IMX568c Camera does not open in Jetson Orin Nano
You can also see the issue under the camera driver repo.
Some links are shortened because of the link limit.
I tried setting up the driver for IMX568c camera but keep getting error or black image.
Here are the steps I followed:
In x86 ubuntu 20.08 host;
1- Clone your driver repo
2- Switch to jetson-orin-nano branch
3- Run ./quickstart.sh
4- Edit the device tree for imx568c as
 * Copyright (c) 2023, Vision Components GmbH.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <dt-bindings/media/camera.h>
//  Driver Configuration for NVIDIA Jetson Orin Nano on NVIDIA Jetson Orin Nano Developer Kit
#define VC_MIPI_CAM_1       1   // 1: Enabled, 0: Disabled  (serial_a => CSI Port 0 => VI Stream 0)
#define VC_MIPI_CAM_0       1   // 1: Enabled, 0: Disabled  (serial_c => CSI Port 2 => VI Stream 2)
//  Supported number of lanes
//  1   | OV7251, IMX296, IMX297
//  2   | OV9281, IMX264, IMX265
//  2,4 | IMX178, IMX183, IMX226, IMX250, IMX252, IMX273, IMX290, IMX327, IMX335, IMX392,
//      | IMX412, IMX415, IMX568
#define VC_MIPI_LANES       2   // 1, 2, 4 Lanes
//  Embedded Metadata Height
//  0   | IMX178, IMX183, IMX226, IMX250, IMX252, IMX264, IMX265, IMX273, IMX392, OV7251, OV9281
//  1   | IMX290, IMX327, IMX335, IMX415, IMX462
//  2   | IMX296, IMX297, IMX412
//  4   | IMX565, IMX566, IMX567, IMX568
#define VC_MIPI_METADATA_H  "4" // "0", "1", "2", "4" Lines of meta data
//   Sensor Manufacturer
//   1  | Sony Sensor (IMX)
//   2  | Omni Vision Sensor (OV)
#define VC_MIPI_MANUFACTURER 1
//  GStreamer Support
//  If you want to use GStreamer with nvarguscamerasrc you have to adjust this settings in the
//  device tree below. The sections which have to be modified are marked by a comment.
//  To find the correct parameter values please follow the instruction in the main README.md of
#if VC_MIPI_LANES == 1
    #define BUS_WIDTH 1
    #define NUM_LANES "1"
    #define NUM_CSI_LANES 2
	#define PIX_CLK_HZ "150000000"
#endif
#if VC_MIPI_LANES == 2
    #define BUS_WIDTH 2
    #define NUM_LANES "2"
    #define NUM_CSI_LANES 4
	#define PIX_CLK_HZ "300000000"
#endif
#if VC_MIPI_LANES == 4
    #define BUS_WIDTH 4
    #define NUM_LANES "4"
    #define NUM_CSI_LANES 8
	#define PIX_CLK_HZ "600000000"
#endif
#if VC_MIPI_CAM_1 == 1 && VC_MIPI_CAM_0 == 1
    #define VC_MIPI_CAMERAS 2
#else
    #define VC_MIPI_CAMERAS 1
#endif
	tegra-capture-vi  {
		num-channels = <VC_MIPI_CAMERAS>;
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			vc_vi_port0: port@0 {
				reg = <0>;
				vc_vi_in0: endpoint {
					port-index = <0>;
					bus-width = <BUS_WIDTH>;
					remote-endpoint = <&vc_csi_out0>;
#endif
#if VC_MIPI_CAM_0 == 1
			vc_vi_port1: port@1 {
				reg = <1>;
				vc_vi_in1: endpoint {
					port-index = <2>;
					remote-endpoint = <&vc_csi_out1>;
#endif
		}; // ports
	host1x@13e00000 {
		nvcsi@15a00000 {
			#size-cells = <0>;
			vc_csi_chan0: channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					vc_csi_chan0_port0: port@0 {
						reg = <0>;
						vc_csi_in0: endpoint@0 {
							port-index = <0>;
							remote-endpoint = <&vc_mipi_out0>;
					vc_csi_chan0_port1: port@1 {
						reg = <1>;
						vc_csi_out0: endpoint@1 {
							remote-endpoint = <&vc_vi_in0>;
#endif
			vc_csi_chan1: channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					vc_csi_chan1_port0: port@0 {
						reg = <0>;
						vc_csi_in1: endpoint@2 {
							port-index = <2>;
							remote-endpoint = <&vc_mipi_out1>;
					vc_csi_chan1_port1: port@1 {
						reg = <1>;
						vc_csi_out1: endpoint@3 {
							remote-endpoint = <&vc_vi_in1>;
#endif
	cam_i2cmux {
		i2c@0 {
#if VC_MIPI_MANUFACTURER == 1
			vc_mipi_cam0: vc_mipi@1a {
				reg                     = <0x1a>;
#else
			vc_mipi_cam0: vc_mipi@60 {
				reg                     = <0x60>;
#endif
				compatible              = "nvidia,vc_mipi";
				devnode                 = "video0";
				use_sensor_mode_id      = "false";
				sensor_model            = "vc_mipi";
				num_lanes               = NUM_LANES;
				trigger_mode            = "0";
				io_mode                 = "0";
				// you have to adjust this settings
				physical_w              = "6.752";
				physical_h              = "5.612";
				// This node is needed by the Tegra framework.
				// You don't have to change any settings if just want
				// to use the V4L API.
				mode0 {
					tegra_sinterface         = "serial_a";
					embedded_metadata_height = VC_MIPI_METADATA_H;
					readout_orientation      = "0";
					lane_polarity            = "0";
					// you have to adjust this settings.
					active_l                 = "0";
					active_t                 = "0";
					active_w                 = "2464";
					active_h                 = "2048";
					mode_type                = "bayer";
					pixel_phase              = "rggb";
					csi_pixel_bit_depth      = "10";
					min_gain_val             = "0";         // mdB
					max_gain_val             = "48000";     // mdB
					step_gain_val            = "100";       // mdB
					default_gain             = "0";         // mdB
					min_exp_time             = "1";         // us
					max_exp_time             = "1000000";   // us
					step_exp_time            = "1";         // us
					default_exp_time         = "10000";     // us
					// For applications like argus_camera, there should
					// be a minimal frame rate greater than zero!
					min_framerate            = "100";       // mHz
					max_framerate            = "78800";     // mHz
					step_framerate           = "100";       // mHz
					default_framerate        = "60000";     // mHz
					gain_factor              = "1000";
					exposure_factor          = "1000000";
					framerate_factor         = "1000";
					inherent_gain            = "1";
					min_hdr_ratio            = "1";
					max_hdr_ratio            = "1";
					line_length              = "0";
					phy_mode                 = "DPHY";
					discontinuous_clk        = "no";
					mclk_khz                 = "24000";
					pix_clk_hz               = PIX_CLK_HZ;
					mclk_multiplier          = "0.0";		// deprecated
					cil_settletime           = "0";
					dpcm_enable              = "false";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						vc_mipi_out0: endpoint {
							port-index = <0>;
							remote-endpoint = <&vc_csi_in0>;
#endif // VC_MIPI_CAM_1
		i2c@1 {
			vc_mipi_cam1: vc_mipi@1a {
				reg                     = <0x1a>;
#else
			vc_mipi_cam1: vc_mipi@60 {
				reg                     = <0x60>;
#endif
				devnode                 = "video1";
				trigger_mode            = "0";
				io_mode                 = "0";
				mode0 {
					tegra_sinterface         = "serial_c";
					active_l                 = "0";
					active_t                 = "0";
					active_w                 = "2464";
					active_h                 = "2048";
					line_length              = "0";
					phy_mode                 = "DPHY";
					mclk_khz                 = "24000";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						vc_mipi_out1: endpoint {
							port-index = <2>;
							remote-endpoint = <&vc_csi_in1>;
#endif // VC_MIPI_CAM_0
	lens@vc_mipi {
		min_focus_distance  = "0.0";
		hyper_focal         = "0.0";
		focal_length        = "6.0";
		f_number            = "2.0";
		aperture            = "0.0";
	tcp: tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <NUM_CSI_LANES>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <240000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		modules {
			cam_module0: module0 {
				badge = "jakku_front_vc_mipi";
				position = "front";
				orientation = "1";
				cam_module0_drivernode0: drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "vc_mipi 9-001a";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/vc_mipi@1a";
#else
					devname = "vc_mipi 9-0060";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/vc_mipi@60";
#endif
				cam_module0_drivernode1: drivernode1 {
					pcl_id = "v4l2_lens";
					proc-device-tree = "/proc/device-tree/lens@vc_mipi/";
			cam_module1: module1 {
				badge = "jakku_rear_vc_mipi";
				position = "rear";
				orientation = "1";
				cam_module1_drivernode0: drivernode0 {
					devname = "vc_mipi 10-001a";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/vc_mipi@1a";
#else
					devname = "vc_mipi 10-0060";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/vc_mipi@60";
#endif
				cam_module1_drivernode1: drivernode1 {
#define CAM0_PWDN	TEGRA234_MAIN_GPIO(H, 6)
#define CAM1_PWDN	TEGRA234_MAIN_GPIO(AC, 0)
#define CAM_I2C_MUX 	TEGRA234_AON_GPIO(CC, 3)
	cam_i2cmux {
		status = "okay";
		compatible = "i2c-mux-gpio";
		#size-cells = <0>;
		mux-gpios = <&tegra_aon_gpio CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
		i2c-parent = <&cam_i2c>;
		i2c@0 {
			status = "okay";
			reg = <0>;
			#size-cells = <0>;
			vc_mipi@1a {
#else
			vc_mipi@60 {
#endif
				reset-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
#endif
		i2c@1 {
			status = "okay";
			reg = <1>;
			#size-cells = <0>;
			vc_mipi@1a {
#else
            		vc_mipi@60 {
#endif
				reset-gpios = <&tegra_main_gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
#endif
	gpio@2200000 {
		camera-control-output-low {
			gpio-hog;
			output-low;
			gpios = <CAM0_PWDN 0 CAM1_PWDN 0>;
			label = "cam0-pwdn","cam1-pwdn";
5- It fails at first with error 'md5sum: Jetson_Linux_R35.3.1_aarch64.tbz2: No such file or directory Jetson_Linux_R35.3.1_aarch64.tbz2: FAILED open or read md5sum: WARNING: 1 listed file could not be read'., so I download the necessary files to build/Xavier35.3.1/downloads/ for Jetson 35.3.1 from page https://developer.nvidia.com/embedded/jetson-linux-r3531
I opened the bash scripts, followed the flow and saw these in vc_mipi_nvidia/bin/config/L4T/R35.3.1.sh at 9-support-for-jetson-orin-nano · VC-MIPI-modules/vc_mipi_nvidia · GitHub. . But the url in the script is developer.nvidia.com/downloads/embedded/l4t/r35_release_v3.1 so changing url solves this issue
6- Run quickstart.sh again and this time it runs successfully in around 2 hours.
7- Go to /target and run $ sudo ./max_speed.sh
Demo Repo
I tried running the first 3 steps both on host and target
Rest is run only on target
1- Clone the demo repo github/VC-MIPI-modules/vc_mipi_demo
2- Run ./setup.sh --host
3- Run $ ./build.sh --all
4- Run # v4l2-ctl --set-fmt-video=pixelformat=RG10,width=3840,height=3040
I also tried setting it with 2464x2048 too.
5- I can see the device from v4l2-ctl --list-devices as
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
vi-output, vc_mipi 9-001a (platform:tegra-capture-vi:1):
/dev/video0
6- The output
 vc@nvidia:~$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
	Type: Video Capture
[0]: 'RG10' (10-bit Bayer RGRG/GBGB)
7- Also output
vc@nvidia:~$ v4l2-ctl -d /dev/video0 --all
Driver Info:
	Driver name      : tegra-video
	Card type        : vi-output, vc_mipi 9-001a
	Bus info         : platform:tegra-capture-vi:1
	Driver version   : 5.10.104
	Capabilities     : 0x84200001
		Video Capture
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x04200001
		Video Capture
		Streaming
		Extended Pix Format
Media Driver Info:
	Driver name      : tegra-camrtc-ca
	Model            : NVIDIA Tegra Video Input Device
	Serial           :
	Bus info         :
	Media version    : 5.10.104
	Hardware revision: 0x00000003 (3)
Interface Info:
	Type             : V4L Video
Entity Info:
	Name             : vi-output, vc_mipi 9-001a
	Function         : V4L2 I/O
	Pad 0x0100000a   : 0: Sink
	  Link 0x0200000f: from remote pad 0x1000003 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
Priority: 2
Video input : 0 (Camera 1: no power)
Format Video Capture:
	Width/Height      : 640/480
	Pixel Format      : 'YUYV'
	Field             : None
	Bytes per Line    : 1280
	Size Image        : 614400
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Limited Range)
	Flags             :
Selection Video Capture: crop, Left 0, Top 0, Width 640, Height 480, Flags:
Selection Video Output: crop, Left 0, Top 0, Width 640, Height 480, Flags:
Camera Controls
                     group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                    sensor_mode 0x009a2008 (int64)  : min=0 max=1 step=1 default=0 value=0 flags=slider
                           gain 0x009a2009 (int64)  : min=0 max=48000 step=100 default=0 value=0 flags=slider
                       exposure 0x009a200a (int64)  : min=1 max=148226464 step=1 default=10000 value=1 flags=slider
                     frame_rate 0x009a200b (int64)  : min=0 max=51778 step=1 default=0 value=100 flags=slider
                   trigger_mode 0x009a200e (int)    : min=0 max=7 step=1 default=0 value=0
                        io_mode 0x009a200f (int)    : min=0 max=5 step=1 default=0 value=0
                    black_level 0x009a2010 (int)    : min=0 max=100000 step=1 default=0 value=0
                 single_trigger 0x009a2011 (button) : flags=write-only, execute-on-write
           sensor_configuration 0x009a2032 (u32)    : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
         sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
      sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
                    bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
				0: 0 (0x0)
				1: 1 (0x1)
                override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
				0: 0 (0x0)
				1: 1 (0x1)
                   height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                     size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
				0: 1 (0x1)
				1: 65536 (0x10000)
				2: 131072 (0x20000)
               write_isp_format 0x009a2068 (int)    : min=1 max=1 step=1 default=1 value=1
       sensor_signal_properties 0x009a2069 (u32)    : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
        sensor_image_properties 0x009a206a (u32)    : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
      sensor_control_properties 0x009a206b (u32)    : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
              sensor_dv_timings 0x009a206c (u32)    : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
               low_latency_mode 0x009a206d (bool)   : default=0 value=0
               preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
                   sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=1 flags=read-only
7- Then I am trying different things to capture image but all of them either gets error or returns black image.
Possible problems might be:
  • Jetson 35.3.1 Driver files are outdated in your repo but I downloaded them manually and still does not work
  • My device tree file has something wrong but then would it be appeared under /dev
  • Something outdated in the bash scripts
Connect single camera?
Try connect to another port to verify.
