I’m streaming a video via an RTSP stream and then compositing it with another video using nvcompositor at 60FPS (or as close as possible to that).
When I run the RTSP stream like so I get the desired framerate:
./test-launch "v4l2src device=/dev/video2 ! video/x-raw, width=2560, height=720, framerate=60/1 ! nvvidconv ! nvv4l2h265enc maxperf-enable=1 ! h265parse ! rtph265pay name=pay0"
gst-launch-1.0 rtspsrc location=rtsp://127.0.0.1:8554/test latency=0 ! rtph265depay ! h265parse ! nvv4l2decoder ! nvvidconv ! xvimagesink sync=0
and when I run nvcompositor with direct streaming I also get the desired latency:
gst-launch-1.0 nvcompositor name=comp \
sink_0::xpos=0 sink_0::ypos=0 sink_0::width=2560 sink_0::height=720 sink_0::zorder=1 sink_0::alpha=1 \
sink_1::xpos=0 sink_1::ypos=0 sink_1::width=2560 sink_1::height=720 sink_1::zorder=2 sink_1::alpha=0.1 ! \
'video/x-raw(memory:NVMM),format=RGBA' ! nv3dsink sync=0 \
v4l2src device=/dev/video2 ! video/x-raw,format=YUY2,width=2560,height=720,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=RGBA' ! comp.sink_0 \
videotestsrc ! videoconvert ! video/x-raw,format=RGBA ! nvvidconv ! 'video/x-raw(memory:NVMM),format=RGBA,width=2560,height=720' ! comp.sink_1
But when I put it all together there’s latency that looks like it’s around 20-30FPS:
'video/x-raw(memory:NVMM),format=RGBA' ! nv3dsink \
rtspsrc location=rtsp://127.0.0.1:8554/test latency=0 ! rtph265depay ! h265parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=RGBA' ! comp.sink_0 \
I realize that the compositor examples use nv3dsink whereas the other one uses xvimagesink and adds the sync=0 property. I couldn’t figure out how to use xvimagesink in the compositor so I didn’t test if the latency came from the sink I was using. I’ve also already tried jetson_clocks, and adding the maxperf-enable property to the encoder. Any advice on how to improve latency would be much appreciated
