I have profiled some metrics for a kernel regex which is “-k ElecEw_Vd”. Now, when I want to import the results with “–summary per-kernel”, I see multiple instances
nbnxn_kernel_ElecEw_VdwLJFsw_F_cuda(cu_atomdata,cu_nbparam,Nbnxm::gpu_plist,bool), Block Size 64, Grid Size 3550, Device 0, 99 invocations
Section: Command line profiler metrics
Metric Name Metric Unit Minimum Maximum Average
dram__sectors_read.sum sector 94003.000000 207336.000000 97702.292929
dram__sectors_write.sum sector 14638.000000 33130.000000 25976.222222
sm__cycles_active.avg.pct_of_peak_sustained_elapsed % 91.110182 96.204656 94.053113
nbnxn_kernel_ElecEw_VdwLJFsw_F_cuda(cu_atomdata,cu_nbparam,Nbnxm::gpu_plist,bool), Block Size 64, Grid Size 3572, Device 0, 99 invocations
dram__sectors_read.sum sector 94047.000000 240262.000000 98858.282828
dram__sectors_write.sum sector 14671.000000 33208.000000 24987.060606
sm__cycles_active.avg.pct_of_peak_sustained_elapsed % 91.364360 96.112414 94.184479
Any comment on that?
