I am trying to build a pipeline like this: Camera → getImage → TRTDetectionYolo → NVEnc-Encode to file.
When I launch this pipeline, it fails on CUDNN_STATUS_MAPPING_ERROR.
I am using latest TRT, latest Cuda + Cudnn, latest Nvidia Video Codec.
The problem is, that when I do Just Camera → getImage → TRTDetectionYolo. It works
and what I do this pipeline Camera → getImage → NVEnc-Encode to file It works.
So for some reason it can not run together. For TRTDetectionYolo I am using cudaHostRegister, but tried to use cudaHostAlloc and cudaMallocManaged but achieved same error.
The error is thrown by TRT->executeV2 method.
NvEnc uses NVEncoderCuda provided by Nvidia.
Can you see a reason, why executing TRT and NvEnc together is resulting in Cudnn Error in configure: 7 (CUDNN_STATUS_MAPPING_ERROR) ? Each encoder has its own cudaContext. TRT has its own cudaEngine. All is ran on same graphic.
[2020-08-21 10:51:28.872][encoder][error][thread 2784]: Encode frame fail error GetEncodedPacket : m_nvenc.nvEncLockBitstream(m_hEncoder, &lockBitstreamData) returned error 8 at ../../video-library/VideoLib/encoder/NvEncoder.cpp:493
[2020-08-21 10:51:28.872][trt][error][thread 2785]: ../rtSafe/safeContext.cpp (133) - Cudnn Error in configure: 7 (CUDNN_STATUS_MAPPING_ERROR)
[2020-08-21 10:51:28.873][trt][error][thread 2785]: FAILED_EXECUTION: std::exception
Edit: It fails even, when TRT is on GPU 0 and NvEnc on GPU 1.
Edit2: The initialize of the encoder is enough to cause this problem.
