@steveu May I ask one more question?
As you can see below, I set a breakpoint at the kernel name and the instructions following the pc are like this:
(cuda-gdb) list increment
12 std::cout << "\n";
13 }
14
15
16 __global__ void increment( int *a, int N )
17 {
18 int i = threadIdx.x;
19 if ( i < N )
20 a[ i ] = a[ i ] + 1;
21 }
(cuda-gdb) break increment
Breakpoint 1 at 0xb498: file vec_add.cu, line 17.
(cuda-gdb) r
Thread 1 "vec_add" hit Breakpoint 1, increment<<<(1,1,1),(1024,1,1)>>> (a=0x7fffd7a00000, N=1024) at vec_add.cu:18
cuda-gdb) x/10i $pc
=> 0x555555b3abf0 <_Z9incrementPii+240>: S2R R3, SR_TID.X
0x555555b3ac00 <_Z9incrementPii+256>: MOV R3, R3
0x555555b3ac10 <_Z9incrementPii+272>: MOV R3, R3
0x555555b3ac20 <_Z9incrementPii+288>: MOV R3, R3
0x555555b3ac30 <_Z9incrementPii+304>: ISETP.LT.AND P0, PT, R3, R4, PT
However, using cuobjdump, shows that there are more instructions before S2R
Function : _Z9incrementPii
.headerflags @"EF_CUDA_SM86 EF_CUDA_PTX_SM(EF_CUDA_SM86)"
/*0000*/ MOV R1, c[0x0][0x28] ; /* 0x00000a0000017a02 */
/* 0x003fde0000000f00 */
/*0010*/ MOV R8, c[0x0][0x118] ; /* 0x0000460000087a02 */
/*0020*/ MOV R9, c[0x0][0x11c] ; /* 0x0000470000097a02 */
/*0030*/ MOV R2, 0x160 ; /* 0x0000016000027802 */
/*0040*/ LDC.64 R2, c[0x0][R2] ; /* 0x0000000002027b82 */
/* 0x00321e0000000a00 */
/*0050*/ MOV R0, R2 ; /* 0x0000000200007202 */
/*0060*/ MOV R4, R3 ; /* 0x0000000300047202 */
/*0070*/ MOV R2, R0 ; /* 0x0000000000027202 */
/*0080*/ MOV R4, R4 ; /* 0x0000000400047202 */
/*0090*/ MOV R0, 0x168 ; /* 0x0000016800007802 */
/*00a0*/ LDC R0, c[0x0][R0] ; /* 0x0000000000007b82 */
/* 0x00321e0000000800 */
/*00b0*/ MOV R3, R0 ; /* 0x0000000000037202 */
/*00c0*/ MOV R2, R2 ; /* 0x0000000200027202 */
/*00d0*/ MOV R0, R4 ; /* 0x0000000400007202 */
/*00e0*/ MOV R4, R3 ; /* 0x0000000300047202 */
/*00f0*/ S2R R3, SR_TID.X ; /* 0x0000000000037919 */
/* 0x00321e0000002100 */
/*0100*/ MOV R3, R3 ; /* 0x0000000300037202 */
So, I want to know what happened to those instructions. Are they executed so far?
