/usr/bin/ld: cannot find -lXi and some other errors
I tried to ‘make’ the sdk, but i get this output:
I’ve read that u have to install libGLUT, but the install says that there is already a newer version installed.
Also ld cannot find -lXi, i searched that on the internet, but only -lX11 exists. What can i do to fix this?
You check if a library is accesible by ld doing
ldconfig -p | grep libraryname
in your case
ldconfig -p | grep Xi
if not listed, then you need to install some lib-dev files not only the lib archives.
:ph34r:
By the way, I have this similar problem
$ glxinfo |grep NVIDIA
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
OpenGL version string: 2.1.2 NVIDIA 177.80
OpenGL shading language version string: 1.20 NVIDIA via Cg compiler
~/NVIDIA_CUDA_SDK/projects/simpleGL$ make
/usr/bin/ld: cannot find -lcutil
collect2: ld devolvió el estado de salida 1
make: *** [../../bin/linux/release/simpleGL] Error 1
---------------- edit
That was because Ihavent done make on the NVIDIA SDK root directory and trying to build directly one o the samples.
You have to install libxi (dev) and libxmu (dev)
External Media
how to i install them? apt-get install doesn’t find them…
install only serve for that and get dependencies, for search use apt-cache.
Try this:
$ apt-cache search libXi-dev
libxi-dev - X11 Input extension library (development headers)
$ apt-cache search libxmu-dev
libxmu-dev - X11 miscellaneous utility library (development headers)
libxmu-headers - X11 miscellaneous utility library headers
$ sudo apt-get install libxi-dev libxmu-dev
Answer yes if there is extra dependencies to get.
if apt-cache is not able to find them, perhaps is a problem about wich repos you have enabled, but first try the above.
THX!
Thanks, i made with your hints…
