Thank you for your work on Jetson. I'm building an AI server that runs on a… NX Orin. But when I ran video-viewer with this command
`./aarch64/bin/video-viewer file:///home/aiserver/Software/cc/videos/helicopter.mp4 webrtc://@:8686/output --headless`
The stream appears to be glitching and freezing, especially after a long time ( like after a minute).
What do you think is the reason for this delay and is there any way that I can debug or solve this issue? (I want to get the latest frame possible with perhaps a lower bitrate/image quality)
https://github.com/dusty-nv/jetson-inference/assets/53960609/6d3f7f14-ee9b-4b4e-8b87-c542475b502a
Here is the full log:
./aarch64/bin/video-viewer file:///home/aiserver/Software/cc/videos/helicopter.mp4 webrtc://@:8686/output --headless --bitrate=6000000 --input-loop=-1
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstDecoder -- creating decoder for /home/aiserver/Software/cc/videos/helicopter.mp4
[gstreamer] GST_LEVEL_WARNING GstFileSrc basesrc
gstbasesrc.c:3583 gst_base_src_start_complete
pad not activated yet
[gstreamer] GST_LEVEL_WARNING qtdemux
qtdemux_types.c:233 qtdemux_type_get
unknown QuickTime node type Xtra
[gstreamer] GST_LEVEL_WARNING GstQTDemux qtdemux
qtdemux.c:3031 qtdemux_parse_trex
failed to find fragment defaults for stream 1
failed to find fragment defaults for stream 2
Opening in BLOCKING MODE
[gstreamer] GST_LEVEL_WARNING GstPad v4l2
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/gstv4l2object.c:4447 gst_v4l2_object_probe_caps
Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
[gstreamer] GST_LEVEL_WARNING (null) v4l2
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/gstv4l2object.c:2388 gst_v4l2_object_add_interlace_mode
Failed to determine interlace mode
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
[gstreamer] GST_LEVEL_WARNING nvv4l2decoder v4l2videodec
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/gstv4l2videodec.c:1673 gst_v4l2_video_dec_decide_allocation
Duration invalid, not setting latency
[gstreamer] GST_LEVEL_WARNING GstNvV4l2BufferPool v4l2bufferpool
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/gstv4l2bufferpool.c:1065 gst_v4l2_buffer_pool_start
Uncertain or not enough buffers, enabling copy threshold
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/gstv4l2bufferpool.c:1512 gst_v4l2_buffer_pool_dqbuf
Driver should never set v4l2_buffer.field to ANY
[gstreamer] gstDecoder -- discovered video resolution: 1920x1080 (framerate 30.000000 Hz)
[gstreamer] gstDecoder -- discovered video caps: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
[gstreamer] gstDecoder -- pipeline string:
[gstreamer] filesrc location=/home/aiserver/Software/cc/videos/helicopter.mp4 ! qtdemux ! queue ! h264parse ! omxh264dec name=decoder ! video/x-raw(memory:NVMM) ! appsink name=mysink
[gstreamer] GST_LEVEL_WARNING omx
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-omx/omx/gstomx.c:2826 plugin_init
Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/aiserver/.config:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
[video] created gstDecoder from file:///home/aiserver/Software/cc/videos/helicopter.mp4
gstDecoder video options:
-- URI: file:///home/aiserver/Software/cc/videos/helicopter.mp4
- protocol: file
- location: /home/aiserver/Software/cc/videos/helicopter.mp4
- extension: mp4
-- deviceType: file
-- ioType: input
-- codec: H264
-- codecType: omx
-- width: 1920
-- height: 1080
-- frameRate: 30
-- numBuffers: 2
-- zeroCopy: true
-- flipMethod: none
-- loop: -1
video viewer
[gstreamer] gstEncoder -- codec not specified, defaulting to H.264
[gstreamer] gstEncoder -- pipeline launch string:
[gstreamer] appsrc name=mysource is-live=true do-timestamp=true format=3 ! omxh264enc name=encoder bitrate=6000000 insert-sps-pps=1 insert-vui=1 ! video/x-h264 ! rtph264pay config-interval=1 ! application/x-rtp,media=video,encoding-name=H264,clock-rate=90000,payload=96 ! tee name=videotee ! queue ! fakesink
[webrtc] WebRTC server started @ http://aiserver:8686
[webrtc] WebRTC server thread running...
[webrtc] websocket route added /output
[video] created gstEncoder from webrtc://@:8686/output
gstEncoder video options:
-- URI: webrtc://@:8686/output
- protocol: webrtc
- port: 8686
-- deviceType: ip
-- ioType: output
-- codec: H264
-- codecType: omx
-- frameRate: 30
-- bitRate: 6000000
-- numBuffers: 2
-- zeroCopy: true
-- latency 0
[gstreamer] opening gstDecoder for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> decoder
[gstreamer] gstreamer changed state from NULL to READY ==> h264parse1
[gstreamer] gstreamer changed state from NULL to READY ==> queue0
[gstreamer] gstreamer changed state from NULL to READY ==> qtdemux1
[gstreamer] gstreamer changed state from NULL to READY ==> filesrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> decoder
[gstreamer] gstreamer changed state from READY to PAUSED ==> h264parse1
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> queue0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer stream status CREATE ==> sink
[gstreamer] gstreamer changed state from READY to PAUSED ==> qtdemux1
[gstreamer] gstreamer changed state from READY to PAUSED ==> filesrc0
[gstreamer] gstreamer stream status ENTER ==> sink
(video-viewer:23711): GStreamer-CRITICAL **: 09:13:16.625: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:23711): GStreamer-CRITICAL **: 09:13:16.625: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:23711): GStreamer-CRITICAL **: 09:13:16.626: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:23711): GStreamer-CRITICAL **: 09:13:16.626: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:23711): GStreamer-CRITICAL **: 09:13:16.626: gst_structure_get_string: assertion 'structure != NULL' failed
[gstreamer] GST_LEVEL_ERROR GstOMXH264Dec-omxh264dec omxvideodec
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-omx/omx/gstomxvideodec.c:3274 gst_omx_video_dec_negotiate
Invalid caps: (NULL)
(video-viewer:23711): GStreamer-CRITICAL **: 09:13:16.627: gst_mini_object_unref: assertion 'mini_object != NULL' failed
Allocating new output: 1920x1088 (x 10), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 1920, nFrameHeight = 1080
[gstreamer] gstDecoder -- onPreroll()
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstreamer message duration-changed ==> h264parse1
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ /\ AVC", bitrate=(uint)11907565;
[gstreamer] gstreamer mysink taglist, datetime=(datetime)2021-12-14T16:56:13Z, container-format=(string)"ISO\ MP4/M4A";
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565;
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstBufferManager -- map buffer size was less than max size (1008 vs 3110400)
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstBufferManager recieve caps: video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstBufferManager -- recieved first frame, codec=H264 format=nv12 width=1920 height=1080 size=3110400
[gstreamer] gstBufferManager -- recieved NVMM memory
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> decoder
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> h264parse1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> queue0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> qtdemux1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> filesrc0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda] cudaAllocMapped 8 bytes, CPU 0x2032ba000 GPU 0x2032ba000
[cuda] cudaAllocMapped 8 bytes, CPU 0x2032ba200 GPU 0x2032ba200
[cuda] allocated 2 ring buffers (8 bytes each, 16 bytes total)
nvbuf_utils: dmabuf_fd 1071 mapped entry NOT found
nvbuf_utils: NvReleaseFd Failed... Exiting...
nvbuf_utils: dmabuf_fd 1069 mapped entry NOT found
[cuda] cudaAllocMapped 6220800 bytes, CPU 0x203afa000 GPU 0x203afa000
[cuda] cudaAllocMapped 6220800 bytes, CPU 0x2040e9000 GPU 0x2040e9000
[cuda] allocated 2 ring buffers (6220800 bytes each, 12441600 bytes total)
video-viewer: captured 0 frames (1920x1080)
nvbuf_utils: dmabuf_fd 1073 mapped entry NOT found
[cuda] cudaAllocMapped 3110400 bytes, CPU 0x2034ba000 GPU 0x2034ba000
[cuda] cudaAllocMapped 3110400 bytes, CPU 0x2046d8000 GPU 0x2046d8000
[cuda] allocated 2 ring buffers (3110400 bytes each, 6220800 bytes total)
[gstreamer] gstEncoder -- starting pipeline, transitioning to GST_STATE_PLAYING
[gstreamer] gstEncoder -- queued state to GST_STATE_PLAYING => GST_STATE_CHANGE_ASYNC
[gstreamer] gstreamer changed state from NULL to READY ==> fakesink0
[gstreamer] gstreamer changed state from NULL to READY ==> queue1
[gstreamer] gstreamer changed state from NULL to READY ==> videotee
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter3
[gstreamer] gstreamer changed state from NULL to READY ==> rtph264pay0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter2
[gstreamer] gstreamer changed state from NULL to READY ==> encoder
[gstreamer] gstreamer changed state from NULL to READY ==> mysource
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline1
[gstreamer] gstreamer changed state from READY to PAUSED ==> queue1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videotee
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter3
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtph264pay0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter2
[gstreamer] gstreamer changed state from READY to PAUSED ==> encoder
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysource
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline1
[gstreamer] gstreamer message new-clock ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> queue1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videotee
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter3
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtph264pay0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> encoder
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysource
nvbuf_utils: dmabuf_fd 1075 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1077 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1079 mapped entry NOT found
[gstreamer] gstEncoder -- new caps: video/x-raw, width=1920, height=1080, format=(string)I420, framerate=30/1
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
video-viewer: captured 1 frames (1920x1080)
NvMMLiteBlockCreate : Block : BlockType = 4
[gstreamer] GST_LEVEL_WARNING GstOMXH264Enc-omxh264enc omxvideoenc
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-omx/omx/gstomxvideoenc.c:1860 gst_omx_video_enc_set_format
Error setting temporal_tradeoff 0 : Vendor specific error (0x00000001)
[gstreamer] gstEncoder -- appsrc signalling enough data
video-viewer: captured 2 frames (1920x1080)
H264: Profile = 66, Level = 40
NVMEDIA_ENC: bBlitMode is set to TRUE
video-viewer: captured 3 frames (1920x1080)
[gstreamer] gstreamer message stream-start ==> pipeline1
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)10789680, maximum-bitrate=(uint)10789680;
video-viewer: captured 4 frames (1920x1080)
[gstreamer] gstreamer changed state from READY to PAUSED ==> fakesink0
[gstreamer] gstreamer message async-done ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> fakesink0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline1
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)3829680, maximum-bitrate=(uint)10789680;
video-viewer: captured 5 frames (1920x1080)
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)3010320, maximum-bitrate=(uint)10789680;
video-viewer: captured 6 frames (1920x1080)
video-viewer: captured 7 frames (1920x1080)
video-viewer: captured 8 frames (1920x1080)
video-viewer: captured 9 frames (1920x1080)
video-viewer: captured 10 frames (1920x1080)
video-viewer: captured 11 frames (1920x1080)
video-viewer: captured 12 frames (1920x1080)
video-viewer: captured 13 frames (1920x1080)
video-viewer: captured 14 frames (1920x1080)
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)2236800, maximum-bitrate=(uint)10789680;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)2236800, maximum-bitrate=(uint)11034000;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)2236800, maximum-bitrate=(uint)65089680;
video-viewer: captured 25 frames (1920x1080)
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)1505760, maximum-bitrate=(uint)65089680;
video-viewer: captured 50 frames (1920x1080)
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)1505760, maximum-bitrate=(uint)65120640;
video-viewer: captured 75 frames (1920x1080)
video-viewer: captured 100 frames (1920x1080)
video-viewer: captured 125 frames (1920x1080)
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)1433520, maximum-bitrate=(uint)65120640;
video-viewer: captured 150 frames (1920x1080)
video-viewer: captured 175 frames (1920x1080)
[webrtc] websocket /output -- new connection opened by 127.0.0.1 (peer_id=0)
[webrtc] new WebRTC peer connecting (127.0.0.1, peer_id=0)
(video-viewer:23711): GLib-GObject-WARNING **: 09:13:23.382: g_object_set_is_valid_property: object class 'GstWebRTCBin' has no property named 'latency'
(video-viewer:23711): GLib-GObject-WARNING **: 09:13:23.383: g_object_set_is_valid_property: object class 'WebRTCTransceiver' has no property named 'direction'
[gstreamer] gstreamer changed state from NULL to READY ==> queue-0
[gstreamer] gstreamer changed state from READY to PAUSED ==> queue-0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> queue-0
[gstreamer] gstreamer changed state from NULL to READY ==> rtpbin
[gstreamer] gstreamer changed state from NULL to READY ==> webrtcbin-0
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtpbin
[gstreamer] gstreamer changed state from READY to PAUSED ==> webrtcbin-0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtpbin
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> webrtcbin-0
[webrtc] GStreamer WebRTC -- onNegotiationNeeded()
video-viewer: captured 200 frames (1920x1080)
[gstreamer] GST_LEVEL_WARNING GstPad GST_PADS
gstpad.c:4226 gst_pad_peer_query
could not send sticky events
[webrtc] GStreamer WebRTC -- onCreateOffer()
[webrtc] negotiation offer created:
v=0
o=- 2909856011703445696 0 IN IP4 0.0.0.0
s=-
t=0 0
a=ice-options:trickle
a=msid-semantic:WMS webrtcbin-0
m=video 9 UDP/TLS/RTP/SAVPF 96
c=IN IP4 0.0.0.0
a=setup:actpass
a=ice-ufrag:X14dK5fZJCw9rL+FV2lK0uXQnJFGeXWz
a=ice-pwd:PGn86OaHdnjVxczRy6L1nnovUTzYOt20
a=sendrecv
a=rtcp-mux
a=rtcp-rsize
a=rtpmap:96 H264/90000
a=rtcp-fb:96 nack pli
a=framerate:30
a=fmtp:96 packetization-mode=1;profile-level-id=424015;sprop-parameter-sets=Z0JAKJWgHgCJ+WEAAAMAAQAAAwA8jwiEag==,aM48gA==
a=ssrc:3885686574 msid:user3754559267@host-2cc00e2c webrtctransceiver0
a=ssrc:3885686574 cname:user3754559267@host-2cc00e2c
a=mid:video0
a=fingerprint:sha-256 DC:8D:D0:55:78:A6:87:A5:E0:12:6F:B8:1D:F8:64:62:93:D4:3F:5D:DB:4D:0B:43:61:88:A4:CE:14:5F:50:DC
[webrtc] sending offer for /output to 127.0.0.1 (peer_id=0):
{"type":"sdp","data":{"type":"offer","sdp":"v=0\r\no=- 2909856011703445696 0 IN IP4 0.0.0.0\r\ns=-\r\nt=0 0\r\na=ice-options:trickle\r\na=msid-semantic:WMS webrtcbin-0\r\nm=video 9 UDP/TLS/RTP/SAVPF 96\r\nc=IN IP4 0.0.0.0\r\na=setup:actpass\r\na=ice-ufrag:X14dK5fZJCw9rL+FV2lK0uXQnJFGeXWz\r\na=ice-pwd:PGn86OaHdnjVxczRy6L1nnovUTzYOt20\r\na=sendrecv\r\na=rtcp-mux\r\na=rtcp-rsize\r\na=rtpmap:96 H264/90000\r\na=rtcp-fb:96 nack pli\r\na=framerate:30\r\na=fmtp:96 packetization-mode=1;profile-level-id=424015;sprop-parameter-sets=Z0JAKJWgHgCJ+WEAAAMAAQAAAwA8jwiEag==,aM48gA==\r\na=ssrc:3885686574 msid:user3754559267@host-2cc00e2c webrtctransceiver0\r\na=ssrc:3885686574 cname:user3754559267@host-2cc00e2c\r\na=mid:video0\r\na=fingerprint:sha-256 DC:8D:D0:55:78:A6:87:A5:E0:12:6F:B8:1D:F8:64:62:93:D4:3F:5D:DB:4D:0B:43:61:88:A4:CE:14:5F:50:DC\r\n"}}
[gstreamer] gstreamer changed state from NULL to READY ==> rtpssrcdemux0
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtpssrcdemux0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtpssrcdemux0
[gstreamer] gstreamer changed state from NULL to READY ==> rtpsession0
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtpsession0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtpsession0
[gstreamer] gstreamer changed state from NULL to READY ==> funnel4
[gstreamer] gstreamer changed state from READY to PAUSED ==> funnel4
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> funnel4
[gstreamer] gstreamer changed state from NULL to READY ==> funnel5
[gstreamer] gstreamer changed state from READY to PAUSED ==> funnel5
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> funnel5
[gstreamer] gstreamer changed state from NULL to READY ==> rtpstorage0
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtpstorage0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtpstorage0
[gstreamer] gstreamer changed state from NULL to READY ==> nicesink2
[gstreamer] gstreamer changed state from NULL to READY ==> nicesink1
[gstreamer] gstreamer changed state from NULL to READY ==> outputselector0
[gstreamer] gstreamer changed state from NULL to READY ==> transportsendbin0
[gstreamer] gstreamer changed state from READY to PAUSED ==> nicesink2
[gstreamer] gstreamer changed state from READY to PAUSED ==> nicesink1
[gstreamer] gstreamer changed state from READY to PAUSED ==> outputselector0
[gstreamer] gstreamer changed state from READY to PAUSED ==> transportsendbin0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nicesink2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nicesink1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> outputselector0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> transportsendbin0
[gstreamer] gstreamer changed state from NULL to READY ==> nicesrc1
[gstreamer] gstreamer changed state from READY to PAUSED ==> nicesrc1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nicesrc1
[gstreamer] gstreamer changed state from NULL to READY ==> nicesrc2
[gstreamer] gstreamer changed state from READY to PAUSED ==> nicesrc2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nicesrc2
[gstreamer] gstreamer changed state from NULL to READY ==> funnel3
[gstreamer] gstreamer changed state from NULL to READY ==> queue2
[gstreamer] gstreamer changed state from NULL to READY ==> funnel2
[gstreamer] gstreamer changed state from NULL to READY ==> srtpdec0
[gstreamer] gstreamer changed state from NULL to READY ==> dtlsdec0
[gstreamer] gstreamer changed state from NULL to READY ==> dtlssrtpdemux0
[gstreamer] gstreamer changed state from NULL to READY ==> dtlssrtpdec0
[gstreamer] gstreamer changed state from NULL to READY ==> srtpdec1
[gstreamer] gstreamer changed state from NULL to READY ==> dtlsdec1
[gstreamer] gstreamer changed state from NULL to READY ==> dtlssrtpdemux1
[gstreamer] gstreamer changed state from NULL to READY ==> dtlssrtpdec1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter4
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter5
[gstreamer] gstreamer changed state from NULL to READY ==> transportreceivebin0
[gstreamer] gstreamer changed state from READY to PAUSED ==> funnel3
[gstreamer] gstreamer changed state from READY to PAUSED ==> queue2
[gstreamer] gstreamer changed state from READY to PAUSED ==> funnel2
[gstreamer] gstreamer changed state from READY to PAUSED ==> srtpdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlsdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlssrtpdemux0
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlssrtpdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> srtpdec1
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlsdec1
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlssrtpdemux1
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlssrtpdec1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter4
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter5
[gstreamer] gstreamer changed state from READY to PAUSED ==> transportreceivebin0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> funnel3
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> queue2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> funnel2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> srtpdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlsdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlssrtpdemux0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlssrtpdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> srtpdec1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlsdec1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlssrtpdemux1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlssrtpdec1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter4
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter5
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> transportreceivebin0
[webrtc] GStreamer WebRTC -- onICECandidate()
[webrtc] sending ICE candidate for /output to 127.0.0.1 (peer_id=0):
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:1 1 UDP 2013266431 fe80::42:feff:fe44:1ee2 36747 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:2 1 TCP 1015023359 fe80::42:feff:fe44:1ee2 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:3 1 TCP 1010829055 fe80::42:feff:fe44:1ee2 48607 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:4 1 UDP 2013266430 fe80::7d4b:aa57:607f:a15a 60821 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:5 1 TCP 1015023358 fe80::7d4b:aa57:607f:a15a 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:6 1 TCP 1010829054 fe80::7d4b:aa57:607f:a15a 57381 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:7 1 UDP 2013266429 172.17.0.1 44864 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:8 1 TCP 1015022335 172.17.0.1 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:9 1 TCP 1010828031 172.17.0.1 34103 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:10 1 UDP 2013266428 192.168.0.182 49196 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:11 1 TCP 1015022591 192.168.0.182 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:12 1 TCP 1010828287 192.168.0.182 34065 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:1 2 UDP 2013266430 fe80::42:feff:fe44:1ee2 56877 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:2 2 TCP 1015023358 fe80::42:feff:fe44:1ee2 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:3 2 TCP 1010829054 fe80::42:feff:fe44:1ee2 56661 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:4 2 UDP 2013266429 fe80::7d4b:aa57:607f:a15a 50172 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:5 2 TCP 1015023357 fe80::7d4b:aa57:607f:a15a 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:6 2 TCP 1010829053 fe80::7d4b:aa57:607f:a15a 33137 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:7 2 UDP 2013266428 172.17.0.1 51381 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:8 2 TCP 1015022334 172.17.0.1 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:9 2 TCP 1010828030 172.17.0.1 48999 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:10 2 UDP 2013266427 192.168.0.182 40393 typ host"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:11 2 TCP 1015022590 192.168.0.182 9 typ host tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:12 2 TCP 1010828286 192.168.0.182 46519 typ host tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:13 1 UDP 1677722111 82.16.190.80 44864 typ srflx raddr 172.17.0.1 rport 44864"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:14 1 TCP 847250175 82.16.190.80 9 typ srflx raddr 172.17.0.1 rport 9 tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:15 1 TCP 843055871 82.16.190.80 34103 typ srflx raddr 172.17.0.1 rport 34103 tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:16 2 UDP 1677722110 82.16.190.80 40393 typ srflx raddr 192.168.0.182 rport 40393"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:17 2 TCP 847250430 82.16.190.80 9 typ srflx raddr 192.168.0.182 rport 9 tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:18 2 TCP 843056126 82.16.190.80 46519 typ srflx raddr 192.168.0.182 rport 46519 tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:13 2 UDP 1677722109 82.16.190.80 51381 typ srflx raddr 172.17.0.1 rport 51381"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:16 1 UDP 1677722110 82.16.190.80 49196 typ srflx raddr 192.168.0.182 rport 49196"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:14 2 TCP 847250174 82.16.190.80 9 typ srflx raddr 172.17.0.1 rport 9 tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:17 1 TCP 847250431 82.16.190.80 9 typ srflx raddr 192.168.0.182 rport 9 tcptype active"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:15 2 TCP 843055870 82.16.190.80 48999 typ srflx raddr 172.17.0.1 rport 48999 tcptype passive"}}
{"type":"ice","data":{"sdpMLineIndex":0,"candidate":"candidate:18 1 TCP 843056127 82.16.190.80 34065 typ srflx raddr 192.168.0.182 rport 34065 tcptype passive"}}
[webrtc] websocket /output -- recieved message from 127.0.0.1 (peer_id=0) (639 bytes)
[webrtc] received SDP message for /output from 127.0.0.1 (peer_id=0)
v=0
o=- 3063459327295625883 2 IN IP4 127.0.0.1
s=-
t=0 0
a=msid-semantic: WMS
c=IN IP4 0.0.0.0
a=rtcp:9 IN IP4 0.0.0.0
a=ice-ufrag:fr/O
a=ice-pwd:aftzGMOvJiLp3hAEwDjnlUNl
a=fingerprint:sha-256 BA:3C:8B:17:19:C9:CE:09:47:57:26:58:F3:59:08:39:E0:EF:47:BE:A0:30:50:A0:A9:B0:AA:E3:42:2F:D6:CD
a=setup:active
a=mid:video0
a=recvonly
a=rtcp-mux
a=rtcp-rsize
a=fmtp:96 level-asymmetry-allowed=1;packetization-mode=1;profile-level-id=42e015
[webrtc] websocket /output -- recieved message from 127.0.0.1 (peer_id=0) (208 bytes)
[webrtc] received ICE message on /output from 127.0.0.1 (peer_id=0) with mline index 0; candidate:
candidate:2147567054 1 udp 2113937151 192.168.68.128 64683 typ host generation 0 ufrag fr/O network-cost 999
[gstreamer] gstreamer changed state from NULL to READY ==> funnel0
[gstreamer] gstreamer changed state from NULL to READY ==> dtlsenc0
[gstreamer] gstreamer changed state from NULL to READY ==> srtpenc0
[gstreamer] gstreamer changed state from NULL to READY ==> dtlssrtpenc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> funnel0
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlsenc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> srtpenc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlssrtpenc0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> funnel0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlsenc0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> srtpenc0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlssrtpenc0
[gstreamer] gstreamer changed state from NULL to READY ==> funnel1
[gstreamer] gstreamer changed state from NULL to READY ==> dtlsenc1
[gstreamer] gstreamer changed state from NULL to READY ==> srtpenc1
[gstreamer] gstreamer changed state from NULL to READY ==> dtlssrtpenc1
[gstreamer] gstreamer changed state from READY to PAUSED ==> funnel1
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlsenc1
[gstreamer] gstreamer changed state from READY to PAUSED ==> srtpenc1
[gstreamer] gstreamer changed state from READY to PAUSED ==> dtlssrtpenc1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> funnel1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlsenc1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> srtpenc1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> dtlssrtpenc1
[webrtc] websocket /output -- recieved message from 127.0.0.1 (peer_id=0) (242 bytes)
candidate:3056029747 1 udp 1677729535 113.178.86.135 64683 typ srflx raddr 192.168.68.128 rport 64683 generation 0 ufrag fr/O network-cost 999
[gstreamer] gstEncoder -- pipeline full, skipping frame 225 (1920x1080, 3110400 bytes)
video-viewer: captured 225 frames (1920x1080)
[gstreamer] GST_LEVEL_WARNING GstDtlsSrtpDemux dtlssrtpdemux
gstdtlssrtpdemux.c:134 sink_chain
received invalid buffer: 1
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)1433520, maximum-bitrate=(uint)66950640;
video-viewer: captured 250 frames (1920x1080)
video-viewer: captured 275 frames (1920x1080)
video-viewer: captured 300 frames (1920x1080)
video-viewer: captured 325 frames (1920x1080)
video-viewer: captured 350 frames (1920x1080)
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)1056720, maximum-bitrate=(uint)66950640;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)11907565, minimum-bitrate=(uint)723120, maximum-bitrate=(uint)66950640;
video-viewer: captured 375 frames (1920x1080)
video-viewer: captured 400 frames (1920x1080)
video-viewer: captured 425 frames (1920x1080)
video-viewer: captured 450 frames (1920x1080)
video-viewer: captured 475 frames (1920x1080)
video-viewer: captured 500 frames (1920x1080)
video-viewer: captured 525 frames (1920x1080)
video-viewer: captured 550 frames (1920x1080)
video-viewer: captured 575 frames (1920x1080)
video-viewer: captured 600 frames (1920x1080)
video-viewer: captured 625 frames (1920x1080)
video-viewer: captured 650 frames (1920x1080)
video-viewer: captured 675 frames (1920x1080)
video-viewer: captured 700 frames (1920x1080)
video-viewer: captured 725 frames (1920x1080)
video-viewer: captured 750 frames (1920x1080)
video-viewer: captured 775 frames (1920x1080)
video-viewer: captured 800 frames (1920x1080)
video-viewer: captured 825 frames (1920x1080)
