Hi (salam) all
First sorry for my English.
I have laptop with integrated Intel VGA and GTX850m NVIDIA. I successfully boot my windows VM with passthrough NVIDIA but my subsystem id of NVIDIA is zero.
The driver fail to install in VM (I think because of it) but not sure.
I don`t know the problem.
- I saw in /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 the rom size is 524.3k but i cant copy it(for use in vm rom).
- I extract the NVIDIA rom from bios eith mmtool but the size I can get was 102.4k and not use it now.
- I passthroug my gigabit lan too for comparison the situation. it worked perfect.
- First when I run lspci the susbsystem for them is correct but when i run the vm lspci does not show the subssystem.
Outputs for them at first :
[i]01:00.0 0302: 10de:1391 (rev a2)
Subsystem: 1043:14ad
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at f6000000 (32-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, prefetchable)
I/O ports at e000
Expansion ROM at f7000000
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel driver in use: pci-stub
Kernel modules: nouveau
04:00.0 0200: 10ec:8168 (rev 10)
Subsystem: 1043:200f
Flags: bus master, fast devsel, latency 0, IRQ 36
I/O ports at d000
Memory at f7904000 (64-bit, non-prefetchable)
Memory at f7900000 (64-bit, non-prefetchable)
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 04-96-95-33-68-4c-e0-00
Capabilities: [170] Latency Tolerance Reporting
Capabilities: [178] L1 PM Substates
Kernel driver in use: r8169
Kernel modules: r8169[/i]
Outputs for them when run VM:
Flags: fast devsel, IRQ 16
I/O ports at e000
Kernel driver in use: vfio-pci
Flags: bus master, fast devsel, latency 0, IRQ 19
I/O ports at d000
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
1- Is there any tool for communicate with nvidia chipset that i run it in VM and see the results?
2- Is there any generic driver for nvidia or specific chipset (gtx850m) but not subsystem id that maybe it can be installed in vm?
3- How can i grab or dumb the rom of NVIDIA or extract it from bios?
Thanx
