Using the background label of the primary model as input for the secondary model
Using the background label of the primary model as input for the secondary model, it was found that the primary model cannot output the background box, so the secondary model cannot be mounted. At present, I am using Tao’s Retinanet for testing on DGPU. The primary model uses 1024 * 576, while the secondary model uses 640 * 384, which is related to resolution.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Please describe which sample to use and how to reproduce it. Without reproduction steps and sample code, I can’t help you.
