I am using the cufftPlanMany construct for doing a batched inverse transform (CUDA 3.1 on Centos 5.0)
/*IFFT*/
int rank[2] ={pix1,pix2};
int pix3 = pix1*pix2*n; //n = Batchsize
cufftHandle plan_backward;
/* Create a batched 2D plan */
cufftPlanMany(&plan_backward,2,rank,NULL,1,0,NULL,1,0,CUFFT_C2C,n);
/* Execute the transform out-of-place */
cufftExecC2C(plan_backward, f3_d, out1_d, CUFFT_INVERSE);
/* Destroy the CUFFT plan */
cufftDestroy(plan_backward);
/*Check values<--Debug*/
cufftComplex* out1h;
cudaMallocHost((void**) &out1h, sizeof(cufftComplex) * pix3);
cudaMemcpy(out1h, out1_d, sizeof(cufftComplex) * pix3, cudaMemcpyDeviceToHost);
for(size_t i = 0; i < pix3; ++i)
printf ( " xcout[%d] %le %f \n", i, out1h[i].x/400, out1h[i].y);
When I check my values, the inverse FFT is done only for the pix1*pix2 elements The remaining values are all zero.
Any idea what is wrong here??
Thanks in advance
/*IFFT*/
Thanks in advance
At a glance, everything seems ok. Have you tried copying and printing f3_d to make sure it is properly set up? That seems like the most likely source of error.
/*IFFT*/
Thanks in advance
/*IFFT*/
Thanks in advance
/*IFFT*/
Thanks in advance
