Continuing the discussion from Holoscan problem using VideoRecorderOp for saving segmentation output:
Dear all,
I am facing a similar problem to this topic but unfortunately the answer by the initial user is not very informative.
Basically I am grabbing frames from an Epiphan video capture system and want to record the video stream. I use a FormatConverter for dropping the alpha channel and convert to Tensor with the use of FormatConverterOp.
I then use the VideoStreamRecorderOp to save the serialized frames to disk.
I keep having the message
2024-03-11 15:40:59.900 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
The file myvideo.gxf_index (recorder basename is “myvideo”) is always empty (0 bytes) while the file myvideo.gxf_entities is coherent (for instance if I receive 81 times the message above, this file is of size 503.9Mb which corresponds to 1920x1080x3 (input resolution, 3 channels uint8) x 81 (# frames) = 503.88Mb).
This way i cannot use the provided scripts in holoscan-sdk (holoscan-sdk/scripts at 90763fae219f27b36b758809fc052a416ee7a377 · nvidia-holoscan/holoscan-sdk · GitHub) to reconstruct a video file from gxf.
Note: If I use a HolovizOp, the frames are well displayed on my screen.
I do not understand what i do wrong and how to fix. Could you please help me here ?
Hereafter are provided the script I use (i installed holoscan 0.6.0 on an Orin DevKit) as well as the YAML config file:
import os
from holoscan.core import Application
from holoscan.conditions import CountCondition
from holoscan.operators import (HolovizOp,
V4L2VideoCaptureOp,
VideoStreamRecorderOp,
FormatConverterOp)
from holoscan.resources import (BlockMemoryPool,
UnboundedAllocator,
CudaStreamPool,
MemoryStorageType)
# Now define a simple application using the operators defined above
class App(Application):
"""Example of an application that uses the operators defined above.
This application has the following operators:
- V4L2VideoCaptureOp
- FormatConverterOp
- VideoStreamRecorderOp
def compose(self):
source_args = self.kwargs("source")
cuda_stream_pool = CudaStreamPool(
self,
name="cuda_stream",
dev_id=0,
stream_flags=0,
stream_priority=0,
reserved_size=1,
max_size=5,
if "width" in source_args and "height" in source_args:
# width and height given, use BlockMemoryPool (better latency)
width = source_args["width"]
height = source_args["height"]
n_channels = 4
block_size = width * height * n_channels
# allocator = BlockMemoryPool(
# self, name="pool", storage_type=0, block_size=block_size, num_blocks=1
allocator = UnboundedAllocator(self, name="pool")
source = V4L2VideoCaptureOp(
self,
name="source",
allocator=allocator,
**source_args,
# Set Holoviz width and height from source resolution
visualizer_args = self.kwargs("visualizer")
visualizer_args["width"] = width
visualizer_args["height"] = height
visualizer = HolovizOp(
self,
name="visualizer",
**visualizer_args,
# Set FormatConverter width and height from source resolution
converter_args = self.kwargs("converter")
converter = FormatConverterOp(
self,
name="converter",
pool=allocator,
cuda_stream_pool=cuda_stream_pool, # not much difference w/ and w/o this line : TODO to be investigated
**converter_args,
else:
# width and height not given, use UnboundedAllocator (worse latency)
self,
name="source",
allocator=UnboundedAllocator(self, name="pool"),
**self.kwargs("source"),
self,
name="visualizer",
**self.kwargs("visualizer"),
self,
name="converter",
**self.kwargs("converter"),
# Set recorder
recorder = VideoStreamRecorderOp(
self,
name="recorder",
**self.kwargs("recorder")
self.add_flow(source, converter, {("signal", "source_video")})
# self.add_flow(converter, visualizer, {("tensor", "receivers")})
self.add_flow(converter, recorder, {("tensor", "input")})
def main(config_file):
app = App()
# if the --config command line argument was provided, it will override this config_file
app.config(config_file)
app.run()
print("Application has finished running.")
if __name__ == "__main__":
config_file = os.path.join(os.path.dirname(__file__), "recorder.yaml")
main(config_file=config_file)
source: # V4L2VideoCaptureOp
device: "/dev/video0"
width: 1920
height: 1080
visualizer: # Holoviz
converter: # FormatConverterOp
out_tensor_name: "converted_tensor"
in_dtype: "rgba8888"
out_dtype: "rgb888"
recorder: # VideoStreamRecorderOp
directory: "/home/igs/Projects/holoscan-test/myholoscan/test-hs-record/recordings"
basename: "myvideo"
and hereafter are the logs i get in terminal (NOTE: i interrupt the application by stopping the process with Ctrl+C command):
[info] [gxf_executor.cpp:210] Creating context
[info] [gxf_executor.cpp:1595] Loading extensions from configs...
[info] [gxf_executor.cpp:1741] Activating Graph...
[info] [resource_manager.cpp:79] ResourceManager cannot find Resource of type: nvidia::gxf::GPUDevice for entity [eid: 00002, name: __entity_2]
[info] [resource_manager.cpp:106] ResourceManager cannot find Resource of type: nvidia::gxf::GPUDevice for component [cid: 00003, name: cuda_stream]
[info] [resource.hpp:44] Resource [type: nvidia::gxf::GPUDevice] from component [cid: 3] cannot find its value from ResourceManager
[info] [gxf_executor.cpp:1771] Running Graph...
[info] [gxf_executor.cpp:1773] Waiting for completion...
[info] [gxf_executor.cpp:1774] Graph execution waiting. Fragment:
[info] [greedy_scheduler.cpp:190] Scheduling 3 entities
Opening in BLOCKING MODE
2024-03-11 15:40:56.009 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
2024-03-11 15:40:56.037 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
2024-03-11 15:40:56.063 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
2024-03-11 15:40:56.088 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
2024-03-11 15:40:59.848 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
2024-03-11 15:40:59.873 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
^C[info] [greedy_scheduler.cpp:390] Stopping scheduler.
[ubuntu:2427644:0:2427658] Caught signal 11 (Segmentation fault: invalid permissions for mapped object at address 0xffff83d94150)
==== backtrace (tid:2427658) ====
0 /home/igs/Projects/holoscan-test/envhs060/lib/python3.8/site-packages/holoscan/graphs/..//lib/libucs.so.0(ucs_handle_error+0x2d4) [0xffff8c3bbce4]
1 /home/igs/Projects/holoscan-test/envhs060/lib/python3.8/site-packages/holoscan/graphs/..//lib/libucs.so.0(+0x2ae74) [0xffff8c3bbe74]
2 /home/igs/Projects/holoscan-test/envhs060/lib/python3.8/site-packages/holoscan/graphs/..//lib/libucs.so.0(+0x2b21c) [0xffff8c3bc21c]
3 linux-vdso.so.1(__kernel_rt_sigreturn+0) [0xffff950b07c0]
4 [0xffff83d94150]
