I want to compile the following program for testing -stdpar in the NVIDIA HPC SDK.
#include <iostream>
#include <vector>
#include <algorithm>
#include <numeric>
#include <execution>
#include <cmath>
int main()
constexpr auto n = 1000000000;
auto numbers = std::vector<float>(n);
std::iota(numbers.begin(), numbers.end(), 0);
std::transform(std::execution::par_unseq, numbers.begin(), numbers.end(), numbers.begin(),
[](auto a)
{ return std::sqrt(a); });
The CMakeLists.txt is as follows:
cmake_minimum_required(VERSION 3.20.0)
project(cpp_hpc LANGUAGES CXX CUDA)
find_package(CUDA 12.1 REQUIRED)
find_package(NVHPC REQUIRED PATHS "/opt/nvidia/hpc_sdk/Linux_x86_64/2023/cmake/")
add_executable(nvidia_hpc_test nvidia_hpc_test.cpp)
target_compile_options(nvidia_hpc_test PRIVATE -stdpar)
target_link_libraries(nvidia_hpc_test PRIVATE NVHPC::CUDA NVHPC::MATH)
Compilation results in linking error for all the cuda libraries.
Whereas compilation from directly invoking nvc++ from command line works without any extra linker arguments. All locations are added to the PATH and LD_LIBRARY_PATH environment variables.
Any help is highly appreciated.
