I have Orin Nano developer kit and I’ve been trying to use a camera imx568c on Orin Nano with MIPI-CSI-2 by using the repo below.
Jetson 5.1.2
R35 (release), REVISION: 4.1
first I did quicksetup with the instructions. Setup completed and no error seen. I can see the camera but I think it shows the wrong model for the camera
v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
vi-output, imx219 10-0010 (platform:tegra-capture-vi:2):
/dev/video0
My camera dtsi configuration is below.
* Copyright (c) 2023, Vision Components GmbH. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <dt-bindings/media/camera.h>
// Driver Configuration for NVIDIA Jetson Orin Nano on NVIDIA Jetson Orin Nano Developer Kit
#define VC_MIPI_CAM_1 1 // 1: Enabled, 0: Disabled (serial_a => CSI Port 0 => VI Stream 0)
#define VC_MIPI_CAM_0 0 // 1: Enabled, 0: Disabled (serial_c => CSI Port 2 => VI Stream 2)
// Supported number of lanes
// 1 | OV7251, IMX296, IMX297
// 2 | OV9281, IMX264, IMX265
// 2,4 | IMX178, IMX183, IMX226, IMX250, IMX252, IMX273, IMX290, IMX327, IMX335, IMX392,
// | IMX412, IMX415, IMX568
#define VC_MIPI_LANES 2 // 1, 2, 4 Lanes
// Embedded Metadata Height
// 0 | IMX178, IMX183, IMX226, IMX250, IMX252, IMX264, IMX265, IMX273, IMX392, OV7251, OV9281
// 1 | IMX290, IMX327, IMX335, IMX415, IMX568
// 2 | IMX296, IMX297, IMX412
#define VC_MIPI_METADATA_H "1" // "0", "1", "2" Lines of meta data
// Sensor Manufacturer
// 1 | Sony Sensor (IMX)
// 2 | Omni Vision Sensor (OV)
#define VC_MIPI_MANUFACTURER 1
// GStreamer Support
// If you want to use GStreamer with nvarguscamerasrc you have to adjust this settings in the
// device tree below. The sections which have to be modified are marked by a comment.
// To find the correct parameter values please follow the instruction in the main README.md of
// this repository https://github.com/VC-MIPI-modules/vc_mipi_nvidia#gstreamer-support
#if VC_MIPI_LANES == 1
#define BUS_WIDTH 1
#define NUM_LANES "1"
#define NUM_CSI_LANES 2
#endif
#if VC_MIPI_LANES == 2
#define BUS_WIDTH 2
#define NUM_LANES "2"
#define NUM_CSI_LANES 4
#endif
#if VC_MIPI_LANES == 4
#define BUS_WIDTH 4
#define NUM_LANES "4"
#define NUM_CSI_LANES 8
#endif
#if VC_MIPI_CAM_1 == 1 && VC_MIPI_CAM_0 == 1
#define VC_MIPI_CAMERAS 2
#else
#define VC_MIPI_CAMERAS 1
#endif
tegra-capture-vi {
num-channels = <VC_MIPI_CAMERAS>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vc_vi_port0: port@0 {
reg = <0>;
vc_vi_in0: endpoint {
port-index = <1>;
bus-width = <BUS_WIDTH>;
remote-endpoint = <&vc_csi_out0>;
#endif
#if VC_MIPI_CAM_0 == 1
vc_vi_port1: port@1 {
reg = <1>;
vc_vi_in1: endpoint {
port-index = <2>;
remote-endpoint = <&vc_csi_out1>;
#endif
}; // ports
host1x@13e00000 {
nvcsi@15a00000 {
#size-cells = <0>;
vc_csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
vc_csi_chan0_port0: port@0 {
reg = <0>;
vc_csi_in0: endpoint@0 {
port-index = <1>;
remote-endpoint = <&vc_mipi_out0>;
vc_csi_chan0_port1: port@1 {
reg = <1>;
vc_csi_out0: endpoint@1 {
remote-endpoint = <&vc_vi_in0>;
#endif
vc_csi_chan1: channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
vc_csi_chan1_port0: port@0 {
reg = <0>;
vc_csi_in1: endpoint@2 {
port-index = <2>;
remote-endpoint = <&vc_mipi_out1>;
vc_csi_chan1_port1: port@1 {
reg = <1>;
vc_csi_out1: endpoint@3 {
remote-endpoint = <&vc_vi_in1>;
#endif
cam_i2cmux {
i2c@0 {
#if VC_MIPI_MANUFACTURER == 1
vc_mipi_cam0: vc_mipi@1a {
reg = <0x1a>;
#else
vc_mipi_cam0: vc_mipi@60 {
reg = <0x60>;
#endif
compatible = "nvidia,vc_mipi";
devnode = "video0";
use_sensor_mode_id = "false";
sensor_model = "vc_mipi";
num_lanes = NUM_LANES;
trigger_mode = "0";
io_mode = "0";
// you have to adjust this settings
physical_w = "6.773";
physical_h = "5.612";
// This node is needed by the Tegra framework.
// You don't have to change any settings if just want
// to use the V4L API.
mode0 {
tegra_sinterface = "serial_b";
embedded_metadata_height = VC_MIPI_METADATA_H;
readout_orientation = "0";
lane_polarity = "6";
// you have to adjust this settings.
active_l = "0";
active_t = "0";
active_w = "2472";
active_h = "2048";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
min_gain_val = "0"; // mdB
max_gain_val = "48000"; // mdB
step_gain_val = "1"; // mdB
default_gain = "0"; // mdB
min_exp_time = "1"; // us
max_exp_time = "1000000"; // us
step_exp_time = "1"; // us
default_exp_time = "10000"; // us
// For applications like argus_camera, there should
// be a minimal frame rate greater than zero!
min_framerate = "100"; // mHz
max_framerate = "60000"; // mHz
step_framerate = "100"; // mHz
default_framerate = "60000"; // mHz
gain_factor = "1000";
exposure_factor = "1000000";
framerate_factor = "1000";
inherent_gain = "1";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
line_length = "0";
phy_mode = "DPHY";
discontinuous_clk = "no";
mclk_khz = "24000";
pix_clk_hz = "215000000";
mclk_multiplier = "0.0"; // deprecated
cil_settletime = "0";
dpcm_enable = "false";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
vc_mipi_out0: endpoint {
port-index = <1>;
remote-endpoint = <&vc_csi_in0>;
#endif // VC_MIPI_CAM_1
i2c@1 {
vc_mipi_cam1: vc_mipi@1a {
reg = <0x1a>;
#else
vc_mipi_cam1: vc_mipi@60 {
reg = <0x60>;
#endif
devnode = "video1";
trigger_mode = "0";
io_mode = "0";
physical_h = "5.655";
mode0 {
tegra_sinterface = "serial_c";
lane_polarity = "0";
active_l = "0";
active_t = "0";
active_w = "2472";
active_h = "2048";
step_gain_val = "100"; // mdB
max_framerate = "57290"; // mHz
default_framerate = "57290"; // mHz
line_length = "0";
phy_mode = "DPHY";
mclk_khz = "24000";
pix_clk_hz = "600000000"; // 205000000 - 600000000 tested with IMX568
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
vc_mipi_out1: endpoint {
port-index = <2>;
remote-endpoint = <&vc_csi_in1>;
#endif // VC_MIPI_CAM_0
lens@vc_mipi {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "6.0";
f_number = "2.0";
aperture = "0.0";
tcp: tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <NUM_CSI_LANES>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
badge = "jakku_front_vc_mipi";
position = "front";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "vc_mipi 9-001a";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/vc_mipi@1a";
#else
devname = "vc_mipi 9-0060";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/vc_mipi@60";
#endif
cam_module0_drivernode1: drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens@vc_mipi/";
cam_module1: module1 {
badge = "jakku_rear_vc_mipi";
position = "rear";
orientation = "1";
cam_module1_drivernode0: drivernode0 {
devname = "vc_mipi 10-001a";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/vc_mipi@1a";
#else
devname = "vc_mipi 10-0060";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/vc_mipi@60";
#endif
cam_module1_drivernode1: drivernode1 {
#define CAM0_PWDN TEGRA234_MAIN_GPIO(H, 6)
#define CAM1_PWDN TEGRA234_MAIN_GPIO(AC, 0)
#define CAM_I2C_MUX TEGRA234_AON_GPIO(CC, 3)
cam_i2cmux {
status = "okay";
compatible = "i2c-mux-gpio";
#size-cells = <0>;
mux-gpios = <&tegra_aon_gpio CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
i2c-parent = <&cam_i2c>;
i2c@0 {
status = "okay";
reg = <0>;
#size-cells = <0>;
vc_mipi@1a {
#else
vc_mipi@60 {
#endif
reset-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
#endif
i2c@1 {
status = "okay";
reg = <1>;
#size-cells = <0>;
vc_mipi@1a {
#else
vc_mipi@60 {
#endif
reset-gpios = <&tegra_main_gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
#endif
gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_PWDN 0 CAM1_PWDN 0>;
label = "cam0-pwdn","cam1-pwdn";
v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'RG10' (10-bit Bayer RGRG/GBGB)
Size: Discrete 3280x2464
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 3280x1848
Interval: Discrete 0.036s (28.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1640x1232
Interval: Discrete 0.017s (60.000 fps)
this is dmesg
[ 509.046577] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #920955: comm dpkg: iget: checksum invalid
[ 509.060091] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #920955: comm dpkg: iget: checksum invalid
[ 525.105837] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #920955: comm dpkg: iget: checksum invalid
[ 525.254362] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #920955: comm dpkg: iget: checksum invalid
[ 601.668422] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #920955: comm dpkg: iget: checksum invalid
[ 601.679969] EXT4-fs error (device mmcblk1p1): ext4_lookup:1706: inode #920955: comm dpkg: iget: checksum invalid
[ 5415.167390] bwmgr API not supported
[ 5417.835568] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5417.848323] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5417.858831] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5417.866589] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 5417.877282] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5417.885015] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 5417.895891] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5420.651514] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5420.660677] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5420.671110] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5420.678842] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 5420.689512] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5420.697235] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 5420.708118] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5423.467267] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5423.476422] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5423.486985] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5423.494718] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 5423.505390] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5423.513105] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 5423.523945] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5426.283216] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5426.292372] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5426.302817] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5426.310534] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 5426.321238] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5426.328967] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 5426.339831] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 5429.099162] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 5429.108314] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 5429.119772] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5429.127508] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 5429.138191] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 5429.145914] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 5429.156949] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
I’ve tried the commands like
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=ov1080.raw -d /dev/video0
the command execution frozen until I hit ctrl-c and ov1080.raw is 0 byte
gstreamer
gst-launch-1.0 v4l2src ! videoconvert ! x264enc ! matroskamux ! filesink location=data.mkv
It is frozen until I hit ctrl-c and data.mkv cannot be opened by vlc also it’s size is 0 byte
I also tried vpc mipi demo
./vcmipidemo -ao 1000 -g 10
but it is black screen with 24.5mb size files
So, It looks it installed wrong driver? because it says imx219 but I’m sure my camera imx568c
