Videoflip element to Visionworks
I would like to add videoflip element to pipeline. I dont have problem when I rotate 180 degrees because the height and width values doesnt change but if I rotate for 90 degrees then I get error in the run time due to mismatch of dimensions.
I think if I can add the element just after the v4l2src element I would not have problem. I now add the videoflip element just before sink element.
I could not find the right gstreamer mentality to add it after the v4l2src. My goal is to rotate 90 degrees.
here is my modified code in GStreamerCameraFrameSourceImpl.cpp
modified parts:
// create videoflip convert element
GstElement * videoflip = gst_element_factory_make("videoflip", nullptr);
if (!videoflip)
    NVXIO_PRINT("Cannot create %s element", "videoflip");
    FinalizeGstPipeLine();
    return false;
g_object_set(G_OBJECT(videoflip),
             "method",2,
             nullptr);
gst_bin_add(GST_BIN(pipeline), videoflip);
stream << “video/x-raw, width=640, height=512, format=(string)I420;”;
// link elements
if (!gst_element_link_many(color,videoflip, sink))
    NVXIO_PRINT("GStreamer: cannot link color -> appsink");
    return false;
Copyright (c) 2015-2016, NVIDIA CORPORATION. All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of NVIDIA CORPORATION nor the names of its
contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS’’ AND ANY
EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#ifdef USE_GSTREAMER
#include “FrameSource/GStreamer/GStreamerCameraFrameSourceImpl.hpp”
#include <gst/app/gstappsink.h>
#include
namespace nvidiaio
GStreamerCameraFrameSourceImpl::GStreamerCameraFrameSourceImpl(uint cameraIdx_) :
GStreamerBaseFrameSourceImpl(nvxio::FrameSource::CAMERA_SOURCE, “GstreamerCameraFrameSource”),
cameraIdx(cameraIdx_)
bool GStreamerCameraFrameSourceImpl::setConfiguration(const Parameters& params)
NVXIO_ASSERT(end);
configuration.frameHeight = params.frameHeight;
configuration.frameWidth = params.frameWidth;
configuration.fps = params.fps;
NVXIO_ASSERT((params.format == NVXCU_DF_IMAGE_NV12) ||
             (params.format == NVXCU_DF_IMAGE_U8) ||
             (params.format == NVXCU_DF_IMAGE_RGB) ||
             (params.format == NVXCU_DF_IMAGE_RGBX)||
             (params.format == NVXCU_DF_IMAGE_NONE));
configuration.format = params.format;
return true;
bool GStreamerCameraFrameSourceImpl::InitializeGstPipeLine()
GstStateChangeReturn status;
end = true;
pipeline = GST_PIPELINE(gst_pipeline_new(nullptr));
if (!pipeline)
    NVXIO_PRINT("Cannot create Gstreamer pipeline");
    return false;
bus = gst_pipeline_get_bus(GST_PIPELINE (pipeline));
// create v4l2src
GstElement * v4l2src = gst_element_factory_make("v4l2src", nullptr);
if (!v4l2src)
    NVXIO_PRINT("Cannot create v4l2src");
    return false;
std::ostringstream cameraDev;
cameraDev << "/dev/video" << cameraIdx;
g_object_set(G_OBJECT(v4l2src), "device", cameraDev.str().c_str(), nullptr);
gst_bin_add(GST_BIN(pipeline), v4l2src);
if (!videoflip)
    return false;
             "method",2,
             nullptr);
// create color convert element
GstElement * color = gst_element_factory_make(COLOR_ELEM, nullptr);
if (!color)
    NVXIO_PRINT("Cannot create %s element", COLOR_ELEM);
    return false;
gst_bin_add(GST_BIN(pipeline), color);
// create appsink element
sink = gst_element_factory_make("appsink", nullptr);
if (!sink)
    NVXIO_PRINT("Cannot create appsink element");
    return false;
#if FULL_GST_VERSION >= VERSION_NUM(1,7,2)
g_object_set(GST_ELEMENT(sink), “wait-on-eos”, FALSE, nullptr);
#endif
gst_bin_add(GST_BIN(pipeline), sink);
// if initial values for FrameSource::Parameters are not
// specified, let's set them manually to prevent very huge images
if (configuration.frameWidth == (vx_uint32)-1)
    configuration.frameWidth = 1920;
if (configuration.frameHeight == (vx_uint32)-1)
    configuration.frameHeight = 1080;
if (configuration.fps == (vx_uint32)-1)
    configuration.fps = 30;
#if GST_VERSION_MAJOR == 0
std::unique_ptr<GstCaps, GStreamerObjectDeleter> caps_v42lsrc(
gst_caps_new_simple (“video/x-raw-rgb”,
“width”, GST_TYPE_INT_RANGE, 1, (int)configuration.frameWidth,
“height”, GST_TYPE_INT_RANGE, 1, (int)configuration.frameHeight,
“framerate”, GST_TYPE_FRACTION, (int)configuration.fps,
nullptr));
#else
std::ostringstream stream;
stream << “video/x-raw, width=640, height=512, format=(string)I420;”;//stream << “video/x-raw, format=(string){RGB}, width=[1,” << configuration.frameWidth <<“], height=[1,” << configuration.frameHeight << “], framerate=” << configuration.fps << “/1;”;
std::unique_ptr<GstCaps, GStreamerObjectDeleter> caps_v42lsrc(gst_caps_from_string(stream.str().c_str()));
#endif
if (!caps_v42lsrc)
    NVXIO_PRINT("Failed to create caps");
    return false;
// link elements
if (!gst_element_link_filtered(v4l2src, color, caps_v42lsrc.get()))
    NVXIO_PRINT("GStreamer: cannot link v4l2src -> color using caps");
    return false;
// link elements
    return false;
gst_app_sink_set_max_buffers (GST_APP_SINK(sink), 1);
gst_app_sink_set_drop (GST_APP_SINK(sink), true);
// do not emit signals: all calls will be synchronous and blocking
gst_app_sink_set_emit_signals (GST_APP_SINK(sink), 0);
std::unique_ptr<GstCaps, GStreamerObjectDeleter> caps_appsink;
if (configuration.format == NVXCU_DF_IMAGE_U8)
    caps_appsink.reset(gst_caps_new_simple("video/x-raw-gray",
                                           "bpp",        G_TYPE_INT, 8,
                                           nullptr));
else if (configuration.format == NVXCU_DF_IMAGE_RGB)
    caps_appsink.reset(gst_caps_new_simple("video/x-raw-rgb",
                                           "bpp",        G_TYPE_INT, 24,
                                           "red_mask",   G_TYPE_INT, 0xFF0000,
                                           "green_mask", G_TYPE_INT, 0x00FF00,
                                           "blue_mask",  G_TYPE_INT, 0x0000FF,
                                           nullptr));
else if (configuration.format == NVXCU_DF_IMAGE_RGBX ||
         configuration.format == NVXCU_DF_IMAGE_NONE)
                                           "depth",      G_TYPE_INT, 32,
                                           "bpp",        G_TYPE_INT, 32,
                                           "endianness", G_TYPE_INT, 4321,
                                           "red_mask",   G_TYPE_INT, 0xFF000000,
                                           "green_mask", G_TYPE_INT, 0x00FF0000,
                                           "blue_mask",  G_TYPE_INT, 0x0000FF00,
                                           "alpha_mask", G_TYPE_INT, 0x000000FF,
                                           nullptr));
else if (configuration.format == NVXCU_DF_IMAGE_NV12)
    caps_appsink.reset(gst_caps_new_simple("video/x-raw-yuv",
                                           "format", GST_TYPE_FOURCC, GST_MAKE_FOURCC ('N', 'V', '1', '2'),
                                           nullptr));
else
    NVXIO_THROW_EXCEPTION("Unsupported image format");
#else
std::string caps_string(“video/x-raw, format=(string){”);
caps_string += “GRAY8”;
caps_string += “RGB”;
caps_string += “RGBA”;
caps_string += “NV12”;
else
NVXIO_THROW_EXCEPTION(“Unsupported image format”);
caps_string += "};";
std::unique_ptr<GstCaps, GStreamerObjectDeleter> caps_appsink(
        gst_caps_from_string(caps_string.c_str()));
#endif
gst_app_sink_set_caps(GST_APP_SINK(sink), caps_appsink.get());
// Force pipeline to play video as fast as possible, ignoring system clock
gst_pipeline_use_clock(pipeline, nullptr);
//GstElement *pipeline1 = gst_parse_launch("v4l2src device=/dev/video1 ! videoflip method=1 ! video/x-raw, width=640, height=512, format=(string)I420 ! appsink",NULL);
status = gst_element_set_state(GST_ELEMENT(pipeline), GST_STATE_PLAYING);
handleGStreamerMessages();
if (status == GST_STATE_CHANGE_ASYNC)
    // wait for status update
    status = gst_element_get_state(GST_ELEMENT(pipeline), nullptr, nullptr, GST_CLOCK_TIME_NONE);
if (status == GST_STATE_CHANGE_FAILURE)
    NVXIO_PRINT("GStreamer: unable to start playback");
    return false;
// GST_DEBUG_BIN_TO_DOT_FILE(GST_BIN(pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "pipeline");
// explicitly set params to -1 to ensure
// their update in the updateConfiguration() function
configuration.frameWidth = (uint32_t)-1;
configuration.frameHeight = (uint32_t)-1;
configuration.fps = (uint32_t)-1;
if (!updateConfiguration(sink, color, configuration))
    return false;
end = false;
return true;
} // namespace nvidiaio
#endif // USE_GSTREAMER
We support 90-degree rotation in nvvidconv plguin. Please set the property:
  flip-method         : video flip methods
                        flags: readable, writable, controllable
                        Enum "GstNvVideoFlipMethod" Default: 0, "none"
                           (0): none             - Identity (no rotation)
                           (1): counterclockwise - Rotate counter-clockwise 90 degrees
                           (2): rotate-180       - Rotate 180 degrees
                           (3): clockwise        - Rotate clockwise 90 degrees
                           (4): horizontal-flip  - Flip horizontally
                           (5): upper-right-diagonal - Flip across upper right/lower left diagonal
                           (6): vertical-flip    - Flip vertically
                           (7): upper-left-diagonal - Flip across upper left/lower right diagonal
