Hi all,
I’m using the cuFFTt to solve the Poisson equation.
Here ,I have done the 2D discrete sine transform by cuFFTT and slove the Poisson equation.
But it’s not powerful enough.
When the matrix dimension comes to 2^12 x 2^12, it’s only fifth times faster than cpu.
But the cuFFT is 125 times faster than cpu when the vector length is 2^24.
I think the data communication have spent so many times in gpu computing.
(my enviroment : I7-4770, GTX-960 2G, ram 12G)
compile command: pgc++ -acc -ta=tesla -Minfo -Mcudalib=cufft
Question:
1.How can I improve my code?
2.Does there have discrete sine transform in CUDA library?
3.Can I use double precision in cuFFT?
Here’s my code:
Using cufft to do the discrete sine transform and solve the Poisson equation.
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <time.h>
#include <cufft.h>
#include "openacc.h"
void fast_poisson_solver_gpu(float *b, float *x, float *data2, float *data3, int Nx, int Ny, int Lx);
void Exact_Solution(float *u, int Nx);
void Exact_Source(float *b, int Nx);
float Error(float *x, float *u, int Nx);
void print_matrix(float *x, int N);
int main()
int p, Nx, Ny, Lx;
float *x, *u, *b, *data2, *data3;
clock_t t1, t2;
// Initialize the numbers of discrete points.
// Here we consider Nx = Ny.
printf(" Please input (Nx = 2^p - 1) p = ");
scanf("%d",&p);
Nx = pow(2, p) - 1;
Ny = Nx;
printf(" Nx = %d \n", Nx);
// Prepare the expanded length for discrete sine transform.
Lx = 2*Nx + 2 ;
// Create memory for solving Ax = b, where r = b-Ax is the residue.
// M is the total number of unknowns.
// Prepare for two dimensional unknown F
// where b is the one dimensional vector and
// F[i][j] = F[j+i*(N-1)];
b = (float *) malloc(Nx*Ny*sizeof(float));
x = (float *) malloc(Nx*Ny*sizeof(float));
// data2 : Prepare for dst.
// data3 : Prepare for complex value to data2 and do the cufft.
data2 = (float *) malloc(Lx*Ny*sizeof(float));
data3 = (float *) malloc(2*Lx*Ny*sizeof(float));
// Prepare for two dimensional unknowns U
// where u is the one dimensional vector and
// U[i][j] = u[j+i*(N-1)]
u = (float *) malloc(Nx*Ny*sizeof(float));
Exact_Solution(u, Nx);
Exact_Source(b, Nx);
t1 = clock();
fast_poisson_solver_gpu(b, x, data2, data3, Nx, Ny, Lx);
t2 = clock();
printf(" Fast Poisson Solver: %f secs\n", 1.0*(t2-t1)/CLOCKS_PER_SEC);
printf(" For N = %d error = %e \n", Nx, Error(x, u, Nx));
/* printf(" \n \n");
printf(" u matrix \n");
print_matrix(u, Nx);
printf(" \n \n");
printf(" x matrix \n");
print_matrix(x, Nx);
*/ return 0;
int i, j;
for(i=0;i<N;i++)
for (j=0;j<N;j++) printf(" %f ", x[N*i+j]);
printf("\n");
// put the exact solution
int i, j;
float x, y, h;
h = 1.0/(Nx+1);
for(i=0;i<Nx;++i)
x = (i + 1)*h;
for(j=0;j<Nx;++j)
//k = j + i*(N-1);
y = (j + 1)*h;
u[Nx*i+j] = sin(M_PI*x)*sin(2*M_PI*y);
int i,j;
float x, y, h;
h = 1.0/(Nx+1);
for(i=0;i<Nx;++i)
x = (i+1)*h;
for(j=0;j<Nx;++j)
//k = j + i*(N-1);
y = (j+1)*h;
b[Nx*i+j] = -(1.0+4.0)*h*h*M_PI*M_PI*sin(M_PI*x)*sin(2*M_PI*y);
// return max_i |x[i] - u[i]|
int i, j;
float v, e;
v = 0.0;
for(i=0;i<Nx;++i)
for(j=0;j<Nx;j++)
e = fabs(x[Nx*i+j] - u[Nx*i+j]);
if(e > v) v = e;
return v;
void expand_data(float *data, float *data2, int Nx, int Ny, int Lx)
// expand data to 2N + 2 length
#pragma acc data copyin(data[0:Nx*Ny]), copyout(data2[0:Lx*Ny])
#pragma acc parallel loop independent
for(int i=0;i<Ny;i++)
data2[Lx*i] = data2[Lx*i+Nx+1] = 0.0;
#pragma acc loop independent
for(int j=0;j<Nx;j++)
data2[Lx*i+j+1] = data[Nx*i+j];
data2[Lx*i+Nx+j+2] = -1.0*data[Nx*i+Nx-1-j];
void expand_idata(float *data2, float *data3, int Nx, int Ny, int Lx)
#pragma acc data copyin(data2[0:Lx*Ny]), copyout(data3[0:2*Lx*Ny])
for (int i=0;i<Ny;i++)
for (int j=0;j<Lx;j++)
data3[2*Lx*i+2*j] = data2[Lx*i+j];
data3[2*Lx*i+2*j+1] = 0.0;
extern "C" void cuda_fft(float *d_data, int Lx, int Ny, void *stream)
cufftHandle plan;
cufftPlan1d(&plan, Lx, CUFFT_C2C, Ny);
cufftSetStream(plan, (cudaStream_t)stream);
cufftExecC2C(plan, (cufftComplex*)d_data, (cufftComplex*)d_data,CUFFT_FORWARD);
cufftDestroy(plan);
void fdst_gpu(float *data, float *data2, float *data3, int Nx, int Ny, int Lx)
float s;
s = sqrt(2.0/(Nx+1));
expand_data(data, data2, Nx, Ny, Lx);
expand_idata(data2, data3, Nx, Ny, Lx);
#pragma acc data copy(data3[0:2*Lx*Ny])
// Copy data to device at start of region and back to host and end of region
// Inside this region the device data pointer will be used
#pragma acc host_data use_device(data3)
void *stream = acc_get_cuda_stream(acc_async_sync);
cuda_fft(data3, Lx, Ny, stream);
#pragma acc data copyin(data3[0:2*Lx*Ny]), copyout(data[0:Nx*Ny])
for (int j=0;j<Nx;j++) data[Nx*i+j] = -1.0*s*data3[2*Lx*i+2*j+3]/2;
void transpose(float *data_in, float *data_out, int Nx, int Ny)
int i, j;
#pragma acc data copyin(data_in[0:Nx*Ny]), copyout(data_out[0:Ny*Nx])
for(i=0;i<Ny;i++)
for(j=0;j<Nx;j++)
data_out[i+j*Ny] = data_in[i*Nx+j];
int i, j;
float h, *lamda, *temp;
temp = (float *) malloc(Nx*Ny*sizeof(float));
lamda = (float *) malloc(Nx*sizeof(float));
h = 1.0/(Nx+1);
#pragma acc data copyout(lamda[0:Nx])
for(i=0;i<Nx;i++)
lamda[i] = 2 - 2*cos((i+1)*M_PI*h);
fdst_gpu(b, data2, data3, Nx, Ny, Lx);
transpose(b, temp, Nx, Ny);
fdst_gpu(temp, data2, data3, Nx, Ny, Lx);
transpose(temp, b, Ny, Nx);
#pragma acc data copyin(b[0:Nx*Ny]), copyout(x[0:Nx*Ny])
for(i=0;i<Ny;i++)
for(j=0;j<Nx;j++)
x[Nx*i+j] = -b[Nx*i+j]/(lamda[i] + lamda[j]);
fdst_gpu(x, data2, data3, Nx, Ny, Lx);
transpose(x, temp, Nx, Ny);
transpose(temp, x, Ny, Nx);
