For running UDP streaming, please refer to Jetson Nano FAQ
Q: Is there an example for running UDP streaming?
You can try the setup and confirm it is working, and develop your use-case based on it.
running TCP streaming
Please share more information about your use-case. Do you use IP camera source? Or?
And the latest release is Jetpack 5.1.2. If you use previous version, please consider upgrade.
not support TCP streaming?
It looks to be a RTSP source. Please try the command on Orin Nano and check if you see video preview:
$ DISPLAY=:0 gst-launch-1.0 uridecodebin uri='rtsp://192.168.2.105:554/12' ! nvvidconv ! video/x-raw ! xvimagesink sync=0
it is ok,thank you
Hi,this can receive uvc streaming?
For UVC streaming, do you mean you use USB camera sources?
yes,usb
Is it OK?
Please refer to steps in Jetson AGX Orin FAQ
Q: I have a USB camera. How can I launch it on AGX Orin?
The capability of each USB camera is different. You would need to check the capability and set to gstreamer command accordingly. Please follow the steps in FAQ and try.
