Noticed that using ConnectX-5 or ConnectX-6 LX on VGT+ and DPDK19.11 application, cannot communicate on VLANs that are allowed based on VGT+ configuration. If disable VGT+ the VLAN communication works fine.
Are you aware of any related issue? Thanks.
Hi Alex,
Assuming that you are configuring VGT+ using the “ip” command according to the OFED guide: ip link set dev vf vlan <vlan_id> [qos ]
DPDK doesn’t know about this configuration.
If you’d like to send/receive tagged traffic with DPDK, you can either use “vlan add” or rte_flow push/pop rules.
For more info please take a look at testpmd examples: https://doc.dpdk.org/guides/testpmd_app_ug/testpmd_funcs.html
Best Regards, Anatoly
Thank you very much. We are going to follow the suggested solution.
Thanks. Br, Alex
