I am writing an algorithm to run in GPU using cuda and my algorithm depend heavily in pointers.
I already test it in cpu and it runs perfectly. Whoever, when I started to convert it to cuda there was an error that I can’t run cudamalloc inside device function.
I am really disappoint because I must use cudamalloc in my algorithm.
1- Is there any idea how to solve this problem ?
2- Is there any way to use LIST in cuda because I had to write it in C by my self so I can replace cudamalloc with default LIST?
I also tried new and delete but still I need to call it from global function rather than device function.
Any idea ?
I really need your help guys.
I just read that I can use C++ class in Cuda.
I made this class :-
__device__ class ListClass
public:
__device__ ListClass()
list = new List;
__device__ ~ListClass()
private:
List* list;
I want to know List is now loaded into the global device memory or not ?
Can I call this class from any device function ?
Is any object of this class will not be destroyed until the end of the application ?
I got an error :-
error : calling a host function("operator new ") from a device function(“ListClass::ListClass”) is not allowed
Whoever, It was acceptable in the CUDA samples :-
template<class T>
class Vector : public Container<T> {
public:
// Constructor, data is allocated on the heap
// NOTE: This must be called from only one thread
__device__
Vector(int max_size) : m_top(-1) {
m_data = new T[max_size];
// Constructor, data uses preallocated buffer via placement new
__device__
Vector(int max_size, T* preallocated_buffer) : m_top(-1) {
m_data = new (preallocated_buffer) T[max_size];
// Destructor, data is freed
__device__
~Vector() {
if( m_data ) delete [] m_data;
__device__
virtual
void push(T e) {
if( m_data ) {
// Atomically increment the top idx
int idx = atomicAdd(&(this->m_top), 1);
m_data[idx+1] = e;
__device__
virtual
bool pop(T &e) {
if( m_data && m_top >= 0 ) {
// Atomically decrement the top idx
int idx = atomicAdd( &(this->m_top), -1 );
if( idx >= 0 ) {
e = m_data[idx];
return true;
return false;
private:
int m_size;
T* m_data;
int m_top;
Any idea ???
