x = 2*d_signal[i].x;
d_signal[i].y = 2*d_signal[i].y;
// Transform signal back
printf("Transforming signal back cufftExecC2C\n");
checkCudaErrors(cufftExecC2C(plan, (cufftComplex *)d_signal, (cufftComplex *)d_signal, CUFFT_INVERSE));
// Copy device memory to host
checkCudaErrors(cudaMemcpy(h_reversed_signal, d_signal, SIGNAL_SIZE*sizeof(cufftComplex),
cudaMemcpyDeviceToHost));
// check result
h_reversed_signal[i].x = h_reversed_signal[i].x / (float)SIGNAL_SIZE;
h_reversed_signal[i].y = h_reversed_signal[i].y/(float)SIGNAL_SIZE;
printf("first : %f %f after %f %f \n", h_signal[i].x, h_signal[i].y, h_reversed_signal[i].x, h_reversed_signal[i].y);
bool bTestResult = sdkCompareL2fe((float *)h_reversed_signal, (float *)h_signal, 2 * SIGNAL_SIZE, 1e-5f);
//Destroy CUFFT context
checkCudaErrors(cufftDestroy(plan));
// cleanup memory
free(h_signal);
free(h_reversed_signal);
checkCudaErrors(cudaFree(d_signal));
cudaDeviceReset();
// Pad data
int PadData(const Complex *signal, Complex **padded_signal, int signal_size,
const Complex *filter_kernel, Complex **padded_filter_kernel, int filter_kernel_size)
int minRadius = filter_kernel_size / 2;
int maxRadius = filter_kernel_size - minRadius;
int new_size = signal_size + maxRadius;
// Pad signal
Complex *new_data = (Complex *)malloc(sizeof(Complex) * new_size);
memcpy(new_data + 0, signal, signal_size * sizeof(Complex));
memset(new_data + signal_size, 0, (new_size - signal_size) * sizeof(Complex));
*padded_signal = new_data;
// Pad filter
memcpy(new_data + 0, filter_kernel + minRadius, maxRadius * sizeof(Complex));
memset(new_data + maxRadius, 0, (new_size - filter_kernel_size) * sizeof(Complex));
memcpy(new_data + new_size - minRadius, filter_kernel, minRadius * sizeof(Complex));
*padded_filter_kernel = new_data;
return new_size;
