Video Lag in Jetson AGX Orin
There is Video Lag of Approx 2 Seconds in Jetson Orin when the video is captured using OpenCV Videocapture()
But when the video is streamed directly in the gstreamer path, there is no lag in video.
Also, the same scenario when tried in Jetson Xavier, there is no issue. There is no video ;ag in Xavier.
kindly help us find a solution.
We have tried to use various methods available in different forums like changing the pipeline.
Do you use nvarguscamerasrc or v4l2src in your use-case? Would like to know the type of your source.
import cv2
rtsp_url = “rtsp://192.168.168.119:554”
vs = VideoCapture(rtsp_url)
while True:
frame = vs.read()
if frame is None:
    continue
cv2.imshow('frame', frame)
key = cv2.waitKey(1) & 0xFF
if key == ord('q'):
    break
cv2.destroyAllWindows()
cv2.release()
We are getting a video lag for the above scenario itself. We have just used the opencv for the videocapture and viewing.
Please try this sample and see if the issue is still present:
Doesn't work nvv4l2decoder for decoding RTSP in gstreamer + opencv - #3 by DaneLLL
We are getting the following error when the above pipeline is run.
nvbufsurftransform: Could not get EGL display connection
nvbuf_utils: Could not get EGL display connection
Opening in BLOCKING MODE
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (1758) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module rtspsrc0 reported: Internal data stream error.
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (888) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
[ERROR:0] global …/modules/videoio/src/cap.cpp (116) open VIDEOIO(CV_IMAGES): raised OpenCV exception:
OpenCV(4.2.0) …/modules/videoio/src/cap_images.cpp:253: error: (-5:Bad argument) CAP_IMAGES: can’t find starting number (in the name of file): rtspsrc location= rtsp://192.168.168.119:554! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw,format=BGR ! appsink in function ‘icvExtractPattern’
rtsp open failed
Looks like gstreamer is not enabled in the OpenCV. Do you use default OpenCV package installed through SDKManager?
still there is lag…
But, the gstreamer is enabled
Video I/O:
DC1394: YES (2.2.5)
FFMPEG: YES
avcodec: YES (58.54.100)
avformat: YES (58.29.100)
avutil: YES (56.31.100)
swscale: YES (5.5.100)
avresample: YES (4.0.0)
GStreamer: YES (1.16.2)
PvAPI: NO
v4l/v4l2: YES (linux/videodev2.h)
Parallel framework: TBB (ver 2020.1 interface 11101)
Trace: YES (built-in)
Please try gst-launch-1.0 command for comparison:
$ gst-launch-1.0 rtspsrc location=rtsp://192.168.168.119:554 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM)' ! nv3dsink
see if the RTSP source can be decoded well in gst-launch-1.0 command and the issue is specific to OpenCV code.
it hits this error
gst-launch-1.0 rtspsrc location=rtsp://192.168.168.119:554 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! ‘video/x-raw(memory:NVMM)’ ! nv3dsink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.168.168.119:554
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading and writing.
Additional debug info:
gstrtspsrc.c(7893): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Failed to connect. (Generic error)
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to NULL …
Freeing pipeline …
Please check if this URI is correct. Probably your RTSP source is changed.
HI,
we are getting the stream in gst launch but not in opencv, it shows the warning
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (713) open OpenCV | GStreamer warning: Error opening bin: syntax error
What JetPack or L4T release are you running:
cat /etc/nv_tegra_release
because
may not be expected with current JP-5.0.2 (L4T R35.1.0)
Hi the release version is,
R34 (release), REVISION: 0.1, GCID: 29955323, BOARD: t186ref, EABI: aarch64, DATE: Tue Mar 15 08:13:50 UTC 2022
But there is still 2 seconds delay…
strong text
Looks like you are using developer release. Please upgrade to Jetpack 5.0.2(r35.1) and try again.
Also, be aware that default latency of rtspsrc would be 2 s (2000 ms). Try to decrease it such as:
gst-launch-1.0 rtspsrc location=rtsp://192.168.168.119:554 latency=500 ! rtph264depay latency=300 ! h264parse ! nvv4l2decoder ! nvvidconv ! ‘video/x-raw(memory:NVMM)’ ! nv3dsink
After i gave sudo apt update,sudo sudo apt dist upgrade, sudoreboot,in terminal the jetson orin does not display anything
The screen went blank
And the fan is running continuously what to do
please give some solution…
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
L4T BSP Information:
R35 , REVISION: 1.0
Unsupported ioctl: cmd=0xffffffff8004550f
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
But the USB is connected through Type-C cable
Be sure to use the USB-C connector on GPIO connector side.
Also if possible try another cable… Some cables from smartphone power supply may have low quality signal.
Be sure to set your Jetson in recovery mode.
See:
Please also try to flash through SDKManager. You can install system image and SDK Components by following the steps.
sudo apt install ./sdkmanager_1.9.0-10816_amd64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘sdkmanager:amd64’ instead of ‘./sdkmanager_1.9.0-10816_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
Depends: libcanberra-gtk-module:amd64 but it is not installable
Depends: locales:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages
