qjmiao
November 28, 2020, 11:40am
1
Video playback is jittery when using multiple nv3dsink instances in the same program/process.
For example, “gst-launch-1.0 videotestsrc pattern=ball ! ‘video/x-raw,width=1920,height=1080,framerate=30/1’ ! tee name=t ! queue ! nvvidconv ! nv3dsink t. ! queue ! nvvidconv ! nv3dsink”
If replace one or all nv3dsink with xvimagesink, video playback is very smooth.
For example, “gst-launch-1.0 videotestsrc pattern=ball ! ‘video/x-raw,width=1920,height=1080,framerate=30/1’ ! tee name=t ! queue ! nvvidconv ! nv3dsink t. ! queue ! xvimagesink”
The below program has two pipelines and one nv3dsink per pipeline, the video playback is jittery. If replace one nv3dsink with xvimagesink, the playback will be smooth again.
#!/usr/bin/python3
import sys
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GObject
Gst.init(sys.argv)
a_pipeline = Gst.parse_launch('videotestsrc pattern=ball ! video/x-raw,width=1920,height=1080,framerate=30/1 '
# '! xvimagesink'
'! nvvidconv ! nv3dsink'
b_pipeline = Gst.parse_launch('videotestsrc pattern=ball ! video/x-raw,width=1920,height=1080,framerate=30/1 '
# '! xvimagesink'
a_pipeline.set_state(Gst.State.PLAYING)
b_pipeline.set_state(Gst.State.PLAYING)
loop = GObject.MainLoop()
try:
loop.run()
except:
print('Exitting...')
b_pipeline.set_state(Gst.State.NULL)
a_pipeline.set_state(Gst.State.NULL)
loop.quit()
DaneLLL
November 30, 2020, 1:28am
3
The issue is known and we are checking internally. Suggest you use nvcompositor to composite sources into single video plane.
Related topics:
Multiple gstreamer pipelines slow down when in the same process - #10 by DaneLLL
Multiple instances of NvEglRenderer
qjmiao
November 30, 2020, 12:12pm
5
It does not look like the same. If you don’t have multiple nv3dsink in single pipeline, it should work fine. And we have tried setting ts-offset and it helps. Not sure why it does not take effect with your sensor.
qjmiao
December 11, 2020, 8:13am
7
Hi DaneLLL,
When will this issue be fixed?
nvcompositor is not applicable to us.
Our application will have multiple windows on multiple monitors.
The issue listed in the comment is fixed in Jetpack 4.5.1.
qjmiao
May 24, 2021, 7:19am
10
It’s a good news. I will try 4.5.1 release later
qjmiao
May 24, 2021, 7:41am
11
I just upgraded to 32.5.1 from 32.4.4. But there is a new issue.
$ gst-launch-1.0 videotestsrc pattern=ball ! nvvidconv ! nv3dsink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
(gst-launch-1.0:5913): GLib-CRITICAL **: 15:37:34.766: g_array_remove_index: assertion 'index_ < array->len' failed
(gst-launch-1.0:5913): GStreamer-CRITICAL **: 15:37:34.766: gst_caps_remove_structure: assertion 'idx <= gst_caps_get_size (caps)' failed
(gst-launch-1.0:5913): GStreamer-CRITICAL **: 15:37:34.766: gst_structure_set_parent_refcount: assertion 'refcount != NULL' failed
(gst-launch-1.0:5913): GStreamer-CRITICAL **: 15:37:34.766: gst_caps_features_set_parent_refcount: assertion 'refcount != NULL' failed
free(): invalid pointer
Aborted (core dumped)
qjmiao
May 24, 2021, 7:54am
12
without nvvidconv, the pipeline is OK, but CPU usage is higher considerably than the one in R32.4.4
gst-launch-1.0 videotestsrc pattern=ball ! nv3dsink
Even with h265 hardware decoding, the pipeline CPU usage is higher more than the one in R32.4.4
There is always a process occupying 100% cpu
The nv3dsink plugin supports video/x-raw and video/x-raw(memory:NVMM) . Please specify video/x-raw(memory:NVMM) and try again:
... ! video/x-raw(memory:NVMM) ! nv3dsink
qjmiao
May 24, 2021, 2:19pm
14
If I add ‘video/x-raw(memory:NVMM)’ between nvvidconv and nv3dsink, there is no crash any more.
But in both videotestsrc and hardware video file decoding cases, gst-launch process cpu usage is very high compared with R32.4.4. One of cpus is always 100% usage
(gst-launch-1.0 filesrc location=Apink_MrChu.mp4 ! tsdemux ! h265parse ! nvv4l2decoder ! nv3dsink window-width=1280 window-height=720)
We don’t observe the issue on r32.5.1/Xavier.
$ gst-launch-1.0 filesrc location= /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_1080p_h265.mp4 ! qtdemux ! h265parse ! nvv4l2decoder ! nv3dsink window-width=1280 window-height=720
RAM 2189/31921MB (lfb 7167x4MB) SWAP 0/15960MB (cached 0MB) CPU [2%@2264,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265] EMC_FREQ 0%@2133 GR3D_FREQ 1%@1377 NVDEC 1075 VIC_FREQ 0%@115 APE 150 MTS fg 0% bg 1% AO@41C GPU@41.5C Tdiode@47C PMIC@100C AUX@40.5C CPU@42.5C thermal@41.4C Tboard@43C GPU 1218/1206 CPU 609/655 SOC 3655/3182 CV 0/0 VDDRQ 457/457 SYS5V 2184/2182
RAM 2189/31921MB (lfb 7167x4MB) SWAP 0/15960MB (cached 0MB) CPU [0%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265] EMC_FREQ 0%@2133 GR3D_FREQ 1%@1377 NVDEC 972 VIC_FREQ 0%@115 APE 150 MTS fg 0% bg 1% AO@41C GPU@41.5C Tdiode@46.75C PMIC@100C AUX@40.5C CPU@42.5C thermal@41.4C Tboard@43C GPU 1218/1207 CPU 609/654 SOC 3503/3190 CV 0/0 VDDRQ 457/457 SYS5V 2184/2182
RAM 2189/31921MB (lfb 7167x4MB) SWAP 0/15960MB (cached 0MB) CPU [2%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265,0%@2265] EMC_FREQ 0%@2133 GR3D_FREQ 0%@1377 NVDEC 1075 VIC_FREQ 0%@115 APE 150 MTS fg 0% bg 1% AO@41C GPU@41.5C Tdiode@47C PMIC@100C AUX@40.5C CPU@42.5C thermal@41.4C Tboard@43C GPU 1219/1207 CPU 609/653 SOC 3351/3194 CV 0/0 VDDRQ 457/457 SYS5V 2184/2182
The CPU loading is low in tegrastats. Don’t observe one core is at 100%.
qjmiao
August 14, 2021, 4:54am
16
Such issue still exists in R32.6.1
The test command is
gst-launch-1.0 videotestsrc pattern=ball is-live=true ! 'video/x-raw,width=640,height=480,framerate=60/1' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! tee name=t ! queue ! nv3dsink t. ! queue ! nv3dsink
On r32.6.1, please run single nv3dsink in each process. If you have multiple sources, please use nvcompositor to composite the sources into single video plane.
