Does anyone know how to setup Jetson TX1 device as UVC video device for Windows PC host? I tried to search for UVC and similar but there is so much information for UVC devices for TX1 host that I was not able to find anything useful. Any pointers would be greatly appreciated!
If you are referring to making the micro-USB connector switch to device mode and emulate being video via the “gadget” framework I recall a recent discussion that this would not allow isochronous mode (which is required by UVC). Can you be more specific about what you want? It would still be possible to stream video, just not as a gadget with isochronous mode.
We have TX1 (with ubuntu) and would like to connect it to Windows host PC as UVC device to act as web camera. Micro USB port (marked as USB0 on devkit) would be ok as well as any other means.
I think the USB3 controller in device mode of the TX1 does not support isochronous mode, but someone will have to verify if that is correct (I am not positive on that). Thus a hardware issue.
As mentioned before, someone will need to verify this: If the USB3 device mode hardware (and probably also USB2) is not able to support isochronous mode (basically a continuous uninterrupted data stream with some real time behavior), then it won’t be possible to be a standard UVC device. UVC requires isochronous mode. It looks like a TK1 supports a single isochronous mode device, while I think the TX1 and TX2 do not.
