Holoscan problem using VideoRecorderOp for saving segmentation output
Hi, i´m having some issues using VideoRecorderOp (Holoscan Operator) for saving tensorrt segmentation output. Although it create a GXF file, when i convert GXF to AVI or MP4 the output file it´s just black video. The warning say “no serializer found for component”. Below i leave the warning and my code.
2024-02-28 02:12:08.447 WARN /workspace/holoscan-sdk/gxf_extensions/stream_playback/video_stream_serializer.cpp@188: No serializer found for component '' with type ID 0x7982aeac37f141beade86f00b4b5d47c
YAML config file
replayer:  # VideoStreamReplayer
  basename: "arthroscopic_segmentation"
  frame_rate: 0 # as specified in timestamps
  repeat: true # default: false
  realtime: true # default: true
  count: 0 # default: 0 (no frame count restriction)
aja:  # AJASourceOp
  width: 1920
  height: 1080
  rdma: false
  enable_overlay: false
drop_alpha_channel:  # FormatConverter
  in_dtype: "rgba8888"
  in_tensor_name: source_video
  out_dtype: "rgb888"
preprocessor:  # FormatConverter
  in_tensor_name: "input_tensor"
  out_tensor_name: "output_tensor"
  out_dtype: "float32"
  resize_width: 1024
  resize_height: 1024
  # scale_min: 0.0 scale_max: 255.0
  # out_channel_order: [2,1,0]  # BGR to RGB
inference:  # Inference
  backend: "trt"
  pre_processor_map:
    "AJA_arthrosegmentation": ["source_video"]
  inference_map:
    "AJA_arthrosegmentation": ["output"]
  # dla_core: 0
  # Para usar o DLA - Holoscan 0.4.0 encontrei informaçao SDK e suporta - Holoscan 1.0.3 não suporta?
postprocessor:  # SegmentationPostprocessor
  in_tensor_name: output
  network_output_type: softmax
  data_format: nchw
viz:  # Holoviz
  width: 1920
  height: 1080
  color_lut: [
    [0.65, 0.81, 0.89, 0.1],
    [0.2, 0.63, 0.17, 0.7]
Python
import os
from argparse import ArgumentParser
from holoscan.core import Application
from holoscan.operators import (
    AJASourceOp,
    FormatConverterOp,
    HolovizOp,
    InferenceOp,
    InferenceProcessorOp, # ver este
    SegmentationPostprocessorOp,
    VideoStreamRecorderOp,
    VideoStreamReplayerOp,
from holoscan.resources import BlockMemoryPool, CudaStreamPool, MemoryStorageType, UnboundedAllocator
class AJA_arthrosegmentation(Application):
    def __init__(self, data, source="aja"):
        """Initialize the arthrosegmentation application
        Parameters
        data : Location to the data
        super().__init__()
        # set name
        self.name = "AJA_arthrosegmentation"
        # Optional parameters affecting the graph created by compose.
        self.source = source
        if data == "none":
            data = os.environ.get("HOLOSCAN_INPUT_PATH", "../data")
        self.sample_data_path = data
        self.model_path = os.path.join(self.sample_data_path, "arthroscopic_segmentation", "model")
        self.model_path_map = {
            "AJA_arthrosegmentation": os.path.join(self.model_path, "unet_1024x1024_nhwc.onnx"),
        self.video_dir = os.path.join(self.sample_data_path, "arthroscopic_segmentation", "video")
        if not os.path.exists(self.video_dir):
            raise ValueError(f"Could not find video data: {self.video_dir=}")
    def compose(self):
        n_channels = 4  # 4 channels
        bpp = 4  # 4 bytes per pixel
        cuda_stream_pool = CudaStreamPool( # Create a pool of CUDA streams
            self,
            name="cuda_stream",
            dev_id=0,
            stream_flags=0,
            stream_priority=0,
            reserved_size=1,
            max_size=5,
        is_aja = self.source.lower() == "aja" # True if source is AJA
        if is_aja:
            source = AJASourceOp(self, name="aja", **self.kwargs("aja")) # Create an AJA source operator
            host_allocator = UnboundedAllocator(self, name="host_allocator") # Use UnboundedAllocator instead of BlockMemoryPool
            drop_alpha_channel = FormatConverterOp( # Create a format converter operator
                self,
                name="drop_alpha_channel",
                pool=host_allocator, # Use host_allocator instead of BlockMemoryPool
                cuda_stream_pool=cuda_stream_pool,
                **self.kwargs("drop_alpha_channel"),
            ) # The format converter operator will drop the alpha channel
        else :
            video_dir = os.path.join(self.sample_data_path, "arthroscopic_segmentation", "video") # Set the video directory
            if not os.path.exists(video_dir): # Check if the video directory exists
                raise ValueError(f"Could not find video data: {video_dir=}")
            source = VideoStreamReplayerOp( # Create a video stream replayer operator
                self, name="replayer", directory=self.video_dir, **self.kwargs("replayer")
        preprocessor = FormatConverterOp(
            self, name="preprocessor", pool = host_allocator, # Use host_allocator instead of BlockMemoryPool
            cuda_stream_pool=cuda_stream_pool, **self.kwargs("preprocessor")
        # Inference
        inference = InferenceOp(
            self,
            name="inference",
            allocator=host_allocator,
            model_path_map=self.model_path_map,
            **self.kwargs("inference"),
        # Post processor
        postprocessor = SegmentationPostprocessorOp(
            self, name="postprocessor", allocator=host_allocator, **self.kwargs("postprocessor")
        # Recorder
        recorder = VideoStreamRecorderOp(
            self,
            basename="segmentation",
            flush_on_tick=True,
            name="recorder"
        viz = HolovizOp(self, name="viz", **self.kwargs("viz"))
        # Define the workflow
        if is_aja:
            self.add_flow(source, viz, {("video_buffer_output", "receivers")})
            self.add_flow(source, drop_alpha_channel, {("video_buffer_output", "")})
            self.add_flow(drop_alpha_channel, preprocessor)
            self.add_flow(postprocessor, recorder)
        else:
            self.add_flow(source, viz, {("output", "receivers")})
            self.add_flow(source, preprocessor, {("output", "source_video")})   #porque source_video?
        self.add_flow(preprocessor, inference, {("tensor", "receivers")})       #porque tensor?
        self.add_flow(inference, postprocessor, {("transmitter", "in_tensor")})
        self.add_flow(postprocessor, recorder, {("out_tensor", "input")})
        self.add_flow(postprocessor, viz, {("out_tensor", "receivers")})
if __name__ == "__main__":
    parser = ArgumentParser(description="AJA_arthrosegmentation demo application.")
    parser.add_argument(
        "-s",
        "--source",
        choices=["replayer", "aja"],
        default="replayer",
        help=(
            "If 'replayer', replay a prerecorded video. If 'aja' use an AJA "
            "capture card as the source (default: %(default)s)."
        "-d",
        "--data",
        default="none",
        help=("Set the data path"),
    args = parser.parse_args()
    config_file = os.path.join(os.path.dirname(__file__), "AJA_arthrosegmentation.yaml")
    app = AJA_arthrosegmentation(data=args.data, source=args.source)
    app.config(config_file)
    app.run()
Hi there, the warning you’re seeing may not be the root cause. Could you please create a minimal reproducible sample to run for this issue of saving a blank video? We’d be happy to take a look into that.
Hi, problem solved. I still have the warning but you were right, it is not directly linked to the problem I was having. My problem was not using VideoRecorderOp the right way.
Thank you for your help!
