I try to mount the jetson nano like an uvc gadget device to a a laptop but it doesn’t worked.
cd /sys/kernel/config/usb_gadget
sudo mkdir g1
mkdir: cannot create directory ‘g1’: Cannot allocate memory
dmesg:
[ 1316.660535] sysfs: cannot create duplicate filename ‘/devices/virtual/android_usb/android0’
[ 1316.669043] ------------[ cut here ]------------
[ 1316.673683] WARNING: CPU: 2 PID: 7446 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/fs/sysfs/dir.c:31 sysfs_warn_dup+0x68/0x88
[ 1316.685671] Modules linked in: fuse zram overlay spidev nvgpu bluedroid_pm ip_tables x_tables [last unloaded: v4l2loopback]
[ 1316.685786] CPU: 2 PID: 7446 Comm: mkdir Tainted: G W O 4.9.140-tegra #1
[ 1316.685797] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 1316.685809] task: ffffffc0ccd8e200 task.stack: ffffffc0f7c64000
[ 1316.685828] PC is at sysfs_warn_dup+0x68/0x88
[ 1316.685845] LR is at sysfs_warn_dup+0x68/0x88
[ 1316.685859] pc : [] lr : [] pstate: 40400145
[ 1316.685868] sp : ffffffc0f7c67a80
[ 1316.685878] x29: ffffffc0f7c67a80 x28: 00000000ffffffff
[ 1316.685907] x27: ffffffc0c8760700 x26: 0000000000000000
[ 1316.685932] x25: 0000000000000000 x24: 0000000000000000
[ 1316.685956] x23: 0000000000000000 x22: ffffffc0f4399700
[ 1316.685979] x21: ffffffc0f4eb23c0 x20: ffffff800948e710
[ 1316.686001] x19: ffffffc0f2c60000 x18: 0000000000000010
[ 1316.686024] x17: 0000000000000000 x16: 0000000000000000
[ 1316.686046] x15: ffffffffffffffff x14: 6c6175747269762f
[ 1316.686068] x13: 736563697665642f x12: 2720656d616e656c
[ 1316.686090] x11: 6966206574616369 x10: 0000000000000372
[ 1316.686113] x9 : 65726320746f6e6e x8 : ffffff80083d47b0
[ 1316.686135] x7 : ffffff8009e94358 x6 : ffffffc0fefe7bf0
[ 1316.686157] x5 : ffffffc0fefe7bf0 x4 : 0000000000000000
[ 1316.686179] x3 : ffffffc0fefed7f8 x2 : ffffffc0fefe7bf0
[ 1316.686201] x1 : ffffffc0ccd8e200 x0 : 000000000000004f
[ 1316.686232] —[ end trace 7578c5a09c1fa400 ]—
[ 1316.690868] Call trace:
[ 1316.690890] [] sysfs_warn_dup+0x68/0x88
[ 1316.690910] [] sysfs_create_dir_ns+0x9c/0xb0
[ 1316.690937] [] kobject_add_internal+0x98/0x348
[ 1316.690954] [] kobject_add+0x88/0xf0
[ 1316.690979] [] device_add+0xe8/0x5d8
[ 1316.690998] [] device_create_groups_vargs+0x124/0x130
[ 1316.691015] [] device_create+0x8c/0xa0
[ 1316.691038] [] gadgets_make+0x260/0x338
[ 1316.691056] [] configfs_mkdir+0x138/0x4b8
[ 1316.691079] [] vfs_mkdir2+0x13c/0x1e8
[ 1316.691093] [] SyS_mkdirat+0x88/0xf8
[ 1316.691113] [] el0_svc_naked+0x34/0x38
[ 1316.691274] kobject_add_internal failed for android0 with -EEXIST, don’t try to register things with the same name in the same directory
Could you help me ?
