hello All,
I want use nvcompositor and nvoverlaysink to composit 2 videotestsrc in gstreamer appsink!!
you don’t have sample code of nvcompositor and appsink gstreamer??
i want to use this reference (Video Composition)
https://developer.ridgerun.com/wiki/index.php?title=Jetson_Nano/Gstreamer/Example_Pipelines/Transforming
and this sample
https://devtalk.nvidia.com/default/topic/1037450/jetson-tx2/use-gstreamer-or-tegra_multimedia_api-to-decode-video-would-be-more-efficient-and-increase-throughpu-/post/5270860/#5270860
for example ::
#include <cstdlib>
#include <gst/gst.h>
#include <gst/gstinfo.h>
#include <gst/app/gstappsink.h>
#include <glib-unix.h>
#include <dlfcn.h>
#include <iostream>
#include <sstream>
#include <thread>
#include "NvEglRenderer.h"
#include "nvbuf_utils.h"
using namespace std;
#define USE(x) ((void)(x))
static GstPipeline *gst_pipeline = nullptr;
static string launch_string;
static int frame_count = 0;
static int sleep_count = 0;
static int eos = 0;
static NvEglRenderer *renderer;
static void appsink_eos(GstAppSink * appsink, gpointer user_data)
printf("app sink receive eos\n");
eos = 1;
// g_main_loop_quit (hpipe->loop);
static GstFlowReturn new_buffer(GstAppSink *appsink, gpointer user_data)
GstSample *sample = NULL;
g_signal_emit_by_name (appsink, "pull-sample", &sample,NULL);
if (sample)
GstBuffer *buffer = NULL;
GstCaps *caps = NULL;
GstMapInfo map = {0};
int dmabuf_fd = 0;
caps = gst_sample_get_caps (sample);
if (!caps)
printf("could not get snapshot format\n");
gst_caps_get_structure (caps, 0);
buffer = gst_sample_get_buffer (sample);
gst_buffer_map (buffer, &map, GST_MAP_READ);
ExtractFdFromNvBuffer((void *)map.data, &dmabuf_fd);
//printf("dmabuf_fd %d \n", dmabuf_fd);
renderer->render(dmabuf_fd);
//NvReleaseFd(dmabuf_fd);
frame_count++;
gst_buffer_unmap(buffer, &map);
gst_sample_unref (sample);
else
g_print ("could not make snapshot\n");
return GST_FLOW_OK;
int main(int argc, char** argv) {
USE(argc);
USE(argv);
gst_init (&argc, &argv);
GMainLoop *main_loop;
main_loop = g_main_loop_new (NULL, FALSE);
ostringstream launch_stream;
int w = 1920;
int h = 816;
int WIDTH=320;
int HEIGHT=240;
int xpos=0;
int ypos=0;
GstAppSinkCallbacks callbacks = {appsink_eos, NULL, new_buffer};
launch_stream
<< "nvcompositor name=comp "
<< "sink_0::xpos="<< xpos << " sink_0::ypos="<< ypos <<" sink_0::width="<< WIDTH <<" sink_0::height="<< HEIGHT <<" sink_1::xpos="<< WIDTH << " sink_1::ypos="<< ypos <<" sink_1::width="<< WIDTH <<" sink_1::height="<< HEIGHT << " "
<< "videotestsrc is-live=true" <<" ! "
<< "video/x-raw, width="<< WIDTH <<", height="<< HEIGHT <<" ! "
<< "comp. "
<< "videotestsrc is-live=true pattern=ball "<<" ! "
<< "comp. ! "
// << "nvvidconv ! "
// << "video/x-raw(memory:NVMM), format=I420, width="<< WIDTH <<", height="<< HEIGHT <<" ! "
<< "appsink name=mysink ";
launch_stream
<<"videotestsrc " <<" ! "
<<"video/x-raw, width="<< w <<", height="<< h <<" ! "
<< "nvvidconv ! "
<< "video/x-raw(memory:NVMM), format=I420, width="<< w <<", height="<< h <<" ! "
launch_string = launch_stream.str();
g_print("Using launch string: %s\n", launch_string.c_str());
GError *error = nullptr;
gst_pipeline = (GstPipeline*) gst_parse_launch(launch_string.c_str(), &error);
if (gst_pipeline == nullptr) {
g_print( "Failed to parse launch: %s\n", error->message);
return -1;
if(error) g_error_free(error);
GstElement *appsink_ = gst_bin_get_by_name(GST_BIN(gst_pipeline), "mysink");
gst_app_sink_set_callbacks (GST_APP_SINK(appsink_), &callbacks, NULL, NULL);
renderer = NvEglRenderer::createEglRenderer("renderer0",
w, h, 0, 0);
renderer->setFPS(24);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_PLAYING);
while (eos == 0) {
sleep(1);
sleep_count++;
//sleep(90);
//g_main_loop_run (main_loop);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_NULL);
gst_object_unref(GST_OBJECT(gst_pipeline));
g_main_loop_unref(main_loop);
delete renderer;
g_print("going to exit, decode %d frames in %d seconds \n", frame_count, sleep_count);
return 0;
in launch_stream ,how use nvcompositor pipeline
launch_stream
<< "comp. "
<< "comp. ! "
you can guide me,to implement this sample??
