Hi!
I’m using Fedora 13 x86_64 (on dell Vostro 1320 with GeForce 9300M GS) and I did the following things:
-installed cuda toolkit 3.2 and newest atistream
-changed variables in .bashrc to:
PATH=$PATH:/usr/local/cuda/bin
export PATH
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib64 //cuda path
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:~/ati-stream/lib/x86_64 //opencl_amd path
export LD_LIBRARY_PATH
export ATISTREAMSDKROOT="~/ati-stream"
export ATISTREAMSDKSAMPLESROOT="~/ati-stream/samples"
-downloaded OpenCL SDK, and linked */common/inc/CL to /usr/include/CL, I did not compile it because I don’t need to.
-put an icd for nvidia and 2 for ati into /etc/OpenCL/vendors/
and still after executing:
$ gcc t1.c -lOpenCL
I get:
/usr/bin/ld: cannot find -lOpenCL
collect2: ld returned 1 exit status
Did I miss something?
Source files are ok, because I can run and compile them at my university.
I have driver ver 260.19.12 downloaded from rpmfusion, not from nvidia, but it has OpenCL.so and CUDA works flawlessly.
Cheers,
Mike
