I have faced some nvcompositor issue. I need to composite two video streams from two USB camera.
Below is my pipeline:
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=NV12,width=640,height=480 ! videoconvert ! video/x-raw,format=RGBA ! queue ! nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=640 sink_0::height=480 sink_0::xpos=640 sink_0::ypos=0 sink_1::width=640 sink_1::height=480 ! nv3dsink v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=640,height=480 ! videoconvert ! video/x-raw,format=RGBA ! queue ! comp.
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.608132989
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
If I replace the nv3dsink by nvoverlaysink, the pipeline is working, but I can not use nvoverlaysink since nvoverlaysink does not have window.
And for some reason from my app side the sinkpad of nvcompositor need to be system memory i.e.“video/x-raw, format=RGBA” , rather than NVMM “video/x-raw(memory:NVMM)”.
Could you help? Thanks in advance.
