I recently got my first Spark and love being able to run a bunch of bigger models like Qwen 3.5 122b - dense models sadly disappointed so far, though.
To reach higher quality/faster inference speed, I consider a second Spark to either run dense models with more t/s or at least run higher quality MoE models.
For those who made the upgrade: was it worth it for inferencing? I do some training but primarily use my Spark as inference server for a single model right now (Qwen 3.5 35b in FP8) via spark-vllm-docker.
Appreciate your responses – I tried digging through this forum but a lot of responses are either rather old or not conclusive.
I have an economical take about this: when you buy a single spark you’re basically wasting $1500
Because of the ConnectX-7 module you’re not using. 2 sparks will help you run larger MoE models and
help you increase TG but not 2x. For dense models and for training you’re going to experience linear returns and close to 2x increase in decode. But you’re always going to inevitably have the 273GB/s memory bandwidth limit at some point and while you scale your spark cluster out, you’re going at some point increase latency. To be more aware of the limits per model and cluster sizes check:
We’ve running new models every week there. Feel free to contribute.
After I got the first one I was fairly convinced I needed just a bit more speed and capacity than I got from a single unit so picked up #2 . It’s great to have capacity to run models like Minimax M2.5 with full context for coding. I feel like I get a lot more out of the system now, I don’t regret it.
Thanks! I’m very tempted! I fear I didn’t see any dual spark benchmarks for Qwen 3.5 27b yet. Would you be able to give it a pass if you have a moment? I can contribute the single model benchmark, even if the result is not that impressive.
If it wasn’t for @eugr spark-vllm-docker, I would’ve thrown my spark in the trash. Instead I bought a second one and I’m glad I did.
It’s true. You really need to buy at least two if you want the best value. One is good enough to run the newest diffusion models (like FLUX.2, for example, for which I wrote a custom fastsafetensors loader node), but a better use for these systems seems to be running bigger LLMs. I decided to buy a second one just for that. I knew about the memory bandwidth limitation, but I don’t really care that much. Just being able to run models like Qwen3.5-397B (in 4 bit) with acceptable performance makes it worth it. You really want that extra RAM for large models and the KV cache to maintain large context windows.
You will see a material increase, but it will still be relatively slow. Sparse MoE models like 3.5 122b run much better on this hardware.
AoE
March 9, 2026, 7:12pm
8
Having 2 allows me to run Qwen3.5-122B + Open WebUI + custom RAG (VL) + ComfyUI running all the time with good speed and good enough quality for a couple of concurrent users. It was not convenient to always have to switch model depending on the task at hand when we had only one.
That’e exactly where I am at
relc
March 10, 2026, 12:46pm
10
Also two here. They replicate quickly. I would say it depends on the budget. For research having a second one was a good choice.
I caved in and got a 2nd spark and that shiny qsfp cable. After some back and forth I got the clustering to work as expected and see the first pretty strong results – will play with a dense model tomorrow. Running with @eugr ’s amazing spark-vllm-docker and my own launch script.
Happy to hear people’s thought if there is any room for optimization on below vllm config:
vllm serve Intel/Qwen3.5-122B-A10B-int4-AutoRound \
--host 0.0.0.0 \
--port 8080 \
--gpu-memory-utilization 0.75 \
--load-format fastsafetensors \
--max-model-len 262144 \
--max-num-batched-tokens 16384 \
--enable-prefix-caching \
--enable-chunked-prefill \
--dtype auto \
--kv-cache-dtype auto \
--max-num-seqs 4 \
--trust-remote-code \
--chat-template unsloth.jinja \
--enable-auto-tool-choice \
--tool-call-parser qwen3_coder \
--reasoning-parser qwen3 \
--tensor-parallel-size 2 \
--distributed-executor-backend ray
llama-benchy --base-url ``http://0.0.0.0:8080/v1`` --model Intel/Qwen3.5-122B-A10B-int4-AutoRound --latency-mode api --pp 2048 --depth 0 4096 8192 16384 --tg 32 128 --concurrency 4
| model | test | t/s (total) | t/s (req) | peak t/s | peak t/s (req) | ttfr (ms) | est_ppt (ms) | e2e_ttft (ms) |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 (c4) | 3844.66 ± 12.06 | 1480.32 ± 723.55 | | | 1652.67 ± 580.82 | 1651.01 ± 580.82 | 1652.69 ± 580.81 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg32 (c4) | 58.57 ± 5.77 | 25.89 ± 9.03 | 126.33 ± 0.47 | 33.08 ± 1.76 | | | |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 (c4) | 3859.73 ± 7.42 | 1376.87 ± 411.81 | | | 1624.22 ± 456.37 | 1622.56 ± 456.37 | 1624.25 ± 456.37 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg128 (c4) | 100.31 ± 3.90 | 27.53 ± 2.63 | 137.33 ± 1.89 | 34.33 ± 0.47 | | | |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d4096 (c4) | 3957.67 ± 1.41 | 1070.41 ± 139.76 | | | 5828.54 ± 661.00 | 5826.88 ± 661.00 | 5828.57 ± 660.99 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg32 @ d4096 (c4) | 50.03 ± 0.11 | 27.59 ± 8.61 | 127.00 ± 0.00 | 32.96 ± 1.13 | | | |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d4096 (c4) | 3962.32 ± 3.63 | 1078.39 ± 128.43 | | | 5773.79 ± 622.38 | 5772.12 ± 622.38 | 5773.81 ± 622.36 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg128 @ d4096 (c4) | 88.80 ± 4.52 | 26.91 ± 3.06 | 133.33 ± 1.89 | 33.33 ± 0.47 | | | |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d8192 (c4) | 3913.24 ± 3.31 | 1205.56 ± 332.98 | | | 9028.30 ± 1932.91 | 9026.64 ± 1932.91 | 9028.32 ± 1932.89 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg32 @ d8192 (c4) | 21.71 ± 0.03 | 20.57 ± 10.77 | 123.00 ± 0.00 | 30.75 ± 0.43 | | | |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d8192 (c4) | 3908.68 ± 1.08 | 1204.45 ± 332.89 | | | 9037.00 ± 1936.03 | 9035.34 ± 1936.03 | 9037.02 ± 1936.02 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg128 @ d8192 (c4) | 55.24 ± 0.25 | 23.39 ± 5.89 | 124.00 ± 0.00 | 31.00 ± 0.00 | | | |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d16384 (c4) | 3743.54 ± 4.70 | 1141.74 ± 239.43 | | | 16779.10 ± 3039.37 | 16777.43 ± 3039.37 | 16779.12 ± 3039.35 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg32 @ d16384 (c4) | 14.14 ± 0.01 | 14.57 ± 9.98 | 116.00 ± 0.00 | 29.00 ± 0.00 | | | |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d16384 (c4) | 3732.94 ± 0.97 | 1138.42 ± 238.62 | | | 16827.29 ± 3046.99 | 16825.62 ± 3046.99 | 16827.31 ± 3046.97 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg128 @ d16384 (c4) | 40.82 ± 0.02 | 19.21 ± 6.57 | 116.00 ± 0.00 | 29.00 ± 0.00 | | | |
I really need to try the autoround version. Here’s what i’m getting with the FP8:
| model | test | t/s | peak t/s | ttfr (ms) | est_ppt (ms) | e2e_ttft (ms) |
| Qwen3.5-122B-A10B-FP8 | pp2048 | 3629.67 ± 6.27 | | 592.85 ± 14.20 | 512.61 ± 14.20 | 592.98 ± 14.22 |
| Qwen3.5-122B-A10B-FP8 | tg32 | 32.12 ± 0.08 | 33.16 ± 0.08 | | | |
| Qwen3.5-122B-A10B-FP8 | pp2048 @ d4096 | 3692.04 ± 18.91 | | 1596.89 ± 39.22 | 1516.65 ± 39.22 | 1597.02 ± 39.22 |
| Qwen3.5-122B-A10B-FP8 | tg32 @ d4096 | 32.44 ± 0.32 | 33.49 ± 0.33 | | | |
| Qwen3.5-122B-A10B-FP8 | pp2048 @ d8192 | 3558.71 ± 7.49 | | 2669.43 ± 24.52 | 2589.19 ± 24.52 | 2669.53 ± 24.53 |
| Qwen3.5-122B-A10B-FP8 | tg32 @ d8192 | 32.32 ± 0.23 | 33.37 ± 0.24 | | | |
| Qwen3.5-122B-A10B-FP8 | pp2048 @ d16384 | 3675.96 ± 24.64 | | 4647.34 ± 18.49 | 4567.10 ± 18.49 | 4647.44 ± 18.48 |
| Qwen3.5-122B-A10B-FP8 | tg32 @ d16384 | 31.41 ± 0.39 | 32.43 ± 0.40 | | | |
| Qwen3.5-122B-A10B-FP8 | pp2048 @ d32768 | 3494.11 ± 17.31 | | 9120.80 ± 82.05 | 9040.56 ± 82.05 | 9120.91 ± 82.06 |
| Qwen3.5-122B-A10B-FP8 | tg32 @ d32768 | 30.87 ± 0.24 | 31.39 ± 0.55 | | | |
llama-benchy (0.3.3)
date: 2026-03-05 20:57:16 | latency mode: generation
Please share your launch configuration that helped you achieve these results.
~/spark-vllm-docker/launch-cluster.sh \
exec vllm serve \
"$MODEL" \
--served-model-name "$SERVED_NAME" \
--port 8000 --host 0.0.0.0 \
--distributed-executor-backend ray \
--gpu-memory-utilization 0.82 \
--attention-backend flashinfer \
--max-num-seqs 6 \
--max-num-batched-tokens 8192 \
--max-model-len 65536 \
--mm-encoder-tp-mode data \
serapis:
tg128 @ d16384 (c4)
You should see 65-75 tokens/s at c4 in tg128 @16384
Could you try:
description: vLLM serving Qwen3.5-122B-INT4-Autoround
model: Intel/Qwen3.5-122B-A10B-int4-AutoRound
container: vllm-node-tf5
build_args:
- '--tf5'
mods:
- mods/fix-qwen3.5-autoround
defaults:
port: 8000
host: 0.0.0.0
tensor_parallel: 2
gpu_memory_utilization: 0.7
max_model_len: 131072
max_num_batched_tokens: 8192
env:
VLLM_MARLIN_USE_ATOMIC_ADD: '1'
command: |
--max-model-len {max_model_len} \
--gpu-memory-utilization {gpu_memory_utilization} \
--port {port} \
--host {host} \
--tool-call-parser qwen3_xml \
--max-num-batched-tokens {max_num_batched_tokens} \
-tp {tensor_parallel}
recipe_version: '1'
cluster_only: false
Like the one on spark-arena
This is what I use right now:
max_model_len: 262144
gpu_mem_util: 0.75
tp: 2
max_batch_tok: 8192
max_num_seqs: 4
kv_cache_dtype: auto
This is the benchmark I ran for you: llama-benchy --base-url http://0.0.0.0:8080/v1 --pp 2048 --tg 128 --depth 16384 --concurrency 4
Here is the result:
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d16384 (c4) | 3647.84 ± 9.05 | 1504.22 ± 634.91 | | | 14212.08 ± 4819.14 | 14210.32 ± 4819.14 | 14212.13 ± 4819.11 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg128 @ d16384 (c4) | 28.34 ± 0.05 | 14.60 ± 7.03 | 108.00 ± 0.00 | 27.00 ± 0.00 | | | |
llama-benchy (0.3.5)
date: 2026-03-16 09:51:23 | latency mode: api
And closer to your recipe:
gpu_mem_util: 0.7
tp: 2
max_batch_tok: 8192
max_num_seqs: 4
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d16384 (c4) | 3686.29 ± 18.74 | 1522.02 ± 642.50 | | | 14047.98 ± 4770.82 | 14046.57 ± 4770.82 | 14048.03 ± 4770.81 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg128 @ d16384 (c4) | 27.94 ± 0.89 | 13.92 ± 6.50 | 106.67 ± 1.89 | 26.75 ± 0.43 | | | |
date: 2026-03-16 10:33:07 | latency mode: api
And this is literally running the recipe: ./run-recipe.sh qwen3.5-122b-int4-autoround
llama-benchy --base-url http://0.0.0.0:8000/v1 --pp 2048 --tg 128 --depth 16384 --concurrency 4
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | pp2048 @ d16384 (c4) | 3606.82 ± 40.90 | 1478.36 ± 620.99 | | | 14429.07 ± 4851.22 | 14427.52 ± 4851.22 | 14429.14 ± 4851.21 |
| Intel/Qwen3.5-122B-A10B-int4-AutoRound | tg128 @ d16384 (c4) | 28.31 ± 0.33 | 14.70 ± 7.13 | 108.00 ± 0.00 | 27.00 ± 0.00 | | | |
date: 2026-03-16 10:53:27 | latency mode: api
What modules are you running on the cluster? All I run is Qwen3.5 27b-int4autoround. I don’t feel122B A10B is better than 27B.
After I saw Dgx spark’s price increased $700, I hurry up and pick one GIGABYTE from a store that still has the stock. Its price did not increase yet.
can you do benchmark on Qwen3.5-27B int4-autoround? It ‘s my favorite. I want to see the comparison with 122B-1A10B-int4-AutoRound? thanks.
I only run the 397b autoround model with spark-vllm-docker nowadays
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | pp2048 | 1955.36 ± 6.42 | | 1148.05 ± 3.09 | 1047.90 ± 3.09 | 1148.18 ± 3.09 |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | tg32 | 28.44 ± 0.10 | 29.00 ± 0.00 | | | |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | pp2048 @ d4096 | 1988.45 ± 4.73 | | 3190.35 ± 7.12 | 3090.20 ± 7.12 | 3190.46 ± 7.13 |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | tg32 @ d4096 | 28.35 ± 0.04 | 29.00 ± 0.00 | | | |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | pp2048 @ d8192 | 1975.06 ± 2.62 | | 5285.16 ± 7.05 | 5185.01 ± 7.05 | 5285.26 ± 7.05 |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | tg32 @ d8192 | 28.35 ± 0.16 | 29.00 ± 0.00 | | | |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | pp2048 @ d16384 | 1913.61 ± 2.57 | | 9732.59 ± 13.14 | 9632.43 ± 13.14 | 9732.70 ± 13.16 |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | tg32 @ d16384 | 28.32 ± 0.25 | 29.00 ± 0.00 | | | |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | pp2048 @ d32768 | 1783.73 ± 3.39 | | 19619.28 ± 37.00 | 19519.12 ± 37.00 | 19619.39 ± 36.99 |
| Intel/Qwen3.5-397B-A17B-int4-AutoRound | tg32 @ d32768 | 27.96 ± 0.10 | 28.33 ± 0.47 | | | |
